Cyfac Absolu and Cadence
LouisN
by LouisN
Absolu + Lightning crankset = Want. to. look. at. the. pictures. :D !!!!
Louis :)
strobbekoen
by strobbekoen
It's in customs now and they are giving me a hard time to clear it!
Should be next week..
robertbb
by robertbb
Hiya,
I've read that the adjustable clamp (the one which allows multiple fore-aft positions) will fit Ridley Helium ISP. (Not surprised, some of the joins and design queues on the Helium and Absolu are veeery similar). The clamp that came with my Helium is the non-adjustable one (fixed with aft position -20mm). Are you able to take a couple of close-up shots of the adjustable clamp (shape of the opening, the clamping mechanism itself, the adjustable positions)? If it looks about right, I'll see if I can get one from Cyfac (unless you feel like kicking yours my way for a few quid if you're not going to use it ;-) ) - I'm having difficulty sourcing a Ridley one.
Cheers,
Rob.
It's ALL about the bike.
strobbekoen
by strobbekoen
Hi,
The one which allows multiple (2) fore-aft position does that by moving the rail support to another threaded hole. There are 2 threaded holes. The saddle angle is set by ridges in the rail support.
The fixed position one allows micro-adjustment of the saddle tilt, but not fore-aft adjustment.
There is also a 3rd one (which i dont have) which is a forward post.
robertbb
by robertbb
Thanks strobbekoen,
I'm guessing that if there is a third, fixed set-forward clamp, the adjustable one with the threaded holes allows both neutral and set-back positions... are you able to post any photos of this one?
Cheers,
strobbekoen
by strobbekoen
Yes, i will make some photos for you tomorrow as it's midnight here now :D
Dman
by Dman
Good tip with opening the seat-mast clamp. I would have learnt the hard way. :beerchug:
The more I ride, the less I spend
strobbekoen
by strobbekoen
You are welcome :)
The cranks are still in customs so I am still waiting..
robertbb
by robertbb
/me waits patiently for pics of the clamp... :-) :wink:
strobbekoen
by strobbekoen
sorry..
The first design is a 2-setback system. the bolt can be threaded into 2 different positions, about 1cm apart. the tilt of the saddle is established by the ridged wedge (I dont like this to get the saddle tilt right).
The second design is a fixed setback system - this is similar to many other seatposts where the front bolt determines the saddle tilt and the rear bolt torques it down.
robertbb
by robertbb
Thanks mate :thumbup: The second clamp (fixed position) is identical to the Ridley Helium clamp. The first (adjustable fore-aft) therefore should fit the Helium.
Interestingly, the adjustable Ridley clamp is described as 3-position, not 2-position. I'm trying to get my hands on that one, but unfortunately no Ridley dealer in Australia seems to be able to help. I've contacted Ridley directly, and if I can get my hands on one from them, I'll post pics. If by some chance I can't, would you be willing to part with yours? (I'm fine with a fixed/level tilt, and need neutral setback so judging by the pic the 2-position one would work well too).
Cheers. :beerchug:
rjfrzb
by rjfrzb
The one which came with my Absolu is different than the one shown. It has two bolts for adjusting the saddle angle, with the forword bolt having an adjusting wheel as the head of the bolt is hidden and the rearward an allen bolt. I'll try to post pictures as time permits. For and aft is adjustable within the limits of the seat rail.
prendrefeu
by prendrefeu
How much does it weigh?
strobbekoen
by strobbekoen
rjfrzb wrote:The one which came with my Absolu is different than the one shown. It has two bolts for adjusting the saddle angle, with the forword bolt having an adjusting wheel as the head of the bolt is hidden and the rearward an allen bolt. I'll try to post pictures as time permits. For and aft is adjustable within the limits of the seat rail.
That's the one as shown mounted on the bike, the way you describe yours seems exactly what I got too.
strobbekoen
by strobbekoen
prendrefeu wrote:How much does it weigh?
Alex, it's 116g.
