Fuchs Stevens - getting around 3,6kg
Fuchspk
by Fuchspk
FilmAt11
by FilmAt11
Fuchspk wrote:Do you think about the carbon-housing?
I didn't realize the housing was carbon - all clear now. Great work!
TimmS
by TimmS
Great work again!
Why don't you bind the stem and handlebar together as you can't take of the stem anyway?
Fuchspk
by Fuchspk
Yes i will do that. Just havn´t had the time for doing it. And it was even a little bit off that if i would brake the bar in an accident i could still use the stem.
Did not have done anything more to the bike but it works like normal. Started to use the flickr and as i never have shown some big pictures i´ll show this one. It is from before i changed the wires but otherwise it is the same bike.
_K__6199 by philipp.klement, on Flickr
Elrey
by Elrey
Still love this bike!! :beerchug:
SWijland
by SWijland
+1
Krull
by Krull
perfect. i think i have to get repainted my slc team.
sorry vor mai bed englisch!
bm0p700f
by bm0p700f
where is the rear shifter?
jooo
by jooo
@bm0p700f
Fuchspk
by Fuchspk
Yes it is on the side of the left downtube near the headtube - a bit longer up then normal so that i do not have to reach down as far as normal and can not get my fingers in the frontwheel.
The good thing with having it on the left side is that i still have quite good control by holding the bar when shifting and can brake softly which i never could with having it on the other side.
Here in the link you can see it a bit better http://www.flickr.com/photos/111426698@ ... 620913515/
same picture as this one but much bigger
_K__5498 by philipp.klement, on Flickr
Fuchspk
by Fuchspk
One of the last rounds today for this year as there still is now snow at my place.
Merry Christmas to you all!
_K__5067 by philipp.klement, on Flickr
_K__5092 by philipp.klement, on Flickr
_K__5072 by philipp.klement, on Flickr
TimmS
by TimmS
+1 for the cable routing!
Did you have much trouble to get the cable through?
Fuchspk
by Fuchspk
No actually not. I have an liner in the frame. And for the liner i just removed the fork and then put the liner in from the rear of the frame and could fetch it easy in the headtube.
Fuchspk
by Fuchspk
Updated the Partlist
- Stevens SLC Team Frame (`56 - 2009 - striped from paint and changed a bit) + NLB Seat and Seatpost (integrated in the Frame) + Fuchs Chainguard = 904g
- Ritchey WCS Carbon Fork (stripped from paint - 194mm Steerer - parts of the Headset glued in place) = 252g
- FSA Headset (rebuild - Coparni Aheadcap) = 52g
- Coparni Prototype Stem (-8degree - 100mm) = 64g
- Schmolke TLO Bar (400mm - Ergo - 144g) + Fuchs Brakelevers (70g - "one piece" with the Bar) = 214g
- BTP Shifter (tuned - nylon parts) = 3g
- Velox Tressorex Cotton Bartape (just from the Levers to the stem - sewn in place) = 16g
- Zipp 300 Cranks (stripped from paint - 172,5mm) = 296g
- XX-Light Bottom Bracket (tuned - 108mm) = 118g
- Fiberlyte Chainring (tuned - Style2 - 53-130 - Singel) = 51g
- Zipp Chainring Bolts + Fuchs Carbonspacer = 9g
- Ultralite Cirrus Ti Pedals = 71g
- PYC 11 Chain (108 Glieder) = 212g
- Nino Titan Cassette (11-20 10x - tuned with other Nino TItansprockets + Fuchs Carbonsprocket + Carbonspacer - Aluminium Screw) = 93g
- Lightweight Ventoux Frontwheel = 439g
- Lightweight Ventoux Backwheel (tuned with DT190 parts) = 588g
- Tune Skewers + Fuchs Carbonspacer = 17g
- Tufo < 195 = 388G
- Fuchs Rear Derailleur (mixed with Fuchs-parts and tuned Tiso parts + Extralite Pulleys) = 85g
- AX Orion Brakes + Fuchs Brakeshoes + Fuchs Pads + Fuchs tuningsparts for the Brakes = 97g
- Fuchs Carbon + I-Link + Power Cordz = 61g
- Fuchs Bottlecages + Alu Screws = 8g (2 times in Summer and on longer Distances)
- Extras (Glue - Air - Rounding - Misstakes) = ca 29g
Complete Weight = 4067g
dogg
by dogg
wow very cool bike you've got! fantastic modifications and home made parts.
do you have any more information on how you attached the shifter to the frame?
