Post new topic Reply to topic  [ 177 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 12  Next
PostPosted: Sun Jan 30, 2011 6:35 pm
Love the dash of orange!
viewtopic.php?f=10&t=81983
PostPosted: Fri Feb 04, 2011 4:48 pm
decided to sell the unbranded wheels which i couldnt fix without having changing rims.
so decided permanently use an easton ec90sl which i already have.
here's the updated build.
and also decided to use the short stack headset cap so cut the steerer a bit more, leaving just enough to still be able to use the original acros headset.
you cant buy fitness, but you can buy advantage.
PostPosted: Sat Feb 05, 2011 11:17 am
sweet ride man top notch!
PostPosted: Mon Feb 07, 2011 3:00 am
Absolutely perfect - everything. Thanks for sharing this with us!
PostPosted: Thu Feb 10, 2011 2:20 pm
How do you preload the headset bearings using that arrangement?
Can the Eastons be debadged?
Still great looking ride.
PostPosted: Fri Feb 11, 2011 1:39 am
-the steerer cap is goes in pretty tight inside the steerer tube so i just use it as a preload. so far no problems. can also use a 1 1/8 expanded plug with a shim but havent tried it yet.
-no the eastons cant be debadged without scraping the clear over the decals.
PostPosted: Fri Feb 11, 2011 4:45 am
The bike looks great! I personally loved it with the 20mm tubbies, I am kinda prefer the old school in the wheel department.........I have just ordered a set which are the exact same or similar. Have you put many miles on yours? What are your thoughts??
PostPosted: Fri Feb 11, 2011 4:55 am
should be around 2000km put in.
aside from being light (908g for pair) and nice if the road goes upward and holds well in descents with good braking (xiamen sports 210g rim with swisstops), i personally think they lack the momentum or follow-thru to hold speeds in flat. compared to the ec90sl or the previous unbranded 50mm, just a little coasting and the bike slows down significantly. probably a combination of lack of weight and shape/depth of the rims.
PostPosted: Sat Feb 12, 2011 11:08 am
this just keeps getting better...
+1 for decal removal :thumbup:
i like people... i just can't stand assholes
PostPosted: Sat Feb 12, 2011 11:19 am
if i have to remove the decals, then might just as well use an unbranded wheelset. :wink: i have 2 here so if i need the stealth fix, ill just switch them on. :D
PostPosted: Thu Feb 17, 2011 1:55 pm
:up: :arrow: the bike is awesome. did you do the custom paint of sram red by yourself?
PostPosted: Fri Feb 18, 2011 12:57 am
@aaron- thanks! yes, a little sanding and masking, 3 spray cans (white, black and clear) and lots of patience. :wink:
PostPosted: Fri Feb 18, 2011 11:08 am
:up: can you help me to custom mine?
PostPosted: Fri Feb 18, 2011 12:45 pm
are you sure you want to part with your levers and rd for more more or less 2 months and send it all over to asia for a hobbyist who works only on his free time to work on it?
:mrgreen:
PostPosted: Fri Feb 18, 2011 4:42 pm
:welcome: i have two sets of groupset. will it be heavier or lighter after customizing? and where do live though?
Post new topic Reply to topic  [ 177 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 12  Next
Users browsing this forum: etownfwd, Kam0916 and 32 guests
There are no new unread posts for this topic. Attachment(s) 2012 Canyon Aeroad CF Di2 - 6.250 grams (new pics - page 7)
[ Go to page: 1 ... 5, 6, 7 ]
Juggler
97
18554
Sun Mar 24, 2013 10:27 pm
Martin.F View the latest post
There are no new unread posts for this topic. Help with Canyon Ultimate AL
lone wheeler
13
1251
Thu Jan 10, 2013 7:43 am
lone wheeler View the latest post
There are no new unread posts for this topic. Attachment(s) Canyon Ultimate CF SLX
da123
15
3252
Sun Apr 28, 2013 11:33 pm
Valy View the latest post
There are no new unread posts for this topic. Canyon ultimate al
Patrickh
Sun Jun 10, 2012 8:36 pm
Machinenoise View the latest post
There are no new unread posts for this topic. Canyon Ultimate CF 6.8kg
EKIMIKE
Mon Sep 17, 2012 9:23 am
el condor View the latest post
It is currently Wed May 22, 2013 7:01 pm
