It is currently Sun Apr 30, 2017 10:28 am
Post new topic  Reply to topic  [ 133 posts ]  Go to page Previous 15 6 7 8 9 Next
PostPosted: Sat Jun 02, 2012 9:17 pm
If you're looking for light durable chainrings for sram xx - check out my lastest post on my blog. It's about Tune 39T vs. Sram XX 42T chainrings. Saved me 40 grams :-)
My blog
PostPosted: Thu Sep 06, 2012 6:17 pm
Pent utført bygg! :-D
PostPosted: Wed Oct 17, 2012 12:37 am
Very good job.
PostPosted: Wed Oct 17, 2012 6:22 am
Great build, but frame is to big for you.
PostPosted: Wed Oct 17, 2012 1:36 pm
Online
Thanks, djm and tompho.
anquetil: I know, so I changed it to a smaller one. Besides being a better fit, it saved me 15 gms or so :beerchug:
PostPosted: Wed Apr 10, 2013 10:11 am
Any updates about the build Martin?
How much did it weight it the Racing Ralph's on the Sid fork?
Cheers
David
PostPosted: Sun May 05, 2013 5:44 pm
Perfect Ride!
Are there any photos of the bike with the rigid?
PostPosted: Sun May 05, 2013 8:02 pm
Online
No updates on the build yet. The buildlist now is as follows:
Frame: Vipera sans clearcoat - 1174g
Fork: Sid WC XX - 1446g
Headset: Frankenset - 69g
Expanders + spacers + topcap: FSA - 55g
Handlebar: AX poseidon 620mm - 94g
Grips: Extralite ultragrips - 15g
Stem: Extralite UL3 - 86g
Seat/post: Berk composites - 142g
Seatpostclamp: Procraft - 10g
Shifters: Sec gripshifts (tuned) - 94g
Front derailleur: D-A 7900 with Carbon-ti X-pull - 81g
Rear derailleur: Sram XX with Roth Shek pulleys - 165g
Cables and housings: Powercordz - 32g
Chain: Kmc - 238g
Cassette: Sram XX - 187g
Crankset: Sram XX incl sram BB30 - 745g
Pedals: Shimano XTR - 310g
Brakes: Formula r1 racing with KCNC 160mm front/rear - 517g
Wheels: Stans notubes gold - 1326g
QR: Ebay titanium/carbon - 44g
Tubes: Yellow tape + American classic valves - 14g
Sealant: Joe's - 70g
Tires: Maxxlite 29 - 694g
Adding up to a total of 7609g suspended and 6694g rigid.
Changes I had to make:
Expander: I stripped the bolt, and the stem could not hold on tight enough to keep the headset properly in place. I had a heavy FSA expander laying around
Crankset: I could not get the Lightning to fit properly, so I bought an XX
Wheels: Had some problems with the Extralite/crest, so bought Race gold
Pedals: Eggbeater 4ti's developed a LOT of play after many years of service, swapped for XTR
Changes to come.
New wheels. Hopefully something just below 1300gms and with carbon rims to make them stiffer: -30g
New pedals: I now work in a shop that sells eggbeaters, so I'm buying some 2's and some aftermarket ti spindles: -98g
Maybe new chainrings: Tune for sram XX: -22g
New expander: Extralite ultrastar + lightweight carbon topcap: -37g
Still heavier than what I started with due to heaaavy crankset, but just below 7.5kg suspended and just above 6.5 rigid. I've also looked around to find the Apro-tek MC709ca to save 200gms :O
PostPosted: Sun May 05, 2013 8:32 pm
Hey Martin - you need to let us see your smaller frame :-)
My blog
PostPosted: Fri Jun 28, 2013 10:53 am
Online
This bike went through a reverse diet after some failed and misfit parts.
First I couldn't get the crankset to work, so I went from 561g Lightning to 745g Sram XX - a 184g gain
Then my trusty old 4ti's died on me after several rebuilds, so I went from 168g 4ti to 306g XTR - a 138g gain
Then I had some problems with the FRM expander and the non-bolted topcap, so I went from 4g+3g = 7g to 55g FSA expander + spacer - a 48g gain
So my bike was at a total of 7605g for a while, but now it's time to update it. This is what it looks like right now
IMG_6257 by Martin.F., on Flickr
I bought a new bolt and topcap for the FRM expander, and I'm going to buy a slam that stem topcap or a veloflyte one + cut the steer tube a bit more. New expander weight is 21g + 7g spacers. Trimming the topcap + removing some spacers should bring me down another 8-10g, so a total reduction of around 35g
I will most likely buy some eggbeater 2's and titanium spindles for them, or maybe just a titanium spindle for the XTR. Recommendations appreciated.
I've not been superhappy with the race gold wheels, so I'm upgrading them. Here's the start. I've bought some Light-bicycle rims promised below 360g, and they will be laced most likely with Megalite SS on the high-tension side, and X-tra lite titaniums on the low-tension side. The wheels should weigh around 1240g, and that will shed 70g + add stiffness.
Mack superlight front hub by Martin.F., on Flickr
Pop rear hub by Martin.F., on Flickr
The pair by Martin.F., on Flickr
PostPosted: Wed Jul 03, 2013 8:28 am
Online
Rims in place. Hopefully around 1220-1230g wheelset
rim1 by Martin.F., on Flickr
rim2 by Martin.F., on Flickr
PostPosted: Wed Jul 03, 2013 10:32 am
Don't you mean 1224-1234 grams? ;-) rims looks good - looking forward to hear about how they perform. Would be nice with a pair of carbon rims.
My blog
PostPosted: Mon Jul 15, 2013 12:29 pm
Online
New parts! Wheelset is taped rear, non-taped front. Assuming 5g tape pr wheel, it adds up to 1248g wheelset including tape, and 1238g bare wheels. Handlebar is 640mm wide and bar-end friendly.
Mt zoom handlebar weight by Martin.F., on Flickr
Rear wheel weight by Martin.F., on Flickr
Front wheel weight by Martin.F., on Flickr
Front hub by Martin.F., on Flickr
Nipple/rim by Martin.F., on Flickr
Rear hub by Martin.F., on Flickr
PostPosted: Sat Jul 20, 2013 8:12 am
Great wheels, Martin - had a chance to test them?
My blog
PostPosted: Sat Jul 20, 2013 10:14 pm
Good job!
There are no new unread posts for this topic. Project sub 6kg retro weenie experiment -finished for now 6.22kg
[ Go to page: 1 2 3 4 ]
bm0p700f
52
9364
Thu Nov 10, 2016 12:37 am
bm0p700f View the latest post
There are no new unread posts for this topic. Finished my Caad12
Hapsmo911
Sun Jul 10, 2016 10:21 am
LeeCH View the latest post
There are no new unread posts for this topic. Raw finished steel bike...
Wingnut
37
5665
Thu Sep 08, 2016 1:32 pm
Wingnut View the latest post
There are no new unread posts for this topic. Project WW Emonda SLR
rsiv
Sat Apr 01, 2017 10:41 am
hlvd View the latest post
There are no new unread posts for this topic. project CAAD10 raw or ....
gtinut
Thu Nov 10, 2016 2:44 pm
gtinut View the latest post
Users browsing this forum: bomber, dereksmalls, DOUG, glam2deaf, Google [Bot], Google Adsense [Bot], joaoteixeira and 11 guests
