HOME Listings Blog NEW Galleries NEW FAQ Contact About
It is currently Mon May 30, 2016 9:59 am
Recently the board software has been updated and there are some known bugs/failures:
- Avatars are currently not being displayed ✔ FIXED
- Tapatalk connection is currently broken ✔ FIXED
If you find more errors please post it here: http://weightweenies.starbike.com/forum/viewtopic.php?f=7&t=139062
Post new topic  Reply to topic  [ 64 posts ]  Go to page 1 2 3 4 5 Next
PostPosted: Sat Nov 05, 2011 11:10 pm
Another big frame is on the way. With any luck I'll get it in December. I have most of the components already. Some I will be moving over from my CAAD 10 like the wheels, pedals and brakes. Just a couple more things to order up! I am planning on stripping all of the carbon bits of their stock paint and seeing how things look with a nude finish. CarboLift is taking forever to show up. I am debating whether or not to trade the 3T Team stem for their LTD stem. Other than that I think I am set on everything else.
Arundel Mandibles in matte oil slick finish
K-Edge Chain Catcher - a must for carbon frames
Sram Press-Fit 30 Ceramic bottom bracket
Sram Red Black steel cage front derailleur
Sram Red Black rear derailleur
Sram Red shift/brake levers
Derailleur and brake cables supplied with shifters
Front
Rear
3T Team 110mm stem
3T Dorico LTD seatpost
Easton EC90 SLX 3 46cm handlebar
Cannondale CAAD 10 63cm || Cannondale Flash Carbon 29er || Cannondale Evo 63cm
 Post subject: Re: Another Big Bike
PostPosted: Wed Jan 04, 2012 6:01 pm
Just picked this up for my new ride: KMC X10SL DLC black chain. This is the most over-the-top packaging for a chain I've ever seen. The chain came with 115 links and the connector links so take that into account for the weight.
PostPosted: Wed Jan 04, 2012 9:12 pm
Very nice component choices. I'm subscribed :)
:beerchug:
PostPosted: Fri Jan 13, 2012 5:33 am
The frame is here after so much waiting; a 63cm Cannondale SuperSix Evo. The weight of the frame does not include the following:
- press-fit bottom bracket = 80g
- cable guide = 5g
- derailleur hanger = 9g
- seatpost collar = 15g
- water bottle cage bolts x4 = 6g
The only things left on the frame are the thin nylon string running through the internal rear brake routing and the small metal chainstay/bottom bracket protector. I can't imagine the string weighing more than 5 grams. I will weight it when I have the frame built up so that I can get a more accurate frame weight. Anyone have any ideas on the metal protector? Can it be removed? Can it be put back on after removal?
Once I get a few more pictures I will begin to Carbo Lift the frame and fork. I am very interested to see how much the paint weighs.
PostPosted: Fri Jan 13, 2012 8:57 am
I think you should leave the paint alone fastrow. I love the graphics on your frame. Paint removal will result in 35g to 50g reduction in weight.
56cm PR00 Colnago Extreme Power
PostPosted: Fri Jan 13, 2012 11:26 am
I like your build - but I agree - leave the paint (it looks cool) :mrgreen:
PostPosted: Fri Jan 13, 2012 6:32 pm
Are you keeping your caad10?
I say proceed with the carbolift :thumbup:
PostPosted: Fri Jan 13, 2012 7:48 pm
Stealth all the way for me too! That's a deeply impressive weight for the size. Bravo.
Too old to be fast, too young to be this slow!
PostPosted: Fri Jan 13, 2012 8:08 pm
A very impressive weight that is!!
Looking forward to this build! In color or all black, I dont care.
TREK Madone 5.9 SL
COLNAGO C50 nl12
PostPosted: Fri Jan 13, 2012 10:25 pm
You must be crazy to lift the paint on such a great looking bike. At least ride it for a while in its painted state.
Colnago C59
Canyon CF 9.0
PostPosted: Fri Jan 13, 2012 11:46 pm
Thats one big frame, but great weight for a 63cm.. I have to echo the earlier sentiments of keeping the paint. Hard to strip away such a good looking paintjob.
If you do strip away the paint are you planning on putting any paint back on it?
This is my no name bike
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=81279
-caseycycling
PostPosted: Sat Jan 14, 2012 12:21 am
Thanks for all the compliments! I am definitely keeping my CAAD 10. I don't foresee ever selling that bike. My initial plan was to strip the Evo frame and either see how it looked nude or strip it and paint it matte black. Now that I have the frame in-hand I find myself rethinking the plan. I don't think I am going to strip it just yet. The white paint scheme does look great. What I am thinking of doing is riding it as is for a while and putting it through its paces. Once it takes a beating and looks worn I will strip it and paint it something special.
I also rethought myself becasue I realized I would have two identical bikes. The CAAD 10 and Evo have the same geometry, tube shapes, and would both be matte black. I don't want that. I want this Evo to be something different. As I said, I will ride the Evo as is and think of a great paint scheme for the future.
Stay tuned for the build. I am just waiting on the last few components to show up. I still need the crank, saddle, and bars. The crank will be a Hollowgram. I decided not to go with the Easton bars so I'm looking at other options. The saddle I want is out of stock for a while so I will most likely use one that I have sitting around. That way I can actually get out and ride then replace the saddle when the new one arrives.
PostPosted: Sat Jan 14, 2012 8:08 am
great looking bike,
almost like mine :thumbup:
EVO 63cm
viewtopic.php?f=10&t=92143" onclick="window.open(this.href);return false;
PostPosted: Sat Jan 14, 2012 8:11 am
How about some Zipp short & shallow SLs or Contours for bars? The finish quality is top notch.
PostPosted: Sat Jan 14, 2012 8:16 am
Ahh..I forgot you have that 3T stem, so maybe some Ergonova Pros or the ErgoTeam Stealth Edition would be nice.
There are no new unread posts for this topic. Attachment(s) My Scott Foil DI2 project (final build on page 2)
muntos
23
4101
Sun Mar 20, 2016 5:42 pm
muntos View the latest post
There are no new unread posts for this topic. Attachment(s) Madone 9 Custom Build (More Photos)
da123
Sat Apr 16, 2016 8:02 pm
da123 View the latest post
There are no new unread posts for this topic. Cannondale Supersix Evo Hi Mod build - suggestions please
island
36
2492
Thu May 26, 2016 6:59 pm
VTR1000SP2 View the latest post
There are no new unread posts for this topic. Cannondale Trail SL 3 2010 - Budget Build
in MTB
jmacbrid
Fri Mar 18, 2016 5:03 am
jmacbrid View the latest post
There are no new unread posts for this topic. Price drop - Cannondale FSi $4,800 Team Custom build
gfeldy
Mon Mar 21, 2016 4:58 pm
gfeldy View the latest post
Users browsing this forum: Ulver, Yahoo [Bot] and 13 guests
