Post new topic Reply to topic  [ 56 posts ]
Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Aug 02, 2011 1:55 pm
Ride comparison please!!
PostPosted: Tue Aug 02, 2011 2:45 pm
Willl let you know on the ride comparison. I guess one will be brilliant and the other fantastic, but I guess I'll need to try harder than that!
Hyperons ordered and on their way, so no more Zipps to spoil the view!
PostPosted: Tue Aug 02, 2011 4:11 pm
It does not sound like we are heading for an unbiased review here :lol:
PostPosted: Sat Aug 06, 2011 6:26 pm
So.....ride report time.
Those expecting a biased report should prepare to eat their words. The Responsorium is more expensive, higher spec'd and yet I prefer the Duende!
The Duende feels like a modern take on a very, very good old school steel bike. Stiff through the bottom bracket, tracks beautifully, but really comfortable and forgiving. The Responsorium rides like a modern carbon bike. Stiff everywhere, no loss of power, sharp response (could be quite aptly named!).
If you are after that 'steel' feel, the Responsorium is not the bike for you. It is a real criterium weapon, and a very competitive race bike. I live in central London and have to get out of London over some pretty awful roads to get anywhere near smooth tarmac. I arrived absolutely beaten up after what was meant to be quite a leisurely ride.
There are 3 main differences between the 2 bikes, and I can't yet tell to what extent each are responsible for the ride characteristics differences:
1) Stainless Steel frame with oversized chainstays (Responsorium) vs Nivacrom with standard chainstays (Duende)
2) Carbon forks (Responsorium) vs Steel forks (Duende)
3) Deep section carbon wheels (Responsorium) vs Shallow section aluminium rims (Duende)
I had Zipp 404s on the Duende previously and it still rode smoothly, so I can confidently rule out the wheels, although I have a set of Hyperons to try on the Responsorium to see how this changes the ride.
I had carbon forks on the Duende before and the steel forks are definitely more comfortable, but are perhaps only 30% of the difference. They were the same Mizuno carbon forks that are on the Responsorium, so the comparison is apples-for-apples.
So, that only leaves the frame itself. The tubing, diameters and build make all the difference. Dario has built a beautiful race bike, and and one that deserves to be raced. It would definitely hold its own with any oversized modern carbon bike that I have ridden. The rear end is built for stiffness, responsiveness (that word again!) and large chainstays and seatstays and huge dropouts make a massive impact.
Ultimately, it is horses for courses. On a relaxing Sunday morning ride, or just a recovery or gentle ride, the Duende wins hands down. More forgiving, more 'steel', heavier but an all round pleasurable experience. The Responsorium will only come out of the bike shed when I want something purposeful, sharp and aggressive for those eyeballs out rides.
I had a similar experience a few years back with my Sevens. I had a double butted Axiom. Best bike I have ever ridden and very similar to the Duende. I then bought a triple butted, super light Aerios which was stiff, unforgiving and not as pleasurable to ride. Seems that history has repeated itself.
Light weight, it would appear is nothing without comfort. Possibly not a popular view on here, but the slightly heavier, slightly more forgiving Duende just feel more planted and tracks the road better without bouncing over every slight undulation.
PostPosted: Sat Aug 06, 2011 10:09 pm
solarider, i hope the the ride quality can be made more to your liking by something simple like experimenting with different tyre pressures :shock:
i used to run 7 bar on my conti tubs which is probably the minimum, but any higher and i found comfort and poise reduced accordingly.
cannondale flash3 alloy 29er
trek 5200 nude carbon
pegoretti marcelo
PostPosted: Sun Aug 07, 2011 10:03 am
Might try that. I was running 120 PSI which isn't excessive.
I have some fairly constant base points for comparison (wheels, forks and components), so I am fairly convinced this is just a super stiff, super fast built frame.
Having read the previous post it does sound like I am not happy, but actually I am. The bike does exactly what it is meant to, but I guess I am surprised at how 'modern' a steel bike can feel. It can really hold it's own against any over-sized carbon frame.
PostPosted: Mon Aug 08, 2011 12:34 pm
Amazing... :shock:
I love the paintjobs on these. Things of beauty.
Tester for PMR@cing / www.Biketart.com
PostPosted: Mon Aug 08, 2011 1:23 pm
it looks like the overall setup of the respo with wheels and fork is still where the big difference is coming from... This said 120psi on 404 gives a prettuy tough ride IMO.
I believe the Hyperon will smooth things out, try them with 100psi max. As for the carbon fork I think it contributes quite a bit to front end stiffness.
In some ways it is good that the two bikes behave differently but I hear you on the Duende.
If you have to keep only one which one would it be?
PostPosted: Mon Aug 08, 2011 4:49 pm
Difficult question that one, but honestly I think the Duende.
100PSI is not much in tubulars, but i'll give it a go and let you know. The Hyperons have arrived today, but might not have the chance to ride them until the weekend.
PostPosted: Mon Aug 08, 2011 5:07 pm
I put 90 to 100 psi in my veoflex roubaix all the time and I weight 84kg...
Or give it a try with the Nemesis, they are one of the most comfortable rim out there.
Two of my main steel bikes are a XCr Carl Strong (TIG) and a Sachs (lugged). The Strong has an Edge 2.0 carbon fork and the Sachs, well of course a Sachs steel fork. So I think I understand what you mean.... I also have a set of Nemesis wheels and a bunch of carbon ones. If I had to keep only one bike (out of all my bikes not just the steel ones) it would be without a doubt the Sachs. But hey, I am going to get a Marcelo so it may change that, who knows...
PostPosted: Mon Aug 08, 2011 10:58 pm
Agree with Lionel about tyre pressure. I never put more than 100psi in tubs. Have tried it at 120 myself and the ride was fidgety and pretty unforgiving.
PostPosted: Tue Aug 09, 2011 1:16 am
"Difficult question that one, but honestly I think the Duende."
I like your honesty :up:
It's sometimes quite hard to look objectively when you've just paid a lot of $$ for something.....
The more I ride, the less I spend
PostPosted: Tue Aug 09, 2011 10:03 am
Luckily no one says we need to have only one bike!
PostPosted: Tue Aug 09, 2011 11:10 am
Abolsutely. If I only had one bike, I would be a bit worried, but that's the beauty of having a range of rides available!
The Resposnorium is a beautiful bike and in that respect I can't say that I am disappointed, but maybe the Duende just suits my rapidly ageing body better!
The Hyperons arrived and first layer of glue applied last night. Should be able to report on Saturday how they alter things. They look fantastic, but let's see how they ride.
PostPosted: Tue Aug 09, 2011 11:18 am
What are you gluing to the Hyperon? I hope it starts with a V :D
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: chazmtb and 21 guests
There are no new unread posts for this topic. Cinelli Superpista and Pegoretti Responsorium
RudyMontana
21
2445
Sat Feb 23, 2013 8:01 pm
RudyMontana View the latest post
There are no new unread posts for this topic. Trek Madone 5.5 rebuild for this season WHEELS UPDATED
philipBer
9
1389
Thu Apr 25, 2013 10:55 am
philipBer View the latest post
There are no new unread posts for this topic. Pegoretti
nick
9
2352
Sun Dec 09, 2012 8:22 pm
dcj9 View the latest post
There are no new unread posts for this topic. Pegoretti Marcelo
tuercas
Tue Apr 23, 2013 4:05 pm
tuercas View the latest post
There are no new unread posts for this topic. Pegoretti & ENVE
CAFERACER
24
3357
Wed Nov 07, 2012 8:19 pm
tompho View the latest post
It is currently Thu May 23, 2013 4:15 am
