Post new topic Reply to topic  [ 90 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Apr 19, 2012 6:07 pm
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Wed Apr 25, 2012 5:40 pm
You should be getting a package. Any day now......
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Wed Apr 25, 2012 6:00 pm
Canada Post SUCKS
BIG DADDY B FLOW
PostPosted: Mon Apr 30, 2012 5:48 pm
Canada Post does not suck so much today. Now I have to wait for another 5 hours before I can get home and start to grind metal and get a finished weight.
Yes it is finally here. Now I just need to gently remove some metal from the bottom of the post and install it.
BIG DADDY B FLOW
PostPosted: Mon Apr 30, 2012 7:20 pm
Love it !!!
www.aromadiff.com
PostPosted: Mon Apr 30, 2012 10:38 pm
Looking good BMANX! That is just what I was wanting to see when I clicked on this thread.
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Mon Apr 30, 2012 11:24 pm
5880g with the new saddle/post combo. The bike is not the way it will be when finished so I will save pics and final weight until I get the OMEGA brakes installed.
BIG DADDY B FLOW
PostPosted: Tue May 01, 2012 3:27 pm
The inner weight weenie is battling my aero weenie and I know if I switch out my full aero rings for my normal rings I could get my build under 5800g but having a sub 6000g aero weight weenie build is pretty cool as well.
BIG DADDY B FLOW
PostPosted: Wed May 02, 2012 4:40 pm
I can relate. I think similar things about a Tri-Rig brake or a Scapula F. The fork would get me down to your weight, and possibly beyond. :shock:
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Wed May 02, 2012 4:46 pm
I also think that going with the newer Cervelo forks would be more aero as well but I have been told they are pretty heavy.
BIG DADDY B FLOW
PostPosted: Wed May 02, 2012 5:01 pm
plus they don't fit right on our frames. they look silly.
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Wed May 02, 2012 5:13 pm
Actually I believe that the FK26 does fit but the FK25 does not. Both are more aero than the 3T.
BIG DADDY B FLOW
PostPosted: Wed Jun 27, 2012 4:02 am
Omega's arrived today. Installed and tested. I need to finish up the new shifter run before I can give this a good test which should be on Friday I hope. Work in progress. Crap cell phone pics sorry.
5950g as shown but I can pull out a few tricks to lower the weight a bit.
BIG DADDY B FLOW
PostPosted: Wed Jun 27, 2012 4:58 am
Looks great brother. What were your thoughts on the Omegas? One thing I noticed, is they seemed to stop better the more times I used them. It's like they contact the rim at a different angle than other brakes or something, and it needed to establish a wear pattern before it worked best.
Cervelo S2(5888g)
Trek 5200(7050g)
PostPosted: Fri Aug 31, 2012 10:49 pm
There are a couple of things I need to fix like adding 1-2 links in the shifter housings to allow the front wheel to turn 90 degree each way but I left enough liner to do so. Also need to shim the brakes a bit on the rear so that the toe in is the correct way. It looks great and comes in at 5980g.
BIG DADDY B FLOW
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: cyclistcong, Google Adsense [Bot], hornedfrog and 22 guests
There are no new unread posts for this topic. Cervelo R5 VWD - What's it like ?
roadiesean
Sat Oct 27, 2012 2:38 am
spandexboy817 View the latest post
There are no new unread posts for this topic. Cervelo R5 13.8 lbs
spandexboy817
Fri Mar 29, 2013 5:42 am
There are no new unread posts for this topic. My Cervelo Rca
normcorriveau
22
2204
Wed May 15, 2013 7:26 am
PSM View the latest post
There are no new unread posts for this topic. Cervélo S-5 VWD
shoopdawoop
26
6948
Wed Apr 17, 2013 9:00 am
Andrew69 View the latest post
This topic is locked, you cannot edit posts or make further replies. Cervelo S2 & S3
JBV
Fri Feb 01, 2013 10:34 pm
NGMN View the latest post
It is currently Thu May 23, 2013 5:03 am
