HOT: Active* forum members generally gain 5% discount at starbike.com store!
HOME Listings Blog NEW Galleries NEW FAQ Contact About
Post new topic Reply to topic  [ 53 posts ]
Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: My New CAAD 10
PostPosted: Fri May 06, 2011 4:32 pm
Great build. Also great bike.
Do you have any descending experience on the bike yet? I've got a friend in the market for a new bike - CAAD10 or Super Six in 63cm. He was going to go with the Super Six since reading a review by Leonard Zinn saying that one thing he liked about the Super Six was that there was no high speed shimmy going on in the head tube, which you can usually find in frames of that size. The new CAAD 10s have a tapered head tube but wondering if that eliminates any shimmy, or if you need the tapered head tube and deeper section that is found on the Super Six to eliminate it?
Thanks for your thoughts..
PostPosted: Fri May 06, 2011 4:53 pm
Thanks for the compliments, I have a few planned upgrades to my build. Some are currently in shipping while others are backordered for a while. In regards to the handling and feel of the bike, I know what you mean about large frame sizes not always being that solid. I was really surprised by how excellent this frame rides. Descending is a dream. The tapered head tube makes handling fell really solid. I know someone with a 2010 63cm Hi-mod Supersix that has similar things to say. I would say that obviously you're going to get the stiffer more responsive ride with the SuperSix but with the Evo right around the corner I would recommend holding out if possible and maybe doing a CAAD 10 while he waits.
Cannondale CAAD 10 63cm || Cannondale Flash Carbon 29er || Cannondale Evo 63cm
PostPosted: Fri Jul 01, 2011 12:41 am
New wheels are on the way! Parts are starting to trickle in.
More to come
PostPosted: Thu Aug 04, 2011 9:55 pm
New brakes - TRP 970SL
Removed red 3T and Salsa decals from stem and handlebar
New pedals - Look Keo Blade Ti Axle 16Nm
New seatpost - 3T Dorico LTD
Cut steerer tube and dropped the stem
PostPosted: Mon Aug 08, 2011 8:14 pm
The new wheels are finally here! Under weight to boot. Should have them glued up and running in about 3 days.
Front at 425g
Rear at 638g
Front skewer at 21g
Rear Skewer at 23g
Madfiber cork pads at 15g
Madfiber supplied valve extensions which I will not be using at 3g
Madfiber supplied wheel magnet at 4g
Dura Ace 12-25 cassette at 185g
Vittoria Evo CX 23mm tubular tire #1
Vittoria Evo CX 23mm tubular tire #2
PostPosted: Wed Aug 10, 2011 6:17 am
oh, will be really nice with Madfiber on that bike :)
/jonas l
PostPosted: Fri Aug 12, 2011 12:59 am
Freshly glued and mounted, ready to ride!
Big, aluminum and light - 6540g/14.4lbs
 Post subject: Re: CAAD 10 63cm - 6540g
PostPosted: Fri Aug 12, 2011 4:29 am
Thats awesome. Great build. I would love to see some of the reactions you get when people pick up such a big alloy bike and realise its lighter then there carbons. :shock:
My Cannondale Slice RS Blk Inc
viewtopic.php?f=10&t=110160
My Cannondale CAAD10 with Custom Paint
viewtopic.php?f=10&t=109474&start=15
PostPosted: Sat Aug 13, 2011 4:47 pm
I'm jealous. My 56 weighs more than your 63 :(
Specialized Allez 06' "Rain Bike" 21.50lbs
Neuvation F100 11' "Road Bike" 16.80lbs
Specialized Tarmac Pro 11' "WW Bike" 14.25lbs
PostPosted: Sun Aug 14, 2011 5:27 am
I was stunned this came in as light as it did. I was calculating a much heavier bike. The Madfiber wheels are really something else! Going to switch out the rear derailleur, shift/brake levers and the crankset. That should knock off nearly 100g. I could easily knock off another 100g by getting a carbon bar but I rather like the idea of going with an aluminum cockpit and keeping as much aluminum on the bike as I can. It is after all a CAAD frame.
PostPosted: Mon Aug 22, 2011 9:00 pm
Hollowgram is here! 550g for 53/39 MK V rings with 175 arms
FSA 50/34 chainrings come in at 202g
Cannondale MK V 53/39 chainrings come in at 175g
I think I'll use the FSA chainrings for the time being. I think the 27g weight penalty is worth better shifting performance plus a little extra help in the hills.
PostPosted: Tue Aug 23, 2011 6:12 am
My CAAD10 is feeling so inadequate!
PostPosted: Wed Aug 24, 2011 5:52 am
Have you used that crankset yet? How does it feel?
PostPosted: Wed Aug 24, 2011 6:10 pm
The Hollowgram crankset is amazing. The arms are incredibly stiff. It really feels like all of your power is going right into the drivetrain. The FSA rings are a big step up from the Sram Red rings. They make shifting so much crisper and cleaner. Not to mention the big weight savings. Cannondale is on top of their game. I can't imagine having a better set-up. I think I'll always have to have a BB30 bike just so I can use this crankset.
With the Hollowgram crankset installed the bike now come in at 6.48kg. Only 130g to go before I can get under 14lbs!
PostPosted: Thu Aug 25, 2011 10:06 pm
It looks so much better with those new cranks - the previous cranks were nice but I love those Hollowgram cranks - I have a set waiting to go on my six13 - can't wait!!!
Apologies if you've been asked this before, how much do you weigh?
Users browsing this forum: No registered users and 16 guests
There are no new unread posts for this topic. CAAD 10 problem
Gardengnome
18
2216
Sun Mar 22, 2015 6:53 am
aram View the latest post
There are no new unread posts for this topic. Caad 10 - size 52
in Wanted
wjs
Sun Dec 27, 2015 9:28 pm
wjs View the latest post
There are no new unread posts for this topic. CAAD 3 - The return
thebuny
9
1721
Sat Jan 30, 2016 11:37 pm
thebuny View the latest post
There are no new unread posts for this topic. CAAD 10 Black Inc. 6,59 kg
Wildstyle5000
Sat Jan 23, 2016 7:18 am
Wildstyle5000 View the latest post
There are no new unread posts for this topic. CAAD 10 - "Rogma84"
in Comments
nmx
Mon Oct 05, 2015 8:59 am
nmx View the latest post
It is currently Mon Feb 08, 2016 4:01 pm
