Let's See Your Time Trial bike
Moderators: maxim809, Moderator Team
- shoopdawoop
The shiv TT is consistently the best looking TT bike! I love every build, I most certainly would have picked it if the xs size wasnt so hard to find and so damn expensive haha.
I am working on a little update for my BMC, finally applying some of the things I learned in college. Took some inspiration from Berk and decided to produce a one piece handlebar/fork (akin to Cuddles and TJs TM01 front ends) using carbon fiber. Wanted to reduce the stack and reach abit and the lightness aint bad either
First layup done! Its 7 layers and now I've got some clean up and smoothing with the dremel as well as some cable routing. Then another 4-5 layers and more cleanup and clear coating. So far the reinforcement/bar and fork junction weigh 16g.
very interested to see how the TM01 fork/bar integration turns out
- Tinea Pedis
- Contact:
Argon18 e-118 Next.
Right now it is as 6540g (14.42 lbs.) but of course is missing the I-Link housings and cables as well as the chain. So It will come in under 7000g (15.43 lbs.) which I can live with. I will also have a Catalyst carbon disc cover going on but that should only add about 150g so I will have a very nice sub 16 lbs tri bike for next year.
I am now thinking that I will have the post, cranks, aerobars and extensions maybe painted the Satin black as well.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
Just picked up my first tt bike (other than track pursuit bike)! Fit is pretty close, need to shorten the extensions a bit
Orbea Ordu M30 Ultegra 6800. 8.87kg as pictured w/ training wheels, pedals and cage
TT's round here are either too windy or too hilly for a disc. One day I'll cut the steerer when I decide how low I can go.
Wheels from Dengfu. Garmin Mount made of PVC pipe taped between the bars, rest is 10speed Low end Campag with Centaur brakes & FSA chainset running 54-42.
Only addition is that I'm hunting for a cheap 11-23
[Apologises for the crap photo]
Tomorrow is "Icebreaker Time Trial"
edit: Almost forgot weight. 8.16 kg / 18.00 lbs, kinda porky
- miltmaster3
