It is currently Thu Apr 27, 2017 1:03 am
Post new topic  Reply to topic  [ 1496 posts ]  Go to page Previous 169 70 71 72 73100 Next
PostPosted: Thu Jul 24, 2014 1:26 pm
Where did you get that 28mm wide rim?
PostPosted: Fri Jul 25, 2014 12:18 am
Look a couple of pages back.
PostPosted: Fri Jul 25, 2014 5:11 pm
LoL thanks thuekr I should have looked at that first huh LoL
PostPosted: Fri Jul 25, 2014 5:58 pm
I'm anxiously awaiting your ride report @thuekr
Please flood this thread with pictures too. If you need someone to post the pictures for you, I will be more than happy to do it myself, just let me know.
PostPosted: Fri Jul 25, 2014 9:52 pm
My build is for a track bike - so my experiences are somewhat limited regarding a roadie-build. Anyway - I will share my experiences. BTW found another picture of the rim I haven't seen before.
PostPosted: Fri Jul 25, 2014 9:55 pm
That's the Yishun rim, the metal bit at the clincher bead is the giveaway.
PostPosted: Fri Jul 25, 2014 10:00 pm
Yup should be the WU6C I've ordered and is on it's way.
PostPosted: Fri Jul 25, 2014 11:01 pm
Any first hand experience with the VeloBuild 40 or 50mm, 25mm wide wheels?
Instagram @seanblurr
PostPosted: Wed Jul 30, 2014 7:51 am
Done a fair bit of reading and it's all got a bit daunting. So I'll stick a question out there and see how I go...
Looking to put together a shallow depth carbon-clincher-rim with disc-hub wheelset. Sticking them on my cross bike for wet-weathr-commuting and wet-weather-road-training duties.
Who should I be speaking to... hongfu, light bicycle or someone else?
Weight is not so much the concern as best build quality. They are replacing a wheelset that would have to be over 2kg... whatever I get, it will be a major improvement.
Thanks all.
PostPosted: Wed Jul 30, 2014 8:40 pm
i've had great luck with farsports, their rims have always been pretty spot-on in terms of weight, build quality (although they're not the cheapest anymore...)
PostPosted: Thu Jul 31, 2014 3:32 am
When you say "put together" are you planning to build the wheels?
I am really happy with the quality of my Light Bicycle U45 rims. Those obviously aren't shallow, but they have 29er MTB rims that might fit the bill. (My rims weighed 450g/pc so pretty light for wide rims.) Quality of the carbon finish, smoothness of bead/bed was all very nice. The ERD on both rims was identical and matched claimed numbers. The weights of each were within 2g of each other (and claimed). They seemed to be much better-built (at least the aspects one can see) than the Farsports clinchers I had previously. They also claim to be tubeless ready, though I have not tested that yet.
I just bought the rims and built the wheels; I had a poor experience with build quality from Farsports (I had to rebuild those wheels), so decided to build myself -- though that is not cheaper. I also wanted to use a front hub they did not have available -- the Novatec XD711 hub that is convertible to 15mm thru-axle (and 9mm thru-axle, which is what I am running now).
Anyway, very happy with these wheels. I have only ridden these ~1800 miles, buy they have sustained a lot of abuse (potholes, gravel, a crash a couple weeks ago) without flinching.
PostPosted: Thu Jul 31, 2014 11:52 pm
Yeah sorry when I said put together I used the term pretty loosely. I meant I'm going to spec a road rim with no brake track to mtb disc hub.
Any indication of build quality by light bicycle?
PostPosted: Fri Aug 01, 2014 2:50 am
I don't know; hopefully others can comment. You might want to look at reviews at MTBR too, as I think these guys are known (more?) for their MTB wheels. They use Pillar spokes (not Sapim) and they do offer the standard D711/D712 Novatec hubs, which seem just fine. Dunno if LB stocks a thru-axle hub option.
The only negatives I have seen on LB had to do with clearcoat on the brake tracks / poor braking, but obviously that was not a concern for the disc-brake build.
Anyway, good luck with the disc wheelset project.
PostPosted: Fri Aug 01, 2014 2:15 pm
Any recent comments about the wheels?
Me and my friend are looking for 2 sets, and it will be either U45 or wide wheels from Hongfu.
My Orbea Orca
My Stava
My Instagram
PostPosted: Sat Aug 09, 2014 9:03 pm
Pretty much my thoughts on my 45mm LB disc rims! Also bought the rims separately and got them built up on Hope hubs by a local wheel builder - about 1300 miles so far, over some quite rough roads at times, and no problems whatsoever. Really impressed! I'm running them tubeless too, which also works fine.
There are no new unread posts for this topic. Attachment(s) Chinese Open Mold Gravel / CX Bikes
waltthizzney
31
4328
Wed Apr 26, 2017 5:10 pm
dustinmeyer View the latest post
There are no new unread posts for this topic. High profile wheels, advice needed
in Everything wheels
1415chris
Mon Jul 25, 2016 12:37 pm
kgt View the latest post
There are no new unread posts for this topic. Sealant and Valve Core Extension on High-Profile Wheels
Lightweenie
Fri Apr 21, 2017 11:52 pm
beatle View the latest post
There are no new unread posts for this topic. Flat profile full carbon saddle w/cutout
nickf
7
887
Tue Jul 26, 2016 4:18 am
NGtim View the latest post
There are no new unread posts for this topic. Carbon or Ti Narrow/Wide 50T Chainring?
Synnove
Tue May 03, 2016 9:20 am
mulletmaster View the latest post
Users browsing this forum: AC0, FilipBlcr, Hexsense and 7 guests
