Post new topic Reply to topic  [ 1315 posts ]
Go to page Previous  1 ... 70, 71, 72, 73, 74, 75, 76 ... 88  Next
PostPosted: Fri Feb 01, 2013 11:02 am
Berk wrote:
which material is for the rods can I see on right table?
PostPosted: Fri Feb 01, 2013 11:18 am
Carbon Cowboy
Most of them are wooden, some metal etc.,...it's just to make the prototype out of wood/metal, to have a model to make sure how it should turn out...for example, even Parlee makes first some wooden models:
jgrano wrote:
Did you use any kind of special epoxy while working with the brake surface on that rim? It looks super smooth.
Yes you are right, I use a different resin that can hold higher temperatures. Here just another photo from a different angle, it was photographed so that you can see the reflection of the repaired part:
Berk PROTO-TYPE Composites - Handmade In Slovenia
Berk Composites
PostPosted: Fri Feb 01, 2013 12:54 pm
Carbon Cowboy
And a new prototype product: spring for AX Lightness brake
This one on the photo is too stiff and still some more material that can be removed...but anyway, the weight is only 1.5g
As soon as this one is tested I'll see how to continue...my aim is to make it <1g, and I think that it should be possible.
For example, one spring weights as much as one piece of these:
So a pair of springs would weight the same :mrgreen:
Berk Composites
PostPosted: Fri Feb 01, 2013 3:39 pm
Berk, I really like all the things you are doing. You are very talented and dedicated. I hope you make those ax springs available, I am interested, and close to one gram each is fantastic.
PostPosted: Fri Feb 01, 2013 7:53 pm
Jure, did you cure the repaired wheel? Last time I looked into doing brake track repair, I was given the rule of thumb that for resins usually curing temperature is the same as max allowed operation temperature.
Bikes: Raceur, Beateur
PostPosted: Fri Feb 01, 2013 11:34 pm
Carbon Cowboy
@donald
Thanks for the compliments! I'll keep you updated here how it turns out. But I think that most probably it will be possible to make it even lighter, just want to make sure how this will turn out.
@wassertreter
It's not always like that - already some "basic" epoxy resins that can cure at room temperature can hold up to 80°C, depends of course from the resin.
I did cured it, but not on +200°C because I would damage the wheel...as you mentioned the biggest problem is the temperature that you can reach while braking (up to 300°C on the brake track). For the repair I actually don't really use an epoxy that is used for laminating some parts, but I could almost say it's a special glue, that can hold higher temperatures. So that's the "tricky part" of it. And I'll just stick with that method because it turned out very well.
Berk Composites
PostPosted: Mon Feb 04, 2013 2:15 am
Berk,
what do you think about making a carbon spring that doubles as an aero cover for some EEbrakes?
PostPosted: Mon Feb 04, 2013 2:23 am
the spring looks kinda thick, i´d suggest to made it thinner but even wider in the "bowpart" (from the front to the back - if you know what i´m talking about)
with this you can get them softer but without breaking right away
PostPosted: Mon Feb 04, 2013 10:17 am
Carbon Cowboy
thisisatest wrote:
Berk,
Most probably it would be possible, but I didn't yet had those brakes in my hands. If I could get some then I could probably find a way how to make an aero cover for them. But unfortunately I don't know anybody in Slovenia who would have these brakes.
@Fuchspk
Yes I made it too thick, and that's why I made the springs then so thin (they were wider). I know what you mean and it's for sure the right way. I'll see how this will turn out (regarding the stiffness) and will then make some new prototypes.
Berk Composites
PostPosted: Mon Feb 04, 2013 12:22 pm
Berk wrote:
@Fuchspk
yes there is always a lot of testing for the right way of lightweight springs :)
I would take almost just UD on the bow and something like 1x100g 90/90matt on the top of it as there is no torsion on the spring.
and have the part to the screw just in 90/90 2or 3times 100g matt with 1going over the bow and one even going under the bow a bit.
and look that on the tipps of the bow really are some 90degrees UD of the 100g matt (otherwise have some extra there)
But this is a lot of work for almost nothing. You can come down to maybe 1,2g i guess. Some other People have gone to glasfibersprings as Glasfiber seems to be a bit better for a Spring. but then it become heavy again and there is almost no point for making this kind of work instead of just taking an titanium spring instead.
PostPosted: Mon Feb 04, 2013 12:30 pm
Carbon Cowboy
I'll see what I can make with it and will keep you updated.
Otherwise almost all the structure is UD, only the "beauty layer" is plain. The "neck" of the spring is a bit more reinforced because I already saw quite a lot of these springs that broke on that part. Anyway, I'm interested how this will turn out. Unfortunately I can't test them by myself because I don't have these brakes, but we'll see in a few weeks how it will perform.
Berk Composites
PostPosted: Mon Feb 04, 2013 3:20 pm
Well I am not close but I would be more than willing to send you a pair of EE brakes so that you can try a spring for them in carbon and of course aero covers. Let me know if you would like them sent and I can do that. I am a huge supporter of your work as you know so I have no issues taking them off my build for a while so that you can do your magic.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Mon Feb 04, 2013 11:14 pm
Carbon Cowboy
Thanks for the help BmanX, really appreciate that :beerchug:
I'll first see if I can get them in my hands within EU, unfortunately our customs tax even gifts outside EU..well in most cases they don't care at all if it's a gift, and when you get a real gift you even have to pay for it in most cases ...anyway, I'll see if I'll be able to get them in my hands and if it would be possible. My first idea was to laminate some neodim magnets in the aero cover, and then just put it on the brake...probably that would be the most simple way and even very lightweight..just an idea :mrgreen:
Berk Composites
PostPosted: Sun Feb 10, 2013 9:00 am
Berk wrote:
Thanks for the compliments @Bianchi10!
@Dimitri
I finally made some progress on the saddle rails and hopefully I'll be able to make them in February, I'll for sure let you know
Otherwise here just one quick photo of my bike, 6.16kg as it is:
Could change the ALU bar and stem to save some more weight, also the bottle cages and tires,..but at this moment it is like I want! Ready for 2013 :thumbup:
What handlebars are these? And what size?
Thanks!
PostPosted: Sun Feb 10, 2013 10:03 am
Carbon Cowboy
Ritchey WCS Logic II, matte black aluminium, 42cm (c-c).
It may look a bit strange because the angle of that photo, but they are my favourite bars. I already had the SuperLogic (190g), but still prefer ALU (242g). If possible I'll try some day the Ritchey Curve bend...I already tried the classic bend but don't like it. By the way, the stem is Ritchey ALU C260 in 130mm.
Berk Composites
Post new topic Reply to topic  [ 1315 posts ]  Go to page Previous  1 ... 70, 71, 72, 73, 74, 75, 76 ... 88  Next
Users browsing this forum: Alexa [Bot], Exabot [Bot], Google Adsense [Bot] and 26 guests
There are no new unread posts for this topic. Edge/Enve Composites Aero Fork
dcl10
Wed Mar 06, 2013 6:06 am
dcl10 View the latest post
There are no new unread posts for this topic. What type of headset do I need?
in Cyclocross / Touring
chiltonp
Wed Jul 11, 2012 10:17 pm
rockdude View the latest post
There are no new unread posts for this topic. Tune Sixpack Hex type BB?
in MTB
ChrisZ
Tue Sep 18, 2012 8:56 am
ChrisZ View the latest post
This topic is locked, you cannot edit posts or make further replies. What type of Cannondale frame is this?
havana
Sun Apr 07, 2013 9:07 am
havana View the latest post
There are no new unread posts for this topic. xtr m970 vs m980 e type
in MTB
02GF74
Fri Nov 23, 2012 10:34 am
02GF74 View the latest post
It is currently Sat May 18, 2013 10:20 am
