Post new topic Reply to topic  [ 323 posts ]
Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 22  Next
PostPosted: Wed Mar 20, 2013 1:48 am
Tubbie Guru
Hi,
wrcompositi wrote:
fdegrove wrote:
Hi,
Quote:
Besides, the wheel's stiffness doesn't depend on spoke tension.
Which begs the question, what does spoke tension influence if not stiffness?
Ciao, ;)
Well, I think Dave has summed it up pretty well in the previous post. :thumbup: Higher tension can prevent NDS spokes from going totally slack but doesn't contribute to better stiffness.
The correct answer is responsiveness.
Ciao, ;)
PostPosted: Wed Mar 20, 2013 3:35 pm
According to Nancy at HongFu, the HF-R86 (the new 86mm aero wheel from them) is currently undergoing testing in China and will not be ready for production until the middle of April. Also, all of the new Aero models from them (the 40, 56, and 86) will only be made with external nipples, which I guess is a bit surprising to me considering they are aero specific wheels. I'm sure it's not that big of a difference in the drag coefficient, but it was still curious to me that they didn't go the internal route.
PostPosted: Wed Mar 20, 2013 10:23 pm
Do you have info on the availability of the other profiles? I'm particularly interested in the 40 tubular... Thanks!
PostPosted: Thu Mar 21, 2013 12:18 am
Nancy mentioned that the 56 is available now in both tubie and clincher. However, both the 40 and the 86 are 40-50 days out. I could be mistaken, tho. She's really good about answering my emails. You can reach her here ::
sales04@hongfu-bikes.cn
Just remember that their days are usually just the opposite of those of us in the USA. I find that she answers me immediately (almost like an instant message) around 9pm MST.
Good luck
PostPosted: Thu Mar 21, 2013 7:30 am
Yestarday I got my U-shape wheels from LBS.
Mechanic said that the Circus Monkey rear hub has very bad center to flange dimensions. He can´t interlace spokes (too much bend). I was almost sure that my rear wheel has no lateral stiffness, but I took a quick spin in the evening and it felt stiff.
Conti GP4000S 25mm is 27,1mm on this rim.
I mounted cassette with spacer as usually, but then I heard little clatter. Spacer was moving between hub and cassette. Then I removed it and chain didn´t touch spokes, weird!
"Nothing compares to the simple pleasure of a bike ride"
Scale 30
Schenk 007
My blog
PostPosted: Thu Mar 21, 2013 1:39 pm
wut? got hub measurements?
PostPosted: Thu Mar 21, 2013 1:47 pm
viewtopic.php?f=113&t=74564&start=3750
Scale 30
Schenk 007
My blog
PostPosted: Thu Mar 21, 2013 4:10 pm
Scratch what I said earlier - I just re-read our conversations via email. The following are already available ::
1. 40mm tubular
2. 56mm tubular
3. 56mm clincher
The following are 40-50 days out ::
1. 40mm clincher
2. 86mm tubular
3. 86mm clincher
I should also add that it is at least reassuring that HongFu mandates that their products pass certain quality tests. From their Flickr page, those test appear to be quite rigorous. They also claim to pass the EU standards and provide the actual documents to prove that.
PostPosted: Thu Mar 21, 2013 4:35 pm
rainerhq wrote:
Yestarday I got my U-shape wheels from LBS....
Did you get a chance to weight the rims before the wheels got built?
PostPosted: Thu Mar 21, 2013 5:03 pm
493/500g
Scale 30
Schenk 007
My blog
PostPosted: Sat Mar 23, 2013 4:18 pm
I'm with you...liking the profile of the HongFu 40mm. Looks very close to my Zipp 303 FCs. Would like to get a set built up with the DT 240s hubs in clinchers for training.
I live in Florida, even on hills/descents, it is flat out. Only a few times where you need to ride the brakes to slow down enough to take a turn, the vast majority down here are running carbon clinchers. Nobody has had a wheel implode yet, never an issue around here.
I sent HongFu an email regarding pricing and ability to build wheelsets.
Otherwise, have to get the rims, then have them built up with some CXRays and good quality hubs on my own.
PostPosted: Tue Mar 26, 2013 6:12 pm
1. 40mm tubular
2. 56mm tubular
3. 56mm clincher
1. 40mm clincher
2. 86mm tubular
3. 86mm clincher
I sent a message inquiring about the 56mm tubular and was told "the tubular rims now is testing". Then I asked when they would be available and was told "the tubular don't have the lead time".
PostPosted: Tue Mar 26, 2013 8:34 pm
Nancy sent me this: I've asked again for clarification as to what is exactly available.
"this is Nancy.
the price:
40mm tubular rim:$275
40mm clincher rim:$375
56mm tubular rim:$285
56mm clincher rim:$385
now only have clincher rim is producing.
tubular is testing."
I'm confused...so it seems no tubulars, just clinchers?
Then she replies back they have both sets in tubulars of 40-56mm....can't get a straight answer.
Edit, latest as another poster mentioned. Only 56mm clincher available now. No ETAOn tubulars in the various sizes.
PostPosted: Fri Mar 29, 2013 9:19 pm
Farsports 50x25mm to Novatec disc hubs with Sapim CX-Ray:
I've not yet received them, but weight is (I am assured) 1,580g.
PostPosted: Sat Mar 30, 2013 5:45 pm
Anyone know which colour/size of Veloplug I need to order for the Farsports 50X25mm clincher rims?
Post new topic Reply to topic  [ 323 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 22  Next
Users browsing this forum: No registered users and 5 guests
There are no new unread posts for this topic. "Open mold" asian cyclocross carbon fork
in Cyclocross / Touring
LouisN
7
893
Wed Apr 17, 2013 10:31 pm
LouisN View the latest post
There are no new unread posts for this topic. Do latest wide profile wheels increase rolling resistance?
dynaserve
44
2836
Thu Jan 24, 2013 12:02 am
fdegrove View the latest post
There are no new unread posts for this topic. Low profile carbon tubular wheels
in Wanted
$mokeyJoe
Thu May 23, 2013 5:46 pm
$mokeyJoe View the latest post
There are no new unread posts for this topic. FLO 30: New wide clincher wheels
[ Go to page: 1, 2, 3, 4 ]
olebole
48
6601
Mon Apr 29, 2013 5:55 pm
Canadian View the latest post
There are no new unread posts for this topic. Deep Profile Wheels
Colnago68
Sun Oct 28, 2012 4:41 am
Bianchi10 View the latest post
It is currently Tue Jun 18, 2013 7:27 am
