Post new topic Reply to topic  [ 54 posts ]
Go to page Previous  1, 2, 3, 4
PostPosted: Sun Jan 20, 2013 6:17 pm
Remove the Reynolds decals and you 're set! :thumbup:
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
PostPosted: Sun Jan 20, 2013 9:50 pm
Think so? I happily removed half of the stickers years ago, but stubbornly left these on. A couple are now starting to peel at the edges. :noidea:
Guess it's one or two more grams that can be saved...
Leave It On The Road - cross country charity ride to raise $ and awareness for colon cancer
My sub-5.6kg / 12.32lb Addict R1
PostPosted: Sun Jan 20, 2013 10:56 pm
When I stripped my EDGE/ENVE it saved 8g :wink:
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Sat Mar 02, 2013 6:07 pm
Congrats on the new weight! great job. It looks like your custom paint on the leavers is holding up nicely too.
6,251g (Clinchers) Scott Addict R1 Sold
6,432g Colnago M10 Sold
6,432g Wilier Cento 1 SL Sold
PostPosted: Mon Jun 03, 2013 3:11 am
Now that I've got some miles on my Madfibers clinchers (1304g), here's my early observations based on my modestly calibrated arse and in comparison to my Reynolds Assaults (saved just over .4lbs) and Attacks (saved just over .2lbs):
* From a stop, the MF's don't feel feel any faster
* Once underway, they accelerate faster
* Definitely hold speed better, putting me 1-2 gears ahead of my usual pace
* Distinct yet gentle, controllable pushes in crosswinds and from buffeting from passing cars
* Cool "swooshing" sound when I'm kicking out of saddle and throwing the bike from side-to-side just like I remember from an old pair of DV46UL tubies
* Definitely some unconcerning hollow sounds emanating from the wheels underway when I roll over small obstacles plus what I think are pinging/popping noises from the spokes loading and unloading when I'm kicking out of the saddle (some MF users have the same)
* I'm not saying fit and finish is poor, but calling these an industrial look is kind … these won't win any beauty contests
Looking at these pics, I clearly need to de-badge them - I'll do it once I'm sure that I'm keeping them. I still think my bike looks 43x better with the mid-depth Attacks (32mm) than the super deep Madfibers (60/66mm). Oh, the things we'll do for saving a gram or three!
Sadly, I went back to butyl tubes (Schwalbe 80mm super lights, 79g/ea) because my earlier experiment with valve extensions went so poorly (I admit probably my fault). It's been nice not having to pump up the tires before each and every ride, but I miss the thought of riding latex.
Garmin 500 bar mount from Raceware Direct:
* Love it and won't go back to the OEM stem mount again despite the ~13g weight penalty
* Took some mental adjustments (just my mind playing tricks on me with the dramatically different new mounting location)
* Holds the Garmin tightly and installation is a complete non-issue
Aicans brake cables w/EE brakes and Alligator Mini I-Link shifter cables:
* Aicans powered EE brakes are everything they're supposed to be - powerful and easy to modulate. I don't miss my SRAM Red brakes at all; not one bit.
* It's been non-stop cable stretch with the Alligator Mini I-Links requiring near constant fiddling whereas my Yokozuna shift cables were a "set and forget." The Mini's are "out" next time I need bar tape. Bring on the Yokozunas - I'm going back!
PostPosted: Mon Jun 03, 2013 5:57 pm
You can't be serious! Looks good... but... MadFibers? Ultremo ZX? Aicans?
I swear this is either some form of identity theft or twins separated at birth.
My recent purchases for my '09 Addict - haven't updated on WW yet but it's almost done:
even the photos look similar)
I got the stealth version though with ceramic bearings - shweew - something different!
My Addict SL : 5???g (in progress)
My Addict RC: 5490g
My Cycling Blog
PostPosted: Tue Jun 04, 2013 3:27 am
I might be a stalker. I'm not saying, I'm just saying.
You got the latest hub design, ceramic bearings, better stickers and came out 15g lighter on top of all that - plus you're a better cinematographer than me, so you've got that going for you.
PostPosted: Tue Jun 04, 2013 4:10 am
Ok, I thought yours might be standard bearings at first... but what's with the silver vs black freehub? 6 grams and some anodizing I suspect.
And I should point out that you are doing it all wrong with the Reynolds Blue pads... I know because I am also doing it wrong with Reynolds Blue pads. Maybe we should both switch to the required cork pads for the lawyers watching. But I really bet the Blue perform better and have just as low temps, so I'm not rushing.
Have you blown off a tire bead yet? I tried to run lightweight butyl tubes and had a blow out once. The achilles heal of this rim I think. Maybe your standard Schwalbes are a better option. With the right tire/tube combo it probably isn't an issue. I have a hors d'oeuvre platter of several fresh tube varieties on the way to sample.
Did you install the 'wheel balancers'? I only figured out what they were until this weekend... 2 months later.
My Addict RC: 5490g
My Cycling Blog
PostPosted: Sat Jun 08, 2013 1:40 am
No balancing weights needed so far. I wonder if that's mainly for the much lighter tubies.
Yes, I only use the MF-supplied brake pads. I wouldn't dare use other pads. It's by the book for me. :smartass: Here's hoping MF makes allowances for better alternatives. My only experience with cork pads (original Zipp Tangentes) left me feeling they only moderated speeds and lightly at that.
It's been Schwalbe "extralight" 80mm butyl tubes for me at ~79g/ea. For rapid roadside replacements when I'm far less cautious during installation, I ordered up some no-name 80mm butyl tubes. Guess what ... those half-price cheapies weigh 66-67g/ea! WTF?! We'll see if they're quality or not, but I wonder if I just got taken by Schwalbe's marketing so-called genius.
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4
Users browsing this forum: Google [Bot], jbaillie, Rogue and 23 guests
There are no new unread posts for this topic. My fleet (Scott Addict RC, Scott Addict CX, Haibike End...)
superb
Tue Mar 05, 2013 11:01 am
superb View the latest post
There are no new unread posts for this topic. Scott Addict R2
lyot
7
897
Fri Feb 22, 2013 9:20 am
lyot View the latest post
There are no new unread posts for this topic. Scott Addict R3
ukracer
Tue Jan 01, 2013 9:44 pm
ukracer View the latest post
There are no new unread posts for this topic. Scott Addict RC
paradawt
Sun Jun 16, 2013 9:23 pm
paradawt View the latest post
There are no new unread posts for this topic. New Scott Addict spotted!
record
16
2260
Wed Apr 03, 2013 5:33 am
eric01 View the latest post
It is currently Wed Jun 19, 2013 6:40 pm
