It is currently Fri Feb 24, 2017 11:03 pm
Post new topic  Reply to topic  [ 177 posts ]  Go to page Previous 1 2 3 4 5 612 Next
PostPosted: Thu Dec 16, 2010 4:09 am
NextRiot wrote:
When you say you sanded and refinish those 50mm rims, what did you do to refinish them? Interested in your process.
Was it similar to what you did with the seatpost?
yes similar steps. although on the rims, i had to sand off most of the clear coat unlike the saddle and seatpost where i just 'matted' the gloss layer.
rims are actually 12k so sprayed black over, before spraying matte clear again.
right now, brake tracks of course doesnt look as good after the miles, now in the process of sanding and spraying it again but this time, will just mask off the sanded brake tracks.
you cant buy fitness, but you can buy advantage.
PostPosted: Thu Dec 16, 2010 4:13 am
BrianAllan wrote:
Those photos are fantastic. I'd love to know what you shot them at/with + your lighting technique.
also, the bike is stunning.
thanks for the compliments on both. :wink: ND90, 50mm 1.8, shot outside with available daylight.
PostPosted: Fri Dec 17, 2010 8:33 pm
Thanks Farm,
easily one of my favourite bikes on here, i really appreciate that you got that weight without using any super fancy boutique brands.
PostPosted: Sun Dec 19, 2010 7:01 am
Hey farm_lim,
Can you tell me what kind of paint stripper you used on the stem? I am thinking of doing that to my 3T ARX team stem.
Thanks! :thumbup:
PostPosted: Mon Dec 20, 2010 7:31 am
dwn2sk8 wrote:
Hey farm_lim,
Thanks! :thumbup:
a local solvent-based paint stripper labelled appolo.
PostPosted: Tue Dec 21, 2010 12:54 am
This is so good...it hurts.
2005 Moots Compact SL
2010 Tarmac Pro SL
PostPosted: Mon Dec 27, 2010 9:40 pm
farm_lim wrote:
(thanks for the tip rasmusic!).
No problem :)
Nice bike, but you should really get a black faceplate for the stem.
Canyon Ultimate CF SLX
PostPosted: Sun Jan 02, 2011 2:13 am
Location: Lima, Peru and occasionally in the Washington DC area.
:unbelievable:
Fantastica.
:unbelievable:
PostPosted: Mon Jan 03, 2011 3:37 am
thanks everyone for the votes!
will post newer pics with some updates soon!
PostPosted: Fri Jan 07, 2011 5:33 am
looking to further drop the 16mm headset cone spacer to around 5mm. can order a special cap (not in the website, but there is) from canyon, but costs eur120 shipped to asia. :shock: :shock:
so ill have this made by the local machine shop in t6 al, probably for just a song. next step will be how to anodize something this small, as there's none locally that does small parts.
will post pics when done.
PostPosted: Tue Jan 18, 2011 7:31 pm
the 5mm headset cap done by the local machine shop, minus the o-ring slot from the drawing. will post pics once installed.
@murphs, will PM you the contact details of the guy.
PostPosted: Fri Jan 21, 2011 3:26 pm
installed the short stack headset cap already. will ride and decide wether to cut the remaining steerer since once cut, cant use the original internal-locking headset cap anymore.
PostPosted: Fri Jan 28, 2011 3:22 pm
What size frame is this? 52 or 54cm?
With the stem: after applying the stripping solution what did you scrape it off with? Did you have to do anything else to get a good finish?
PostPosted: Sat Jan 29, 2011 10:40 am
Absolutely delicious!
If my Addict turns out half as good I'll be thrilled!
:thumbup:
"When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much the old man had learned in seven years."
Josh Billings
PostPosted: Sun Jan 30, 2011 1:19 am
52.
after 2x paint stripper, just cleaned it after with lacquer thinner. didnt spray or paint anymore. its anodized back under the ritchey paint.
There are no new unread posts for this topic. Bh ultralight evo sram red etap new pics & updates page 3
bmCube
38
5185
Fri Sep 23, 2016 7:15 pm
bmCube View the latest post
There are no new unread posts for this topic. Canyon Ultimate SLX
Guest
Sun Jul 24, 2016 11:50 pm
Kayrehn View the latest post
probertsqbe
10
2750
Wed Jan 11, 2017 11:18 pm
probertsqbe View the latest post
There are no new unread posts for this topic. Canyon Ultimate EVO
lovemyway
28
3706
Fri Feb 10, 2017 8:13 pm
reedplayer View the latest post
There are no new unread posts for this topic. Canyon Ultimate SLX (M)´2016
Kesselflicker
10
3190
Thu Jan 19, 2017 3:13 pm
nonamed View the latest post
Users browsing this forum: gerryc89, hlvd, Sizzler, victaras, Yahoo [Bot] and 25 guests
