The CAAD Build Thread...
Moderators: maxim809, Moderator Team
tomee wrote:just finished this build over the weekend
di2 disc.
Currently weights 7.95
Only issue is when i used a converted BB, the hydraulic lines would touch the crank axles.
I think i have solved this issue by araldite the cable down and running a sleeve over the axle.
probably do some more weight savings by cutting the seatpost and Ti pedals
I'm actually quite curious to find out what exactly did you use for the BB conversion. Are you using adaptors to the existing BB30 bearings or the BB sleeve that converts it entirely to take the English threading? Thanks!
Sick setup with the Shimano cranks!
thanks
I'm using Kogel ceramic adaptor. Take out the existing bearings and press the Kogel in
http://kogelbearings.mysimplestore.com/ ... ano-cranks
- thencameyou
Also posted in 'Dale thread but really belongs here I guess
tomee wrote:thanks
Also want to convert my BB30 CAAD10 with a Shimano crankset.
Curious on what's the weight of this adaptor.
Louis
LouisN wrote:tomee wrote:thanks
Louis
that is one thing i forgot to do when i received the adaptor unfortunately
Louis
Why not go with the wheelmfg plugs ? simple installation/removal and looks like it might be the lightest solution.
wheelzqc wrote:LouisN wrote:tomee wrote:thanks
Louis
I had originally planned to use the wheelsmfg adaptors but opted to go for a proper adaptor like the Kogel
- alexneumuller
- Contact:
I m looking to purchase a Caad 12 frame and move my SRAM RED22, Enve Cockpit and all other parts over from another bike. However my current bike has a SRAM Black Back GXP Ceramic Cup BB and comes with a SRM Power Meter S975 GXP Compact.
Could somebody please advise on what is the best way to do this. I know Praxis Work do a PRAXIS CONVERSION BOTTOM BRACKET, a CONV BB-SRAM™/GXP™ ISIS2 ROAD BB Size 68mm.
Is this the correct one? Or are there any other ones on the market? Better ones? Ceramic Ones?
Thanks in advance!
Thanks in advance!
alexneumuller wrote:I m looking to purchase a Caad 12 frame and move my SRAM RED22, Enve Cockpit and all other parts over from another bike. However my current bike has a SRAM Black Back GXP Ceramic Cup BB and comes with a SRM Power Meter S975 GXP Compact.
Could somebody please advise on what is the best way to do this. I know Praxis Work do a PRAXIS CONVERSION BOTTOM BRACKET, a CONV BB-SRAM[TRADE MARK SIGN]/GXP[TRADE MARK SIGN] ISIS2 ROAD BB Size 68mm.
Thanks in advance!
Ceramicspeed do mkes bb30 bb with 24mm spindle support.
Sent from my Redmi Note 3 using Tapatalk
- alexneumuller
- Contact:
Edited: No need to quote.
Looks great! How tall are you! I ordered a size 56, as I only need a top tube of around 560 with a 120mm stem, and I m 184cm, long legs short body!
Reason: photo in quote
