onyourleft wrote:What do you mean, "still have" a steel bike??
Darned RIGHT I do!
Mine is an '03 Raleigh Professional:
~ Bar Tape: Stella Azzurra Tecno Spugna #3, Sunflower Yellow
~ BB: Token TK-872-SC, 108mm x Eng.
~ Bottle Cage: n/a (use Camelbaks), Ti bolts
~ Brakes: '03 Centaur
~ Cables: Campagnolo
~ Cassette: Veloce 12-23 10v, w. PedalSoft Cirque lockring
~ Chain: Record Ultra 10
~ Chainrings: FSA Pro Road, 52/38
~ Computer: Cateye Micro Wireless, Model CC-MC100W
~ Crankset: FSA Team Pro Issue, 175mm
~ Fork: Columbus Muscle, 45 deg. carbon monocoque, 1 1/8", 15mm carbon spacer
~ Frame Geometry: 56.13cm Top Tube, 40.39cm Chainstay, 98.81cm Wheelbase, 73.0d Head Tube Angle, 73.0d Seat Tube Angle, 81.03cm Stand Over.
~ Front Derailleur: '03 Chorus, braze-on
~ Handlebar: ITM The Bar 26.0, 46 o-o
~ Headset: Columbus/FSA Intellaset Pro w. Stainless Steel bearings
~ Pedals: Time RXE
~ Paint: Heritage Champagne/Black
~ Rear Derailleur: '03 Chorus short cage, 10v, w. Fiberlyte carbon backplate
~ Rim Tape: Velox, trimmed to cover spoke & valve holes only
~ Saddle: Brooks Swift
~ Seat Clamp: OEM
~ Seatpost: Kalloy Guizzo Carbon, 27.2 x 200mm.
~ Shifters/Brake Levers: '05 Chorus Ergo
~ Skewers: '02 Record
~ Stem: Oval Concepts R700, 110mm/84d
~ Tires: Vredestein Fortezza Road 23c rear, Fortezza Pro 21c front
~ Tube: Specialized Turbo Road LVS 18/25, butyl, 48mm valve
~ Tubing: Columbus Zona Megatube steel
~ Wheels: '03 Zonda G3 rear, '02 Bora front
Weight as listed: 18.8 lbs.
Frame-wise, this thing is stiff! I'm 5' 11.5" and 195 lb. range. Columbus Muscle seat stays would tame the sometimes "too stiff" rear end. It would fit me better with about 7 mm. added to the TT length with a 110mm stem. Maybe a different paint scheme some day.
Component-wise, eventually I'm changing calipers, skewers, crankset, pedals, cassette, and saddle.
* Will update specs and pix as they change. This pic does not show new Easton bar & Ritchey stem, shorter steerer tube, Record Ultra Narrow chain, Zonda rear wheel, and mounted tubulars.
