Cyfac Absolu and Cadence
strobbekoen
by strobbekoen
I received the frameset around noon today and could not wait to build it up!
I am happy because the geo is spot on with a standard L size.
I might change the stem to a 8 degrees instead of 6 degree so it's parallel with the toptube.
Moved the parts from another bike to this one, will need a 1cm longer stem as well.
I am still waiting on the 11speed StrongLight chainrings for the SRM!
Temporary pic:
click on it to see the biggie.
devinci
by devinci
oh it will seriously look nice with the wheels and SRM. Very nice build. Original too!
strobbekoen
by strobbekoen
10 degree stem, 1cm longer. Reach is perfect now.
some more shots..
By the way, tape will be black. Might change the hoods back to black too. will see later.
devinci
by devinci
wow some very nice build and nice close shots. I am all the way down for black tape+black hoods!
:thumbup:
LouisN
by LouisN
Soooooo Nice :thumbup: !!!!
Now give that rig a beating, and come back with riding reviews :beerchug:
Fashion weenie comment: I like red hoods. Not too much IMO (as long as you don't throw in some deep rims with big red stickers "à la Bora").
Louis :)
Geoff
by Geoff
Really nice!
iamblichus
by iamblichus
dang koen, that bike is so nice. i love the cable stops on the down tube. i can't wait to hear what you think about how it rides.
good luck finishing the build.
strobbekoen
by strobbekoen
Thanks guys.
Chainrings are on the way for the SRM.
Actually I didn't expect the frame to arrive until thursday, and yesterday I took off the chainrings and put them on my brother's SRM :D
jghall
by jghall
Agree, very proper build. Like the lower profile rims as they match well with the not overly robust tubes.
coloclimber
by coloclimber
:thumbup: :thumbup: :thumbup:
Nice Ride.
-Deacon Doctor Colorado Slim
prendrefeu
by prendrefeu
Winning. :thumbup:
deltasierra
by deltasierra
Sticky!
strobbekoen
by strobbekoen
The bike's been finished and did some rides on it. It's one of the smoothest rides I've been on. Stiff enough, comfortable enough. The geo on their standard (non custom) frames has a slack seattube angle so it may not be suited for those with little saddle setback (say < 6cm). The setback in the pics is 7cm and I am using the shortest position on the clamp.
The Cyfac has a slightly slacker seattube (72.5) and a taller headtube which gives me a little less reach, compared to my Time. perfect. I left the spacers on top of the steerer in case I want to change to another stem. I put the Syntace combo back on, which is at 6 degrees. The syntace stuff is noticably stiffer than the Easton combo. I am using one 5mm spacer. This gives me about 7.5cm drop from saddle to bars.
Some nice features:
The way the cable stops are designed keeps the cables away from the frame. No cable rub or rattle.
There is plenty room for bigger tires on front and rear. I would guess it would fit up to 27s or so.
It came with two seatpost clamps. The one you see is a fixed position one a la Giant. It has two threaded holes for adjustment. The other clamp is a adjustable one.
The bottlecages hold the bottles well. No rattle or jumping bidons!
All these give it a really quiet ride. Cool.
ISP Tip:
To put the clamp on without damaging the paint, unscrew the bolt, thread it in from the other side with a coin in the slot. The bolt will push against the coin and open the clamp.
some new shots:
strobbekoen
by strobbekoen
After 5 test rides, I am done tampering with the stem/bars.
Changed the seatpost clamp to the adjustable one, easier to get the saddle level.
Stem and bars: 10 degree 110mm easton, ritchey alloy logic II.
The first setup with the SLX3 was good as far as reach is concerned, but I don't like the sharp bend in the bars.
The second setup came off my Time, but it felt short on the tops with the same reach to the hoods.
All black tires would be nicer but I'll use up these crits first.
