Post new topic Reply to topic  [ 294 posts ]
Go to page Previous  1 ... 16, 17, 18, 19, 20
 Post subject: Re: Gum's CRUMPTON UL
PostPosted: Mon Apr 23, 2012 2:55 pm
tranzformer wrote:
Crumpton's pricing in a while but assume this frameset is what ~$6500?
no, considerably less.
www.crumptoncycles.com
PostPosted: Mon Apr 23, 2012 3:44 pm
Yah I didn't want to get into pricing, because I don't know if Nick set a final price for the isogrid frames, but I paid much less than $6500.
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Mon Apr 23, 2012 4:39 pm
Care to share pricing on a custom isogrid framset (frame/fork/headset) or when you might put it on your website? I looked and saw the SL Road starts at $5500. I assumed with the new isogrid it would start around $6000 plus a few hundred for the extras. But if it is a lot less than this, that would be great. :thumbup:
"Sacred to the god Aesculapius"
 Post subject: Gum's CRUMPTON UL
PostPosted: Sat May 05, 2012 9:55 pm
I decided to go back to the aerolite pedals. I switched to the road version though. I originally had the tt version and the q factor was too narrow for me. I was constantly rubbing my shoe against the crank arm. The new Aerolites weigh 74g, which is a tad heavier than the tt version, but they work much better for me. I saved 111g with the switch. I also cut off that piece from the rear derailleur mech plate. New weight is 4.40kg or 9.70lbs. I need to shave another 323g to get down to the 8lb range using pretty standard road components. ;)
PostPosted: Sun May 06, 2012 2:24 am
did you cover why you ditched the morpheus cranks?
Speedplay is the devil.
PostPosted: Sun May 06, 2012 2:36 pm
I ditched the Morpheus because the ones I had installed where actually a 'bad' pair so I sent them back to AX. Honestly I didn't think they'd replace them for me (or it would take months)so I purchased the Clavicula, which is a little lighter. AX gave me a brand new set of cranks and I had them back 2 weeks later. The Clavicula was already installed so I just stuck with those.
PostPosted: Sat May 26, 2012 10:12 pm
A custom build AX24 wheelset as seen in previous post viewtopic.php?f=3&t=97206 at 773g saving -158g plus swapping your rubber out at a saving of -250g would take you under the 4kg mark. Fantastic. :D
PostPosted: Sat May 26, 2012 10:19 pm
Ask4 wrote:
A custom build AX24 wheelset as seen in previous post viewtopic.php?f=3&t=97206 at 773g saving -158g plus swapping your tyres out at a saving of -250g would take you under the 4kg mark. Fantastic. :D
PostPosted: Sat Jun 23, 2012 5:45 am
Gum, a coupe of months after you build this dream machine, are you enjoying using it as an everyday bike?
more specifically Im now interested on your thoughts regarding your choice for the cableset and durability of these veloflex extremes... were these two worthy weight savings?
and have you any plans for bringing under 9lbs in the future?
Tks!
Post new topic Reply to topic  [ 294 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20
Users browsing this forum: LittleSprinter and 19 guests
There are no new unread posts for this topic. Crumpton SL - 54.8cm tt x 53 st
tonytourist
Tue Apr 16, 2013 4:25 pm
tonytourist View the latest post
There are no new unread posts for this topic. Crumpton T5
jcumpstay
Tue Apr 23, 2013 7:40 am
BeeBee30 View the latest post
There are no new unread posts for this topic. Attachment(s) Crumpton Corsa M
scb
15
1829
Thu Aug 23, 2012 3:35 am
grid256 View the latest post
There are no new unread posts for this topic. Incoming Crumpton SL
[ Go to page: 1, 2, 3, 4, 5 ]
LionelB
71
5852
Wed Sep 12, 2012 12:02 pm
LionelB View the latest post
There are no new unread posts for this topic. Crumpton SL Build
3delis
24
3137
Sun Nov 04, 2012 7:28 pm
konky View the latest post
It is currently Tue May 21, 2013 11:39 pm
