Post new topic Reply to topic  [ 79 posts ]
Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Nov 18, 2011 12:47 am
Finally I am under 8 lbs. The pictures are with my Becker saddle, which has a weight of 7.95 lbs. The 7.89 is with my Dash saddle, which is the one I have been using the most. If you remember, the frame is 4 1/2 years old. A custom, 54 cm. Zen Uberlight, 86 mm. BB shell with pressed in ceramic bearings, 610 grams with F. & R. derailleur hangers and down tube bosses installed. What brought the weight down is the new Eclipse inner tubes. They are a little heavier than 29 grams, 30 and 31 grams. I have had two good rides with them and I really like them. They don't lose air like a latex tube and are supposed to have lower rolling resistance. Fork: Edge 1.0, 243 grams; Stem: Extralite UL3, 110 mm. modified, 78.5 grams. Bar. Schmolke TLO, 44 cm. Levers: Campy carbon, modified, including al. nut & bolt carbon clamp. 117 grams. F. der. Campy Record, modified, including Ti. spring. 46.5 grams. R. der. Shimano Dura Ace 8-spd. modified, 108 grams. Crankset: THM Calvicula, modified, 172.5, 373 grams. Chainrings: Fibre-lyte, 53 & 38, 64 grams. Pedals: Aerolite Ti.,65 grams. Brakes: AX Orien, modified, 98 grams the pair with all hardware carbon holders, cork pads. Seatpost: Performance, modified, Carbon craddle and clamp, al. bolt, 295 mm. 84.5 grams. Chain: Yaban Ti. 208 grams. Headset: KCNC Morien, 28 grams. Cassette: Tiso, modified, 12 & 13 cogs are carbon, Its a 12-21 8-spd. All cable housing is Tune plastic. I made the front rim a little heavier, now it is 225 grams. F. wheel, is a 27 gram Dash hub, 16 Pillar Ti. spokes, Fred Johnson Mag clincher rim. R. is 237 gram Mag rim, 93 gram Dash hub, Pillar Ti. spokes. Tires are Velo Flex Record, 125 grams each. The bike has index shifting. All other weights for things like skewers, cables, bar tape, etc. are on my other posts.
PostPosted: Fri Nov 18, 2011 1:01 am
I forgot to list the cassette weight, it is 62 grams. Also the total weight for the front wheel is 309 grams, The rear is 407 grams, and yes, they are clinchers. I have been using Fred Johnson mag rims for over 20 years, never had any serious problems, main problem was little cracks at the spoke holes, mainly from high tension.
PostPosted: Fri Nov 18, 2011 1:20 am
Online
This is a truly incredible bike. Glad to see it's under 8lb now! I am most impressed by the wheels, clincher as well! They must be incredible to ride. I may be in the minority too, but I think it's aesthetically fantastic - looks brilliant and has a certain cutting edge look about it. Thanks for sharing!
PostPosted: Fri Nov 18, 2011 1:21 am
Wow!
PostPosted: Fri Nov 18, 2011 3:33 am
So, would a second water bottle cage and bar end plugs put the weight back over 8lb?
PostPosted: Fri Nov 18, 2011 4:36 am
WoW. How much do you weigh if you don't mind me asking? What would the rider weight limit be on the complete bicycle?
The more I ride, the less I spend
PostPosted: Fri Nov 18, 2011 4:47 am
It has bar end plugs. I made them myself. They are carbon, I think they are 3 grams the pair. I weigh 140 lbs, just a hair under 5' 10 ". I'm not sure about a weight limit on the frame. At the time I told Rue that I wanted the absolute lightest frame possible. He said my frame was as stiff as a Trek 5500 frame, and I also observed him banging tubes against a table very hard, without cracking. I would think someone around 185 lbs. could ride it without a problem. Right now only my seatpost would perhaps be a problem for anyone over 160 lbs., especially on bad roads.
PostPosted: Fri Nov 18, 2011 9:15 am
WOW incredible weight!
What seatpost is it?
PostPosted: Fri Nov 18, 2011 11:21 am
Applause! How does it feel to ride such a light bike? Does it feel fragile at all?
WTB: MTB hubs, 29'er carbon rims
My 7.3kg/6.4 kg 29'er project buildthread!
My Bianchi Oltre XR
PostPosted: Fri Nov 18, 2011 12:39 pm
The saddle points down somewhat, and the chain looks to be on the short side.
PostPosted: Fri Nov 18, 2011 5:16 pm
Nice job.. WW is not dead.
PostPosted: Fri Nov 18, 2011 6:03 pm
:shock: That is the most astonishing build I have ever seen, simply incredible! Well done indeed!
PostPosted: Fri Nov 18, 2011 6:11 pm
I love it. Really nice attention to the detail
BIKE DESIGN AND +
http://cds-0.blogspot.com/
PostPosted: Fri Nov 18, 2011 6:21 pm
Fantastic work Donald, thank you.
Exp001
PostPosted: Fri Nov 18, 2011 6:23 pm
That is one seriously ugly bike. I LOVE IT!
TED ESSENFELD
Schoorl, Noord-Holland, Nederland
Bike Pics
English Custom Steel Internal di2
Litespeed Ghisallo
Post new topic Reply to topic  [ 79 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Users browsing this forum: CSKeller, Esterhas, Google [Bot], Rippin, spOOn1965, t0ph0id and 31 guests
There are no new unread posts for this topic. Attachment(s) 2012 Canyon Aeroad CF Di2 - 6.250 grams (new pics - page 7)
[ Go to page: 1 ... 5, 6, 7 ]
Juggler
97
18455
Sun Mar 24, 2013 10:27 pm
Martin.F View the latest post
There are no new unread posts for this topic. Attachment(s) Scott 3 - update- new pics on latest post
mdeth1313
Sat Jul 07, 2012 1:04 am
mdeth1313 View the latest post
There are no new unread posts for this topic. Attachment(s) BMC SLR01 Project --> [Update & link to NEW Pics on PP 2]
vlastrada
22
3037
Wed May 08, 2013 3:53 pm
bally81 View the latest post
There are no new unread posts for this topic. Attachment(s) Update - pics - look what I found! FD cable shock!
blakemulder
Thu Jan 03, 2013 4:36 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Lapierre Xelius FDJ Build (Update 10.01 - Finished w/ PICS)
xjbaylor
26
5077
Tue Oct 30, 2012 1:27 pm
xjbaylor View the latest post
It is currently Sun May 19, 2013 7:03 pm
