It is currently Wed Apr 26, 2017 11:04 pm
Post new topic  Reply to topic  [ 102 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Thu Mar 10, 2011 6:39 pm
It would push you well over budget but you are still using that 324g fork.
17 and stupid, bear with me
PostPosted: Fri Mar 11, 2011 1:50 am
Well 2 of my recent purchases have come in. The brake pads are still 2 weeks away according to an email I received.
KMC X11-SL chain - 3 links removed (217g); was 230g at full length
15g savings over X10-SL at same length
M2 Racer B/O Ti skewers (28.5g)
12g savings over KCNC Ti
This brings my calculated weight to 5.070kg.
Current Weight Weenies:
Cannondale Evo HM (In Progress)
Cannondale CAAD 9 - 6.44kg
Cannondale CAAD 5 Track - 6.55kg
Kona Kula Supreme Mtb - 8.97kg
Other Bikes:
De Rosa Primato, 1988 Cannondale Criterium, Cannondale CAAD 8, Surly Steamroller, YETI ASR
PostPosted: Thu Mar 17, 2011 6:44 pm
Have you considered a bit of bar end trimming? You may be able to save another 5-10g. I've seen it done for those who don't utilize that portion of the bar.
A thought, not something I'm doing, but a thought none the less.
PostPosted: Fri Mar 18, 2011 8:50 pm
I cut 20mm off the ends of my ritchey wcs bars 8g total and you lose a bit more of the shorter bartape too, I don't notice the slightly shorter bar either.
PostPosted: Fri Mar 18, 2011 9:27 pm
I was sorry for cutting my bar ends, though. Had no idea I would miss them...
But I dont regret using shifter cables for brakes. Firstly I only changed the one for the rear brake. Not noticing any ill-effects I recently replaced the other one as well.
These are low-cost grams, I hope...
PostPosted: Thu Mar 24, 2011 5:51 am
While some can deal with it, I will not be shortening my bars, I like the lower section.
Now onto the easiest 24 grams I have ever saved. I got my Red Corima Cork pads in today to replace the yellow Swissstops I was using and they are certainly lighter, and a whole lot cheaper. Lets hope they work well. I don't plan on riding this bike in the rain or slop since I have the Cannondale, so they just have to perform well in the dry.
This brings my new calculated total down to 5.046Kg, oh so close.
Heavy Swissstop Yellow pads at 32 grams
Much lighter Corima Red Cork pads at 8.5 grams pictured. They are probably around 8 grams as installed since I had to shave them down to fit them into the KCNC pad holders.
I will have pictures on the hanging scale soon.
Other Bikes:
PostPosted: Sat Mar 26, 2011 7:16 am
So I took the fork off of my CAAD 9 and mounted it up to the Scott and my original goal has been achieved. Sub 5.0kg!!! :D I don't think it looks quite as nice as the Scott fork. The Scott fork flows better into the 44mm headtube, but the Ritchey doesn't look too bad. Never the less, I reached my weight goal and I am only slightly over budget at around $2700.
Final Build List
Thanks for looking, it sure was fun.
Other Bikes:
PostPosted: Fri Apr 01, 2011 5:04 am
Very well done. That thing is an absolute beauty!
How often do you get to ride it?
PostPosted: Thu Apr 07, 2011 6:05 am
awesome build. quick question for you though, what grit sandpaper did you use to sand down the decals? did you wet sand? or dry sand?
PostPosted: Fri Apr 08, 2011 5:59 am
Denzity:
Thanks. I haven't ridden the bike a ton due to work and weather, but have commuted on it a little bit. Once summer arrives I will hopefully be riding it a lot.
Balayeur:
With the paint/decals I usually started around 200grit moved to about 600-800 grit as I got closer to the primer and raw carbon. I mostly did wet sanding. If you search around the forum there are some excellent write-ups on the process here on Weight Weenies.
Other Bikes:
PostPosted: Tue Apr 12, 2011 7:12 am
Wow, awesome build! I'm very impressed how budget conscious the whole thing is as well.
Range || range.wordpress.com
Asterisk*Cycles
'10 Velocite Millennium Elite SRAM Red
'11 Velocite Geos w SRAM Red || '08 Giant Anthem X0 w SRAM X0 || '93 Pinarello w Shimano 105
PostPosted: Tue Apr 19, 2011 9:00 am
I am impressed and full of ideas.... :shock:
TREK Madone 5.9 SL
COLNAGO C50 nl12
PostPosted: Thu Apr 28, 2011 7:31 am
So since Sram Red Black is now available, I am thinking of switching to it. I have done a poor PS job of the bike from my first photo shoot with the two different derailleur options.
Should I "Make the Leap" to Red/Black?
Regular Red
Red Black (Photoshop)
Other Bikes:
PostPosted: Fri Apr 29, 2011 5:03 pm
Stem= Syntace => Extralite ;)
www.aromadiff.com
PostPosted: Fri May 06, 2011 11:02 pm
Tried filling the tires with helium?
Specialized Allez 06' "Rain Bike" 21.50lbs
Neuvation F100 11' "Road Bike" 16.80lbs
Specialized Tarmac Pro 11' "WW Bike" 14.25lbs
There are no new unread posts for this topic. Mr. Black #2 - Super Weenie Budget Build Round 2
Comanche_man
20
7270
Fri Dec 09, 2016 2:07 pm
gtinut View the latest post
There are no new unread posts for this topic. Budget Non-carbon WW build
topflightpro
Tue Jan 24, 2017 10:09 pm
raisinberry777 View the latest post
There are no new unread posts for this topic. Attachment(s) LeMond Reynolds 853 budget build
Johnny Rad
Thu Mar 02, 2017 12:57 am
Johnny Rad View the latest post
There are no new unread posts for this topic. 2012 48cm CAAD10 w/Ultergra 6800 7.2kg (Budget build)
edbach
Thu Aug 04, 2016 6:10 am
livestrong1986 View the latest post
There are no new unread posts for this topic. Caad12 Black Inc. Build
[ Go to page: 1 2 3 4 5 ]
raffit78
66
6939
Mon Apr 24, 2017 4:09 am
raffit78 View the latest post
Users browsing this forum: gb103, ianeire, silvalis, tibikeboy and 20 guests
