Scalpel 2009 BBQ 7.960kg ECLIPSE tupes
- Robin v Berkel
FRAME :Cannondale Scalpel BBQ 2009
FORK : Lefty carbon SL1 110mm 1190 88+
SHOCK : Dt-swiss SSD carbon + chims 155gr
STEERTUPE: custom made carbon steer tupe 83gr
HANDLEBAR : AX-lightness 56cm 69gr
STEM: Extralite UL3 100mm 87gr
SADDLE : Tune concorde 60gr
SEATPOST: Ax-Lightness Daedalus 27.2 / 350mm rider limt 90kg 137gr
SEATPOSTCLAMP: B-T-P carbon 5gr seatpostclamp
BREAKS: Formula carbon R1
DISC FRONT: Scrub Rotor 160mm 56gr
DISC REAR: Scrub Rotor 140mm 42gr
BOLT: Tune skyline MTB bouten 13gr
SHIFT HOUSING Shimano SIS SP41
SHIFT CABLE PowerCordz
SHIFTER : Sram XX triggers 216gr
REAR DERAILLEUR : Sram Red 123gr ( tune )
FRONT DERAILLEUR: B-T-P Tune Campagnolo Record 10s 60gr Met B-T-P clamp
CASSETTE : Dura ace 7900 11-23 163gr
CHAIN : KMG X10 SL gold 240gr
CRANK: THM Clavicula DP + BB30 adapters 520gr+-
BB: THM-Carbones ceramic hybrid 71gr
CHAINRINGS : Extralite 44T 59gr
CHAINRINGS : Extralite 30T 28gr
PULLYS: Extralite Ultra Pulleys 10T 9gr
TYRES:Schwalbe Rocket Ron 2.1 388/394gr
INNER TUPES: ECLIPSE 54/55gr
PEDALS : Crank Brothers - Eggbeater 4ti 168gr
GRIPS : Extralite ultragrips 10gr
WEELSET: Dt-swiss XRC 1250 + lefty hub with ceramic bearings and 5gr ti bolt and rim tape = 1235gr
Last edited by Robin v Berkel on Fri Jul 30, 2010 5:14 pm, edited 47 times in total.
It's sad that those wheels are lighter than my road wheels....
Really excited about this build. A tips is to change the M4x15mm steel bolts on the twisters for alu ones, saved 2g when I did that.
/jonas l
http://instagram.com/jonaslundb
- Robin v Berkel
cerro wrote:Really excited about this build. A tips is to change the M4x15mm steel bolts on the twisters for alu ones, saved 2g when I did that.
thy are alu now so dont need do that any more
cannondale Rush carbon SL team 8.75kg/19.29 1x10
viewtopic.php?f=10&t=101405
old WW bikes
Epic carbon 2006 9.3kg
Spark 10 2008 8.2Kg
Anthem Adv 9kg ( solt after 3 weeks not done )
scalpel 2009 7.97kg
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
Ti bolts on the F99 stem for sure will drop that under 100g and you can go with 3 ti bolts and 3 aluminum bolts for the calipers.
You can also tune the RED rear derailleur down to 122g as I did on my road build.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
- Robin v Berkel
BmanX wrote:Ti bolts on the F99 stem for sure will drop that under 100g and you can go with 3 ti bolts and 3 aluminum bolts for the calipers.
f99 is onlye for short time for i go for UL3 stem
you got foto's what you doen on your sram red ?
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
Check out this link
http://weightweenies.starbike.com/forum ... highlight=
And this one.
And this one.
BIG DADDY B FLOW
- Robin v Berkel
cswi9367 wrote:will be interesting on how you get the red rear der to work with twist shifters. thats great.
it works this der was on my sprak 10 some time go
and how to get work is so easy need some glow + some alu or steel or ti
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
- Robin v Berkel
BmanX wrote:Check out this link
And this one.
thx for link
is spring in sram red Ti or steel ?
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
- Robin v Berkel
KCNC pulleys wil come and hope to save 4gr so i get red on 131gr and stil work for MTB
got noting to do so tune iner carbon cage normal it was 6gr now 3gr and sram red was 146gr now 135gr and stil strong
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
old WW bikes
Spark 10 2008 8.2Kg
scalpel 2009 7.97kg
Your parts last forever always new as the first day . Another lovely bike for sure.
