Beaver wrote: ↑Thu Apr 19, 2018 12:18 pm
Hexsense wrote: ↑Thu Apr 19, 2018 12:14 am
i'm using 23c on 21mm on my front wheel.
I think 25c on 23mm will be great.
Expected tire width is only 0.7mm wider than on 21mm from my rough estimation.
Some 28c are narrower than others. Vittoria Corsa G+ 28c, for example, is not much wider than the 25c.
How does the 23mm tire feel on 21C? For some it's a bit too hard...?
I'm happy with 25mm on 21C and never tried 23mm until now. What pressure are you running at which rider weight?
And do they also plan lower versions of this rim?
23c on 21 is right at the limit where i still feel fully confident about the system. I'd only do it on big 23c like Continental and certainly not small 23c like Veloflex etc.
I use Continental Force III and Attack III which is 23c and 25c combo. Although they use the same Black Chili compound as the 4000sII as well as having same Vectran breaker, they are still thinner thus they feel softer than 4000sII so i run them a bit higher up than i used to. Front wheel pumped to 70-80 psi (depend on road i plan to ride them on). With rear wheel only 3-5 psi more because it's already mostly compensated by being 25c.
I find them good, fast, comfortable for me, 64kg rider. Cornering feel a bit strange at first compare to Pirelli Pzero Velo 25c up front especially when the tire is so new that it doesn't grip well yet. Then the tire break in and i get used to it quickly. It's certainly aero as the front tire is not wider than the rim.
I also have chances to compare test 17mm inner width and 21mm inner width rear wheel with the same tire (the 17mm inner width wheel become my spare wheel since i got the 21mm). The 17mm really need 10+ more psi to not feel squishy in hard corner. The 21mm inner width rim (wider base) really do stabilize base of the tire. So i'm a believer of wide internal width being the way forward... as long as we are sensible about tire we put on them. 23-28c on 21mm and 25-30c on 23mm sound about right for me.
