Moots Vamoots RSL - 6140g
wheelbuilder
by wheelbuilder
Nicely done! Very attractive.
elfuinha
by elfuinha
Enviado do meu SM-G935F através do Tapatalk
NiFTY
by NiFTY
I have the haero. Swapped to them from a 3t ergonova ltd. 155g on scales for a 42. At least as stiff as ergonovas ltd, not as stuff as team. Shape is similar but with a much shorter rea h (10mm or so). Vs most bars you will need to add 10mm to your stem length. Have put several thousand ks on them without issue including flying to hawaii.
elfuinha
by elfuinha
Many thanks... I'm inclined to the MCFK that I already know and have on my other bike.
My regret is that is only UD
elfuinha
by elfuinha
pull the plug on a MCFK UD handlebar.
dak
by dak
elfuinha wrote:
Mon Jan 29, 2018 11:10 am
Out of curiosity why did you change the MCFK/AX bar /stem combo? Sorry if I missed it in an earlier post.
Amazing bike though!! I have been looking at and RSL as my N+1. How does it compare to high end carbon bikes you have ridden?
My 2016 Evo Hi-Mod
viewtopic.php?f=10&t=141400
elfuinha
by elfuinha
dak wrote:
Mon Jan 29, 2018 6:45 pm
1st - never ridden carbon road bike, can only compare to the Vitoire XCR i've. But the bike is very light and stiff. i weight 85kg.
2nd - changing the stem bar, so the messure be the same as my other bike viewtopic.php?f=10&t=135477
thanks
dbnm
by dbnm
I am currently working on getting my RSL below 7kg. It's my every ride bike so I need durability over light weight. Thanks for post your parts and experience.
elfuinha
by elfuinha
dbnm wrote:
Tue Jan 30, 2018 5:20 pm
what do you have, o your bike.?
elfuinha
by elfuinha
New pictures:
Changes from 2017:
  • OMC ITALIA 175mm Crank Arms
    MCFK 3K 110mm 6º Stem
    MCFK 42cm UD Handlebar (Note: MCFK no longer does 3K components :( )
    MCFK 3K top cap
    Berk Lupina 150mm padded Saddle
    Extralite 5mm Spacer
    K-Edge Garmin Pro Mount
    New Cables and housing
Cut 5mm of the Fork Stering tube (all messures equal to my Victoire Veloce XCR)
https://ibb.co/jJDkY7
https://ibb.co/i2pQY7
https://ibb.co/jfUsD7
Didn't weight this build, but should be around 6250g
