Post new topic Reply to topic  [ 90 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Sat Sep 01, 2012 3:29 am
This is amazing. You've reached another level (or two) with the recent upgrades.
PostPosted: Sat Sep 01, 2012 3:24 pm
Dear lord that looks amazing. Seems incredibly aero
PostPosted: Sat Sep 01, 2012 3:35 pm
Very slick and stealthy... :)
But isn't the cable work quite a hassle? I have heard some complaints about the internal cable routing...
2012 Canyon Aeroad CF 8.0 Di2 (6.250 grams)
2010 Canyon Grand Canyon F6
2012 (2013?) Canyon Speedmax Evo (is ordered)
PostPosted: Sat Sep 01, 2012 5:31 pm
The only issue with the cabling is when it exits the bottom bracket but there is a trick to this and the fact that I did the behind the stem internal routing myself made it easier than the newer S-series when cabling. Not really any hassles.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Sat Sep 01, 2012 5:36 pm
It must be the newer version I have heard about... the guy I talked with had big issues with his RD.
PostPosted: Sat Sep 01, 2012 5:38 pm
very easy to do it on my own but yes I have heard stories of it being difficult. really the whole at the BB is damn small but I sorted it out.
BIG DADDY B FLOW
PostPosted: Mon Sep 03, 2012 4:28 pm
That seals it. I give up on sub 13lbs. The brakes clean up the frontal area of the bike a ton. It sucks I'll have to buy two. I would rather use my lighter C7 brake, but it just didn't feel right with the two different brakes. The modulation feel of the two, were way different. I don't think the aero of the rear is even that big of a factor, but having similar modulation fr and rr is. My does that ever look fast as hell. With my Zipp bars it will be even more awesome. You need to buy a set you know.,,,,
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Mon Sep 03, 2012 4:42 pm
I have almost bought them 3 times now but cannot pull the pin because I want to be able to use clip ons when I do some longer rides and if I race again. That is the only thing stopping me. Rob and I have talked about a custom stem with internal run cabling for the Omega which would clean up the front end even more. One day I will just say hell with it and buy something aero for the bars but I still think someone could design something better and more integrated then 3T's attemp. Not very aero in my opinion.
BIG DADDY B FLOW
PostPosted: Mon Sep 03, 2012 5:05 pm
I'm not going to tell you how to live your life, but this is what needs to happen here. I need your brakes, you need my bars, and then we both need to build TT rigs. You know I am right. :wink:
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Mon Sep 03, 2012 7:27 pm
I have a build on the trainer totally done up as a tt build but using an older TCR frame. I can get in a great position on this bike and it has an Omega on the front with an EE on the back so I technically have a TT bike to ride BUT it will never be as aero as the SLC.
BIG DADDY B FLOW
PostPosted: Mon Sep 03, 2012 7:48 pm
I've been thinking long and hard about building one. Since taking to running, I know what that can lead to next. I've really just always wanted one anyway. I am thinking Speed Concept or some sort of P series.
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Mon Sep 03, 2012 7:53 pm
P series and just do what I did tot he SLC. Only difference I would suggest is getting a Devox for the front end and running Sram shifter and levers.
BIG DADDY B FLOW
PostPosted: Tue Sep 11, 2012 1:46 am
Well it seems like someone has been listening to what I am saying but it looks like it is going to cost me north of $1000 to own them.
BIG DADDY B FLOW
PostPosted: Tue Sep 11, 2012 2:58 am
Could you post some pics on how you exited the shifter cables out of the bottom bracket?
http://www.hackracer.com/
PostPosted: Tue Sep 11, 2012 3:13 am
They exit the standard way through the hole under the BB.
BIG DADDY B FLOW
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
Users browsing this forum: alfredox5, deltree, fitty4, Google Adsense [Bot], poppiholla and 27 guests
There are no new unread posts for this topic. Cervelo R5 VWD - What's it like ?
roadiesean
Sat Oct 27, 2012 2:38 am
spandexboy817 View the latest post
There are no new unread posts for this topic. Cervelo R5 13.8 lbs
spandexboy817
Fri Mar 29, 2013 5:42 am
There are no new unread posts for this topic. My Cervelo Rca
normcorriveau
22
2167
Wed May 15, 2013 7:26 am
PSM View the latest post
There are no new unread posts for this topic. Cervélo S-5 VWD
shoopdawoop
26
6938
Wed Apr 17, 2013 9:00 am
Andrew69 View the latest post
This topic is locked, you cannot edit posts or make further replies. Cervelo S2 & S3
JBV
Fri Feb 01, 2013 10:34 pm
NGMN View the latest post
It is currently Tue May 21, 2013 11:51 am
