Post new topic Reply to topic  [ 58 posts ]
Go to page 1, 2, 3, 4  Next
PostPosted: Sun May 22, 2011 8:48 pm
After almost 10 months of waiting my custom Sycip Finally showed up on Friday. Having a BMC Racemaster I knew I wanted to copy many of the race geometry and handling from this bike. Knowing Jeremy personally and him knowing how I ride, he had some improving suggestions on geometry, measurements, and tubing.
Tubing is oversize Columbus Spirt with Life seat tube.
DT is 38mm, curved seatstays, PF30 BB, new 44mm Chris King head tube.
This is truly not a weight weenie from coming from steel, but hopefully with some well chosen parts the weight won't be too bad. I originally was going to mix components to make it the lightest possible, but after test riding 2011 Super Record and spending time at Above Category, I made the switch to everything part complimenting each other rather than being the lightest. Just looking at the frame and color, I think it was the right move.
Build Specs:
-2011 Super Record w/Ti Crank
-ENVE 1.0 fork, bar, seatpost
-Deda Stem
-Reynold MV32T rims (237g ea.)
-C-4 50f,170r hubs w/ceramic hybrids (was told they came in 10g under weight)
-Sapim CX-Ray
-C-4 Ti UL Skewers
-Vittoria corsa evo 320tpi
-Selle Italia SLR carbon
-CAN'T DECIDE ABOUT CAGES, KING TI OR NEW ULTIMATE CARBON. Suggestions, opinions?
Having ridden carbon, aluminum, steel/carbon, aluminum/carbon, I'm a little anxious/curious how this will ride. Talking to Jeremy and many other builders, its been everything from "it will ride awesome" to "will ride like a brick".
Build pics and weight coming sometime this week. For now...
update
PostPosted: Sun May 22, 2011 9:45 pm
:thumbup:
PostPosted: Sun May 22, 2011 10:48 pm
Wow.. !
Nice selection of parts too.
Go with the King cages, the NU's are too fragile in my opinion and don't hold bottles that well. (I used both)
PostPosted: Mon May 23, 2011 1:46 am
:thumbup:
That will be fantastic with SR. Cannot wait to see the final build and weight.
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Mon May 23, 2011 5:02 am
BEAUTIFUL!
Steel is real... :thumbup:
"It never gets easier, you just go faster..." - Greg Lemond
"Because technology alone is a poor substitute for experience." - Richard Sachs
PostPosted: Mon May 23, 2011 5:13 am
Wow, that's absolutely beautiful! :thumbup:
Has the top tube an oval section, or does it just seem so in the pics?
2010 Guerciotti Whisper
2007 Bianchi 928L (update Sep '11)
1999 Bianchi MegaPro 25CrMo4
PostPosted: Mon May 23, 2011 6:00 pm
more on this please, looking forward to the build up :thumbup:
cannondale flash3 alloy 29er
trek 5200 nude carbon
pegoretti marcelo
PostPosted: Mon May 23, 2011 6:58 pm
Sweet looking bike. Keep us posted on the build.
I have a custom steel frame on order from Strong. Should be complete in the next month or so. We selected True Temper S3 for the main tubes, Columbus Spirit for the chainstays and 16mm seat stays. I was looking for something that was stiff out of the saddle and with a nice ride in the saddle.
I LOVE the ride of my '00 Serotta Atlanta with '01 Record, but it weights 21lbs. I love the stiffness of my Caad9 with '07 Record (18.0 lbs) but it beats the hell out of you on rough roads. I'm hoping that the Strong will come in around the weight of the Caad9 with similar out of the saddle stiffness and the great ride of steel.
Having ridden Steel, AL, and Carbon bikes, nothing compares to the comfort of steel...
1984 Ciocc Designer (63) '84 Super Record = 21.9 lbs
2000 Serotta Atlanta (60) '01 Records = 20.9 lbs
2009 Cannondale Caad9 (60) '06 Record/Chorus = 17.4 lbs
2009 Trek Madone 5.5 (60) '07 Record = 14.8 lbs
2011 Strong Extralite [steel] (59) '08 Record = TBD
PostPosted: Mon May 23, 2011 7:53 pm
Top tube is round, probably just the picture. Also went with all internal cable routing. It might be a little headache, but wanted to keep things really clean.
Might have some weights posted by the end of the day.
PostPosted: Mon May 23, 2011 10:45 pm
What did the bare frame weight? About what size is it?
Thanks!
PostPosted: Tue May 24, 2011 2:38 am
wow. looks great! will probably ride even better!
the tube shaping is very impressive. i bet a lot of people won't be able to tell that is steel from a short distance.
PostPosted: Tue May 24, 2011 4:13 am
Beautiful. Can't wait to see the complete build. Have a feeling you will like the ride of steel.
PostPosted: Tue May 24, 2011 6:09 am
Effective TT is 55cm, HT-132mm, Chainstays-405mm
I apologize for iphone photos, but it was the quickest with my 1yr old daughter. Having an experienced frame builder, and personal friend, has made all the different in the world. I almost pulled the trigger on a Cervelo R5 because I thought I wanted the"Lightest possible bike"...and I would still get one if possible. However, after having many conversations and spending a lot of time on here, I decided having Jeremy build exactly what I want was more important than just weight.
Jeremy has build hundreds of frames and used to do all his own paint in house before outsourcing. He said the frame weight is very light for steel and the tubing/options we went with. Also, the powder probably adds 100-150 grams. That could put the bare frame around 1550ish grams.
It was a little shock to see how much the "little parts" weighed...seatpost collar, headset, seatpost clamp...maybe I can work on these later.
Complete weights and partial build at the bottom
At this point need to add cables, housing, chain, bar tape, cages, pedals....enjoy
PostPosted: Tue May 24, 2011 11:43 am
Nice bike :thumbup:
Can you post a closeup of those rear dropouts?
PostPosted: Tue May 24, 2011 11:54 am
Looking fantastic :D I love the frame.
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3, 4  Next
Users browsing this forum: Google Adsense [Bot], LocoDuck, Majestic-12 [Bot] and 21 guests
There are no new unread posts for this topic. First crit ride report
pmr
25
1557
Mon Jan 07, 2013 7:21 pm
edesigner View the latest post
There are no new unread posts for this topic. Ride report Majorca...
PSM
41
2125
Mon Apr 22, 2013 11:14 am
Leviathan View the latest post
There are no new unread posts for this topic. Attachment(s) Ride report for Ridley Fenix
nickl
Sun Feb 10, 2013 2:23 am
nickl View the latest post
There are no new unread posts for this topic. Sycip with Hyperons
go4custom
14
1604
Fri Sep 28, 2012 4:52 am
go4custom View the latest post
There are no new unread posts for this topic. Steel/Carbon Sycip 29er completed!
go4custom
Sun Mar 10, 2013 5:58 pm
Dennis View the latest post
It is currently Mon May 20, 2013 6:06 am
