It is currently Wed Jan 24, 2018 8:52 am
Post new topic  Reply to topic  [ 89 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Tue Jan 10, 2012 1:48 pm
I often deliver babies that weigh more than your bike. Ridiculous.
PostPosted: Tue Jan 10, 2012 2:07 pm
You have to Dremel the babies if you want them to weigh less.
PostPosted: Tue Jan 10, 2012 2:08 pm
hahaha :)
:arrow: my 36XXg Stevens
:arrow: my Litespeed
PostPosted: Tue Jan 10, 2012 2:32 pm
Well, with my baby, you'd have to take off 2 lbs. That is more than a Dremel job! Amazing.
PostPosted: Tue Jan 10, 2012 5:37 pm
I can easily get my bike donw to 3,6kg! I just have to cut it in half :mrgreen:
PostPosted: Tue Jan 10, 2012 6:01 pm
Its a fantastic bike and amazing weight . You have my admiration sir. But can i ask about the stem and if you have ever thought of changing your stem for a less erect look ?
PostPosted: Tue Jan 10, 2012 6:17 pm
donald wrote:
The cables I'm using are Power cords for the derailleurs and front brake, a very thin steel cable for the rear brake. I could have a lighter fork, and 4 years ago I did have a THM on it that Rue let me use for about 6 months. I just really like the Edge fork. I am a weightweenie because I even sand the chain ring bolts, I think I save 1 1/2 grams. The little holes in the cassette are made a little bigger and it is also sanded as far as I could go, and still work. I say this about the chain ring bolts and cassette lock ring to give you an example of how just about every part on the bike that can have some material removed, I have done it. And so doing this just about everywhere really helps to get the weight down.
I appreciate your work a lot but removing material from a Extralite stem or any superlight part without having FEA results or any hard data to know where it's safe to remove material, it's a real risk. We are not talking about a 200gr DH stem, it's a 78gr stem
http://cds-0.blogspot.com
PostPosted: Tue Jan 10, 2012 6:59 pm
Epic-O, I understand your concern about my stem. We all know about many parts that have failed, both modified and stock. And of course, the less material with anything the more likely it could fail. I really did not remove very much material from this stem, and much of it was sanding the sides of the shaft and a little here and there at various places on it. I removed a total of about 6 grams. A stem is a critical area of the bike, if it fails a crash is very likely. I never want to crash, but with what I have done, and my experience modifying parts I feel totally confident with this stem.
PostPosted: Wed Jan 11, 2012 2:16 am
donald do you have more pictures of the rim drilling that you've done? I think I remember reading that you drill out the inner wall so the rims are almost like a single wall? Do you use a few large holes or lots of small holes about the size of the existing inner spoke holes?
Have you done any to the outer walls other than re-drilling them for whatever spoke count that you'd like to use?
PostPosted: Wed Jan 11, 2012 3:33 am
Jooo, I don't have pictures of my rim modifications. I have talked a little about it in past posts. I no longer drill the inner upper wall, only holes where the spoke nipples go in. I just remove material by sanding the side walls a little, drilling different size holes between where the spoke holes are, depending how light I want to go, and also using a dremel sanding cylinder to remove various amounts of material near these holes, and a little above. I don't remove material where the spoke holes are. And again, I have been using these rims for over 20 years and have had very few problems. My wife always wonders why I spend so much time making my bikes light.
PostPosted: Wed Jan 11, 2012 11:57 am
Thanks donald, I'm thinking of giving it a try myself - I think I may have even asked you about it at some stage before.
I've seen lots of pics of others doing it, but the majority have been on very wide single wall snow/trials rims so it's a bit different than normal road/MTB rims.
PostPosted: Wed Jan 11, 2012 9:19 pm
Hi Donald
I think how you can save few grams:) First you can do is to sand the seatpost and saddle.
Another option for very light project bike is to change gearing for 1x1 (singlespeed)
Best
PostPosted: Sat Jan 21, 2012 12:38 am
Every time i think about that seatpost, with no clamp. I really hope the roads stay true for you. It's such a fantasic bike. I just hope you have not gone beyond the limits of your own safety for the sake of a gram or two.
PostPosted: Sun Jan 22, 2012 12:50 am
Artray, I have talked about this in the past. I have used this post, without a clamp for two years now. There is a very small bolt, 1/2 of a gram, in the front seat tube and goes into the post. This prevents the post from turning. The post fits very tight into the seat tube but I also have a little build up of clear coat right where the post stops at the seat tube. I also use this same set up on my other bike. I have never had a problem, even on the very bad roads in the Bay area.
PostPosted: Tue Mar 20, 2012 7:46 pm
Now 7.82 lbs., 3,550 grams with the new stem and seat post. The frame is now 5 years old, with over 4 1/2 years of riding. 5 years ago it started out at 8.4 lbs., in that time I have only taken off .6 lbs., not really much at all. Oh well, I better get back in my shop right now and start working -- just kidding.
There are no new unread posts for this topic. Attachment(s) Update: Rue Uberlight now 3,248 grams ( 7.15 lbs. )
donald
24
3087
Sun Oct 01, 2017 1:34 am
donald View the latest post
There are no new unread posts for this topic. Looking for compact aluminum handlebar under ~260 grams
mpulsiv
21
2393
Thu Feb 02, 2017 11:14 pm
DutchMountains View the latest post
There are no new unread posts for this topic. So Dogma F10 shaved a few grams and now flexes...
ninjasloth
13
2293
Mon Jun 05, 2017 4:01 am
Seedster View the latest post
There are no new unread posts for this topic. Attachment(s) Aluminium frame + Dremel = How many grams lost?
SABARRAS
23
3538
Wed Feb 01, 2017 4:42 pm
darnellrm View the latest post
There are no new unread posts for this topic. Cannondale Hollowgram SL Crank, New Spiderring, 536 grams. $350
VTBike
Tue Jan 16, 2018 12:08 am
VTBike View the latest post
Users browsing this forum: genesis692, Google [Bot] and 11 guests
