Post new topic Reply to topic  [ 833 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6 ... 56  Next
 Post subject:
PostPosted: Mon Aug 29, 2005 2:47 am
oh click the pictures for bigger ones!
 Post subject:
PostPosted: Mon Aug 29, 2005 7:21 am
sex
 Post subject:
PostPosted: Tue Aug 30, 2005 12:51 am
Independent Fabrication Crown Jewel representin!!!
as much as I drool over all the cool carbon framesets, I take my baby out and let the steel fork (!!!) sing over the pavement in perfect harmony with the frame and it's just the right thing for me.
maybe someday I'll get a Scott CR1, but for now I'm happy with a 19lb steel couch.
Jamis Xenith SL is next up...
 Post subject:
PostPosted: Tue Aug 30, 2005 4:11 am
What do you mean, "still have" a steel bike?? :P :D Darned RIGHT I do!
Mine is an '03 Raleigh Professional:
~ Bar Tape: Stella Azzurra Tecno Spugna #3, Sunflower Yellow
~ BB: Token TK-872-SC, 108mm x Eng.
~ Bottle Cage: n/a (use Camelbaks), Ti bolts
~ Brakes: '03 Centaur
~ Cables: Campagnolo
~ Cassette: Veloce 12-23 10v, w. PedalSoft Cirque lockring
~ Chain: Record Ultra 10
~ Chainrings: FSA Pro Road, 52/38
~ Computer: Cateye Micro Wireless, Model CC-MC100W
~ Crankset: FSA Team Pro Issue, 175mm
~ Fork: Columbus Muscle, 45 deg. carbon monocoque, 1 1/8", 15mm carbon spacer
~ Frame Geometry: 56.13cm Top Tube, 40.39cm Chainstay, 98.81cm Wheelbase, 73.0d Head Tube Angle, 73.0d Seat Tube Angle, 81.03cm Stand Over.
~ Front Derailleur: '03 Chorus, braze-on
~ Handlebar: ITM The Bar 26.0, 46 o-o
~ Headset: Columbus/FSA Intellaset Pro w. Stainless Steel bearings
~ Pedals: Time RXE
~ Paint: Heritage Champagne/Black
~ Rear Derailleur: '03 Chorus short cage, 10v, w. Fiberlyte carbon backplate
~ Rim Tape: Velox, trimmed to cover spoke & valve holes only
~ Saddle: Brooks Swift
~ Seat Clamp: OEM
~ Seatpost: Kalloy Guizzo Carbon, 27.2 x 200mm.
~ Shifters/Brake Levers: '05 Chorus Ergo
~ Skewers: '02 Record
~ Stem: Oval Concepts R700, 110mm/84d
~ Tires: Vredestein Fortezza Road 23c rear, Fortezza Pro 21c front
~ Tube: Specialized Turbo Road LVS 18/25, butyl, 48mm valve
~ Tubing: Columbus Zona Megatube steel
~ Wheels: '03 Zonda G3 rear, '02 Bora front
Weight as listed: 18.8 lbs.
Frame-wise, this thing is stiff! I'm 5' 11.5" and 195 lb. range. Columbus Muscle seat stays would tame the sometimes "too stiff" rear end. It would fit me better with about 7 mm. added to the TT length with a 110mm stem. Maybe a different paint scheme some day.
Component-wise, eventually I'm changing calipers, skewers, crankset, pedals, cassette, and saddle.
* Will update specs and pix as they change. This pic does not show new Easton bar & Ritchey stem, shorter steerer tube, Record Ultra Narrow chain, Zonda rear wheel, and mounted tubulars.
 Post subject:
PostPosted: Tue Aug 30, 2005 3:42 pm
As the following pic shows.......alu all the way :lol:
Vorsprung Durch Tortë http://www.costablancacycling.com/
 Post subject:
PostPosted: Wed Aug 31, 2005 12:07 pm
Hello,
Here is mine
It is a CUSTOM 650 deda SAT 14.5.
Please, leave your car at home every time it's possible.
 Post subject:
PostPosted: Wed Aug 31, 2005 4:00 pm
KB wrote:
Caygill Ultra Foco with Lightweight wheels, love it and it's very comfortable. Approx 6.6 - 6.7 kg. Ialso have two bikes with Reynolds 853, but the Ultra Foco's better.
:shock: this is one stunning machine :shock:
 Post subject:
PostPosted: Wed Aug 31, 2005 7:45 pm
Thanks. I have a Storck Scenario 0.9 that's bang on 6kg, but I like the Caygill better.
PostPosted: Wed Aug 31, 2005 8:18 pm
mises wrote:
I've decided to get a steel frame made for vacation and other non-goal oriented use so I am curious what people's steel bikes are like. What components are on it, what you would change, like or dislike?
I am thinking of going with downtube shifters and a steel fork in one version of it.
Seeing that you are curious, I'll show you mine. (Any excuse!)
Fillet brazed frame, custom geometry to my own spec. 1.69kg (Approx. size 55cm)
ITM Millenium 1" fork 400g
Dura Ace 9spd, Cinelli Eubios, ITM Millenium stem, SLR/Carbon Alien, Keo pedals, Open Pro rims 32h 3X with DT Revs, Conti GP 3000 + Supersonic, FRM QRs.
Total weight currently 8.07kg / 17.8 lbs.
There's nothing really about the frame that I would change, since I put a lot of thought into the design in the light of many years experience of cycling. But, if I did want anything changed, it would be an option.
I am constantly upgrading components to reduce weight and increase performance, though I do have an underlying rule of not compromising it's rideability ie functioning and comfort.
Down tube levers are certainly an option to simplify a bike and reduce weight, though it may limit your choice of more up to date components.
Nothing rides quite like a good steel fork, but there is a large weight penalty.
 Post subject:
PostPosted: Wed Aug 31, 2005 10:54 pm
:shock: Eek, what's the length of that front tire's valve? :shock:
i'm old enough to still remember the time when the frame had to fit and one didn't need to push the saddle to the rear end and mount a stem as long as a grown man's arm. Nice bike, otherwise :) i like the paintjob! but just one bottlecage?
Martin
Snowman and Strong Walker
Scott Sc
my old stuff
my new stuff
 Post subject:
PostPosted: Wed Aug 31, 2005 11:07 pm
Martin
The frame does fit, I've actually changed the stem to a 12cm, it was a bit stretched. The top tube is quite short, but I prefer it that way. The saddle is not that far back; I've seen them much further. One bottle cage on the bike, but it has one that's not used on the seat tube. The valve came from my LBS, the wheels of course from our hosts.
 Post subject:
PostPosted: Wed Aug 31, 2005 11:54 pm
There are reasons for having a steel bike that haven't been considered here - if you're a weight weenie and you like to travel with your pride and joy, one convenient way to do it is with S&S Machine BTCs (which are for steel and Ti frames, though these won't work with the ultralight Ti tubesets), unless you want to go for smaller wheels...
There's a separate post with the detailed specs of my Roberts ULT Compact here:
http://weightweenies.starbike.com/forum/viewtopic.php?t=3170&highlight=
Since last year, when it was featured on the Cycling Plus stand at the London Cycle Show (lightest bike at the show at 5.5kg) it has been lightened a bit more, with new AX seatpost and saddle, BTP Campy Record FD, cork brake pads, lighter cable splitters and lighter Tune hubs (wheels are now under 1kg for the pair and can be happily ridden up and down mountains).
Sensibly set up for actual riding, with "real-life" tubulars (and chainrings and cassette) etc it comes in at 5.8kgs and is still a mind-blowing ride.
But best of all, within an hour I can pack/unpack it into a 26x26x10" suitcase, along with all my related cycling gear, carry it on my back/use public transport to get to the airport and squeeze under Ryanair's pitiful 15kg baggage allowance (and the standard airline checked baggage size limit).
 Post subject: Marcelo
PostPosted: Sat Jan 20, 2007 1:41 am
This is my Marcelo. I love it.
Pego.
 Post subject:
PostPosted: Sat Jan 20, 2007 3:13 am
Concorde with Colombus MAX tubeset. I also have a Concorde Giro with Columbus Brain. It is really sweet.
 Post subject:
PostPosted: Sat Jan 20, 2007 3:59 am
yourdaguy wrote:
WHY???
why not?
hard to explain really, something about steel that is fun to ride, I ride an apollo frame that I've converted to single speed, weighs in at 25 pounds. I lopped off 5 pounds by changing wheels, brakes, etc
also you can rag on it and it won't brake, can't say that for CF frames
next bike will be steel with all ww parts.
Jack of all trades, master of none.
Post new topic Reply to topic  [ 833 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 56  Next
Users browsing this forum: Exabot [Bot], fio, pje0713, xjbaylor and 28 guests
There are no new unread posts for this topic. Lugged steel winter bike Traitor Exile
bm0p700f
Mon Nov 05, 2012 8:57 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Building urban Steel Bike single speed
JWolf
23
2249
Thu Aug 23, 2012 7:42 am
ticou View the latest post
There are no new unread posts for this topic. Concorde Squadra aero steel bike project
SWijland
10
1299
Wed Apr 17, 2013 10:03 am
SWijland View the latest post
There are no new unread posts for this topic. Sun and Steel.
Cat6TT
Sun Mar 31, 2013 5:11 am
Cat6TT View the latest post
There are no new unread posts for this topic. Attachment(s) Steel WW projects
[ Go to page: 1, 2, 3, 4, 5 ]
1spd
68
7211
Wed Jan 23, 2013 1:17 pm
MDH View the latest post
It is currently Tue May 21, 2013 6:53 pm
