FarSports 38mm Carbon Clincher Review Thread, The
I used small strips of electrical tape over each veloplug, mostly because I was worried about any sharp edges puncturing the tube. I'm sure it would've been fine otherwise, but I'll take a few grams penalty for some peace of mind. Still lighter than standard rim tape I believe.
- prendrefeu
- Contact:
No, electrical tape isn't strong enough to hold up to the pressure from the air in the tubes. It's a bit weak.
Frankly putting electrical tape over the veloplugs is overkill: not only are they already a tight fit (and won't come out easily), the air pressure holds them in place as well. Electrical tape then just adds nothing of value, only weight.
Alternatives to veloplugs:
Rox rim tape (but you'll need two layers)
Small pieces of strapping tape (the type with fibre strengthening in the tape)
I put electrical tape over my veloplugs only to make sure that any sharp edges didn't puncture my tube, as they're a tight fit because FarSports drills their spoke holes to 7.5mm. A little peace of mind with almost no weight penalty IMO.
I'm thinking about picking up a pair of 38mm rims. I have a set of extralite hubs and w/ cx-ray spokes the set will probably come in somewhere around 1200g, probably a bit less.
Speedplay is the devil!
ok.. just emailed kyle.. going to pick up both sets: 38mm and the 50mm.
quick question to all current owners.. as i followed this thread.. i recall reading the brake pads use to be blue and now yellow? what's the difference between them or is it just color preference?
- carlislegeorge
blue are similar (same?) as Reynolds pads, likely they just phased out stocking those?
yellow are Swisstop brand.
different compounds, may behave differently.
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
- btompkins0112
I am going to switch the Black Prince pads when I get a chance.....folks have said very good things about them with these wheels.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
Sure. You can use any old pads you want. But the braking will probably suck and they could damage the rims.
I'd use the Reynolds blue pads. Their perfomance is noticeably superior to the Yellows and they cost less.
- Similar Topics
- Replies
- Views
- Last post
Campagnolo Bora One 50 Clincher Vs Fulcrum Racing Zero Carbon Clincher
by jokersan » Sun Jan 21, 2018 3:58 pm » in Everything wheels - 6 Replies
- 1152 Views
Last post by jokersan
Sun Mar 11, 2018 5:13 pm
- 9 Replies
- 489 Views
Last post by ms6073
Fri Feb 16, 2018 7:30 pm
- 5 Replies
- 1325 Views
Last post by 02GF74
Sun Dec 10, 2017 5:20 pm
- 3 Replies
- 1547 Views
Last post by F45
Sat Jul 15, 2017 1:35 pm
Campagnolo Zonda c17 vs Farsports wheels
by weeniepower » Wed Feb 21, 2018 7:59 am » in Everything wheels - 9 Replies
- 784 Views
Last post by Multebear
Fri Feb 23, 2018 11:29 pm
