Post new topic Reply to topic  [ 294 posts ]
Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20  Next
 Post subject: Gum's CRUMPTON UL
PostPosted: Fri Apr 06, 2012 9:46 pm
My prototype test combo came in the mail today from Berk. 120g for the speedneedle shape (angled a slightly more level front to back) and 350mm. Really impressive work Berk! Beautiful weave.
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
 Post subject: Re: Gum's CRUMPTON UL
PostPosted: Sat Apr 07, 2012 2:06 pm
That is a fab weight for a combo. Makes it worth the loss in flexibility.
PostPosted: Sat Apr 07, 2012 3:46 pm
I've had several Berk combos and each one that I get is more refined and nicer. Jure's really honing his skills. It's fun to watch.
PostPosted: Sat Apr 07, 2012 4:25 pm
Gum,
do something to the spacer or remove it,thats lots of weight there :mrgreen:
Parlee Z3sl - 5 kg
Passoni Xxti- 6.2 kg
PostPosted: Sat Apr 07, 2012 4:28 pm
wshiong wrote:
Gum,
What spacer?
PostPosted: Sat Apr 07, 2012 4:30 pm
the spacer below your stem :|
Parlee Z3sl - 5 kg
Clavicula is here and it's significantly lighter (in WW terms) than the Morpheus. I think I'll be going with the Clavicula ;)
PostPosted: Sat Apr 07, 2012 4:32 pm
Any plan to sand the clavicula ?
Parlee Z3sl - 5 kg
PostPosted: Sat Apr 07, 2012 5:08 pm
What chainrings will you be using, and what do they weigh?
PostPosted: Sat Apr 07, 2012 5:16 pm
The Clavicular will be stiffer and is beautiful.
What possible advantage could the Morpheus have? I thought it was lighter. If not surely it's a no brainer.
PostPosted: Sat Apr 07, 2012 5:49 pm
That's the setup for the NAHBS. That's not how I'll be using it. I'll be doing either 5 or 10mm. This Setup is 40mm. The spacers are made from DELRIN and are extremely light. Lighter than carbon ones. I just want to be certain before I cut the fork.
The rings are fibre-lyte. 78g total weight
I have to look at the crank some more with the bike and see how it looks. I may sand them. Not sure though.
PostPosted: Sun Apr 08, 2012 12:16 am
The cranks might be too nice to sand. THM really did a nice job in designing this crank. Has anyone sanded the Clavicula and has pics to show what it would look like? I'm assuming sanding it would take off all of the lettering.
PostPosted: Sun Apr 08, 2012 12:58 am
DON'T SAND IT!
They produce a matte finish one for that effect.
PostPosted: Sun Apr 08, 2012 4:02 am
Sand it.
In fact, TUNE IT. :twisted:
Donald tuned his Claviculas to make them lighter, you can too. :wink:
Exp001
PostPosted: Sun Apr 08, 2012 4:04 am
I used steel wool on two sets, they came out great. I avtuslly like the sanded ones better than factory matte. The shiny clearcoat is better quality. The reason Parlee do their matte (not waxed) finish like this.
Technical Artisans
Post new topic Reply to topic  [ 294 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20  Next
Users browsing this forum: Exabot [Bot], Rogue and 22 guests
There are no new unread posts for this topic. Crumpton SL - 54.8cm tt x 53 st
tonytourist
Tue Apr 16, 2013 4:25 pm
tonytourist View the latest post
There are no new unread posts for this topic. Crumpton T5
jcumpstay
Tue Apr 23, 2013 7:40 am
BeeBee30 View the latest post
There are no new unread posts for this topic. Attachment(s) Crumpton Corsa M
scb
15
1829
Thu Aug 23, 2012 3:35 am
grid256 View the latest post
There are no new unread posts for this topic. Incoming Crumpton SL
[ Go to page: 1, 2, 3, 4, 5 ]
LionelB
71
5855
Wed Sep 12, 2012 12:02 pm
LionelB View the latest post
There are no new unread posts for this topic. Crumpton SL Build
3delis
24
3144
Sun Nov 04, 2012 7:28 pm
konky View the latest post
It is currently Wed May 22, 2013 6:36 pm
