My light-bike, full suspension 8960gr (PHOTO'S)
i will do that as well - i have a piece of a broken tune carbon-seatpost and will use the upper- undamaged pipe to cut off that thing... i will prepare the surface, with contacts the saddle with cyanacrylat (industrial glue, makes a hard surface) to avoid damaging... lets see if it holds in fall...
The Crimson King wrote:gerardrev wrote:I tuned many of pieces, for exemple, I change the piece of seatpost, the original there are in aluminium, and I changed for a piece of carbon that I'm builted.
i'd be a bit scared of that .
sorry, I don't understand, you are scared for my bad english, or for the piece of carbon?
NoStyle wrote:i will do that as well - i have a piece of a broken tune carbon-seatpost and will use the upper- undamaged pipe to cut off that thing... i will prepare the surface, with contacts the saddle with cyanacrylat (industrial glue, makes a hard surface) to avoid damaging... lets see if it holds in fall...
slowly please , if you want tuned the seatpost, you have take the carbon of a tube of fork for exemple sid wc, reba wc, or others, because the carbon for a seatpost there is too fine, and this piece... broken.
Great bike.
Some riders remove the plastic stuf on the fork (located at the bottom). THis allow to save for free few grams.
(I don't know if it is a problem for the fork; pro riders do it, but... no risk for the lifetime of the fork?)
What is the weight of the crankset with the TA rings?
MORATI COMPONENTS WANTED! - MORATI ON FACEBOOK
nice built, some parts are realy cool as is the frame
But i still think it looks a bit fragile. Maybe it's because of the XL size?
Thierry wrote:Great bike.
It is actually rubber and weights next to nothing and it is there for a reason.
With out it the fork internals are very exposed from the ground.
Fuelled by kofein
- The Crimson King
gerardrev wrote:The Crimson King wrote:gerardrev wrote:I tuned many of pieces, for exemple, I change the piece of seatpost, the original there are in aluminium, and I changed for a piece of carbon that I'm builted.
for the piece of carbon i've seen some broken...i think is just too fragile for off-road use. you put your ride (and life) in risk for what? 0.7 g or something more...it's just senseless.
The ultimate italian weight weenie forum: Light Bikes Forum
L'unico forum italiano per i maniaci del peso: Light Bikes Forum
