Post new topic Reply to topic  [ 55 posts ]
Go to page 1, 2, 3, 4  Next
PostPosted: Fri Jan 27, 2012 6:05 pm
Final design for the English. Should weigh around 13.5 lbs with pedals and saddle.
The head tube is long and there isn't much drop. Not much choice, as I can only handle a limited amount of drop due to a crushed disc in my neck that occurred a few years ago from hitting a pothole at 30 mph. One 10-mm spacer under the stem so I can lower my position if I regain more range of motion.
I don't have the exact tubing specs, but it's mostly 0.7-0.4-0.7 with an aero 0.6-0.3-0.6 downtube, which should be functionally equivalent in terms of stiffness and strength to standard round 0.7-0.4-0.7.
The trail is higher and the wheelbase longer than normal for one of Rob English's race bikes; I requested that he make the bike relatively stable--the majority of my miles and time on bikes are on rides 50-200+ miles in length, and I'm not going to be racing, so I want a bike that isn't going to be dangerous when I'm tired or doing a long ride in the cold. For example, a few weeks ago I took out the current "race" bike on an 80-mile ride in the cold and rain and almost shook myself off the road and over a cliff during a descent.
The bike will be fitted with 26 to 30 mm tires, and an array of ultralight components. I didn't go as light as possible with all the components, as some of our rides can be a little rough on equipment because we hit a lot of gravel and poorly maintained roads. I'm using a Clavicula compact M3 crank; Super Record derailleurs and shifters, eeBrakes; Alchemy hubs with Stan's rims, Dash saddle, Enve compact bar and stem "barstemmed" by Calfee. Scaupla matte fork (miraculously found a new one for cheap on E-Bay). Seatpost will have an internal expander. Also have a tubular wheelset for some 27 mm FMBs or Dugasts. The seat tube will have an integrated tail light since I ride in the dark a lot (there is a picture elsewhere in this set). Tires up to 32 mm fit under the Clavicula/eeBrake combination.
It will be black-on-black, and the only bit of vanity is a carbon fiber headtube insert. (see the English Cycles website for an example). Rob tells me that the CF insert will add stiffness to my overly long head tube, but I'm not sure the effect will be detectable.
Overall, it's not a randonneur and not a race bike, and it is not a good representative of Rob's usual designs. It's more of a dirt-road steep-climb long-ride bike.
Coming in March!
Riding the Catskills
 Post subject: Re: English
PostPosted: Sat Jan 28, 2012 1:14 am
Rob advised against using EE brakes on my English build. The internal cable routing simply didn't work well with those brakes. If you're going with external brake cable routing, or exiting from the top tube rather than the back of the seat mast (as I did) you should be OK though.
This looks like it will be a great bike. Enjoy!
TED ESSENFELD
Schoorl, Noord-Holland, Nederland
Bike Pics
English Custom Steel Internal di2
Litespeed Ghisallo
PostPosted: Sat Jan 28, 2012 2:53 am
Wow! Fantastic.
Sent from my ADR6300 using Tapatalk
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Jan 28, 2012 3:00 pm
Are you sure you're going to clear 27+mm tires? I barely squeeze 25c vittorrias through mine
PostPosted: Sat Jan 28, 2012 4:37 pm
Looking forward to this build...
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Sat Jan 28, 2012 5:07 pm
Isn't tire clearance a matter of chain stay design in the vicinity of the bottom bracket? Should be no problem to build for 30 mm. I definitely approve of the choice.
Fuji SL/1
PostPosted: Sun Jan 29, 2012 3:46 pm
Looking forward to more pics.
Tyre clearance should be a relatively minor issue as it's designed for that size from the outset. Plenty of 29ers with chain stays only slightly longer running huge rubber like a 2.4 Racing Ralph! I think that includes some English's so I'm sure it's no problem.
PostPosted: Sun Jan 29, 2012 4:27 pm
Here's a randonneur frame designed for large tire clearance w/ fenders:
It's a 650B bike, but you can see how by bowing out the chainstays a lot of room can be created.
In contrast, here's a Cannondale: relatively beefy chainstays come in relatively straight, minimizing clearance:
Fuji SL/1
PostPosted: Sun Jan 29, 2012 4:48 pm
There's no problem designing the bike for an appropriate amount of clearance in the rear. The bigger issue is the fork/front brake. A 30 mm tire will fit, albeit tightly, under the eeBrake/Scapula SP combination I am using. I expect that I'll mostly be riding 27 mm tubular except on really long rides where there is a risk for multiple flats.
PostPosted: Mon Jan 30, 2012 8:19 am
Sounds very promising indeed. I am intrigued by Rob's work and this one should not disappoint either.
Pls post pics as soon as you can.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
PostPosted: Sun Feb 05, 2012 9:34 pm
http://www.flickr.com/photos/36397392@N ... 055711825/" onclick="window.open(this.href);return false;
PostPosted: Sun Feb 05, 2012 9:44 pm
Damn this is going to be a sweet bike! Already looking forward to seeing the end result.
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Thu Feb 23, 2012 6:36 pm
More amateur photos here: http://www.flickr.com/photos/36397392@N ... hotostream" onclick="window.open(this.href);return false;
Rob is taking some nice photos next week.
PostPosted: Thu Feb 23, 2012 7:44 pm
Okay... so for one, I don't believe the CF insert does anything for stiffness. Even if the HT is perfectly stiff, the top and down tube can twist in response to moments applied at the head tube.
That said, it does look very cool! Very impressive....
Fuji SL/1
PostPosted: Thu Feb 23, 2012 7:51 pm
Yep, I agree it's not going to do much, but I do like the way it looks so what the heck? To be honest I'm not even concerned about ultimate stiffness. This bike is definitely not for races, instead it's intended for ultra distance (which for me means up to 600k).
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2, 3, 4  Next
Users browsing this forum: No registered users and 27 guests
There are no new unread posts for this topic. Enve 110mm stem & Enve 27.2mm layback post - both BNIB
BikeTart
Fri Apr 05, 2013 9:16 am
BikeTart View the latest post
There are no new unread posts for this topic. Enve 110mm stem & Enve 27.2mm layback post - new, boxed
BikeTart
Mon Apr 15, 2013 1:32 pm
There are no new unread posts for this topic. Rob English new TT rig.
Straff
7
1196
Wed Dec 19, 2012 7:44 pm
jipperd View the latest post
There are no new unread posts for this topic. English speaking TDF coverage in France
konky
Fri May 24, 2013 3:04 pm
russianbear View the latest post
There are no new unread posts for this topic. English bottom bracket history.
Juanmoretime
7
647
Mon Nov 19, 2012 5:42 am
elviento View the latest post
It is currently Thu Jun 20, 2013 10:54 am
