Open mold wide profile carbon wheels
sspring
by sspring
riding2013 wrote:Did you guy mean this without holes?
Find this on yoeleo site,they call it "Special Assembly Technology"
Looks pretty cool. :lol:
Yes, that is what I'm talking about. I know there are several companies that offer this type of build. Personally I think its awesome even if you don't go tubeless. Don't have to fool with rim tape and its probably built a bit stronger since there are no holes taking away from the structure of the wheel.
Build quality of the LB45's wheelset is very good. After several thousand miles they are still perfect. Minus the clear on the brake trac that is still slowly rubbing off.
sspring
by sspring
drewb wrote:Update on my Light Bicycle wheels.
After a bit of delay LB sent me 2 new rims with out the "thick clear coat" issues.
Braking is good. Dry only. I have not tried wet.
No buildup of brake material so far - 100km ride through Sydney with lots of braking for lights etc.
Very very happy with the new set.
I will update if this changes.
Is the braking any better/different without the clear?
Not sure if I am going to ask for new rims still
Zigmeister
by Zigmeister
prendrefeu wrote:
dookiedoodle wrote:Spring, did LB build your wheels with no spoke holes in the tire bed? Are the nipples regular nipples? What do you do if you need to replace a spoke? I don't understand how this is possible with standard nipples unless they put an extra layer of carbon on after building them. Magnets? Aluminum is not ferromagnetic so I don't see how this would help. I am planning on building up some LB rims myself and would love to know how to do it without drilling through the tire bed.
It's a pretty common practice. Regular nipples.
Here's a video to help you figure out how it's done:
http://www.youtube.com/watch?feature=pl ... x3rs#t=210" onclick="window.open(this.href);return false;
Haha..cool. But I didnt know those aluminum Fulcrums were "high-end" racing wheels like the outdated video suggests.
Cool technique, simplest of solutions sometimes.
What gets me a tad pissed is I bought a set of 40mm Hongfu aero rims. Then not long after, light came out with their 45mm, which I prefer. Yet, even with the 5mm added depth and no holes drilled, they are the same weight as my Hongfu.
Oh well.
natefontaine
by natefontaine
Getting these built up soon. 50mm x 25mm wide. 3k weave matte finish.
16h front laced to DA7900
24h rear laced to DA9000
cxray spokes all around.
Est. Just under 1400gm
Sent from my SPH-L900 using Tapatalk
chops
by chops
Nate, where did you get them from? Weight is good.
natefontaine
by natefontaine
Speedcarbon11 from eBay. They're good to the claimed 410+/-20gm. Build quality looks very good.
natefontaine
by natefontaine
Waiting on delivery of the hoops...
23wide x 20mm
20h/24h
BHS SL85W front hub
BHS UL190 rear hub
Cxrays with prolock nipples.
Est. Sub 1000 :)
Found these from Nextie Bikes on eBay. I wanted something wider than the standard 19mm wide low profiles, so I don't have to adjust the brakes when switching between my other 50x25mm wheels.
WMW
by WMW
I don't know... Enve, Zipp, and Reynolds eventually conceded that they couldn't make rims that light that would hold together. If *you* are very light and easy on wheels, maybe you'll be ok.
formerly rruff...
sspring
by sspring
thats crazy light. 150-200g lighter than most carbon rims......not sure
thats either a revolution or an abomination
hope you have health insurance......
petepeterson
by petepeterson
Are those clinchers or tubulars
natefontaine
by natefontaine
Tubular. I hope they turn out OK.
petepeterson
by petepeterson
For the record the enve 25 rims are 35gr heavier not 200. Don't know why everyone is losing their shits. Maybe they assumed they were clinchers which would be bonkers. You'll be fine.
kavitator
by kavitator
good luck on descending
gjash
by gjash
Seems to be much envy for those super light rims. I would use them for a hill climb race any day. I weigh 71kg. Enjoy them!
Sent from my SC-04E using Tapatalk
kavitator
by kavitator
I think ENVE has a reason to add weight on their rims - less overheated brake tracks-specially on low profile rims - less mass less cooling
