Pictures of Colnagos
Moderators: maxim809, Moderator Team
Yes, definitely fix the handlebar angle but nice to see a traditional C60.
but the drops are parallel with the top bar and with the stem which looks great! and the guy has done 600 kms on it and seems to like it like this. actually they could rotate back up slightly and be even better aligned.
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
stormp - can you explain that more. how can the drops (is that what the bottom is?) be parallel with the crown tube? have you got a diagram of what you are describing or an example perhaps?
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
He means rotate the bars counterclockwise about 5 degrees so they are parallel with the fork crown (the gap between the fork and the headtube). I would personally rotate slightly less than this, so the drops are parallel with the ground
i see, that's interesting because it sounds like a bit of a setup guideline.
until recently i aimed for a flat run from bar to lever, with the lever placed so as to extend that.
it does look good though when the drop is parallel with the stem and also with the top tube (which would also be ground in this case). be interesting to hear from the OP if current placement is his preference or just happenstance?
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Current setup is definitely not parallel with the top tube, photoshop says it's around 2 degrees past horizontal
PSM wrote:ross wrote:Current setup is definitely not parallel with the top tube, photoshop says it's around 2 degrees past horizontal
+1
It is -2 now. Should be +2.
Thanks guys, for pointing this out. Parallel to ground now
