Custom painted CR1 - 5,14Kg
FelixOr
by FelixOr
Hi folks,
let me present you my "new old" ride. After lots of hours in my cellar, sanding and repainting my Cr1 frame, I received the last parts today and finished the build-up.
I cannot describe how happy I am with the way everything turned. It's amazing to look at something that required such a big effort when it's finally done. Also, I wasn't even sure if I could finish it at all, but I'm more than satisfied with the result.
The bike is even lighter than before, although i expected the paint to add enough weight after the sanding-process, to make it much heavier.
Here's a short spec-list:
Component Weight(gr)
Bar Tape Ribbon Cork 31,6
Bottle Cages Tune Skyline 10,7
Bottle Cage Bolts Tune 4,3
Bottom Bracket THM 0
Bottom Bracket Shell+Bearings THM 73,2
Front Brake Zero Gravity 05 Ti 67
Rear Brake Zero Gravity 05 Ti 63,8
Brake Shoes Zero Gravity 05 Ti 29
Brake Pads Corima 7,5
Brake cables PowerCordz 10
Shift cables PowerCordz 8,5
Brake-cable housing Nokon 48
Shift-cable housing Nokon 61
Cassette KCNC 108,2
Lockring KCNC 4,8
Chain KMC X10SL 222,5
Missing Link KMC 2,4
Big Chainring Extralite Octaramp 65
Small Chainring Extralite Octaramp 28
Chainring Bolts Tune 9,2
Right crankarm THM Clavicula 197,1
Left crankarm THM Clavicula 145,4
Der. Front Record 55,3
Der. Rear Record 137,5
Shift/Brake Units Record 242,9
Ergpower Hoods BTP 18,7
Fork Look HSC5SL 287,5
Frame Scott CR1 917
Barrel Adjusters B-T-P 3,6
Cableguide Shimano 3,9
Handlebar plugs Cork 2,5
Handlebar Schmolke SL 173,4
Stem Syntace F99 102,6
Seatpost AX-Lightness Daedalus 118,2
Saddle Lotz Carbon 69
Seatbinder Lotz Carbon 5,8
Headset Extralite ScaleHead 48,6
Expander Schmolke A-Head Cap 0
Spacer none 0
Pedals Speedplay X-1 133,6
Grease and Anti-seize 15
Tires Veloflex Servizio Corse 413
Valve extensions Tufo 6,1
Wheelset Lightweight by CarbonSports 1148
Glue Conti 14
QuickReleases Tune 51
Complete 5164,4
The digital hanging scale says 5.14kg
Here are pictures of the complete bike:
You can take a look at some pictures of the painted frame here: http://fairwheelbikes.com/forum/viewtopic.php?t=2381 and at the sanding process here: http://fairwheelbikes.com/forum/viewtopic.php?t=1825
I hope you like the new look of it.
Grüße,
Felix
Kuiper
by Kuiper
Sooooó Der Felix, das isst ein sehr schöne fahrrad geworden. (in my best german)
oke but let's get back to english,
Well felix this turned out very beautifull I really like it!
what was the weight of the frame + fork before you removed everything?
Luc
by Luc
:shock: :shock: :shock: is all that comes to my mind right now...
Uber-classy, Felix !
Congratz ++++
Pollice verso.
currieinahurry
by currieinahurry
xxxxxxxxxxxxxxxxxxxxx for your bike!!
tikka
Skillgannon
by Skillgannon
Congrats - it seems likethe evolution of this bike has been happening for a while, but it looks like things may have approached their finale(for the moment), and I'm really glad you've got the bike to a stage where you're really happy with it. It's brilliant, and with all the work you've put into it, I hope you enjoy it. It's a great bike...To be honest, your making me jealous, to be able to put so much time and effort nto building and setting up your bike - it's not just a kit bike where the excel spreadsheet is the biggest extent of the work...its amazing :D
now all we have to do is put together a group sale for SRM's again :roll:
Hi|ikus
by Hi|ikus
That ride is ridiculously pimp!
Bravo Sir!
Shut up legs and do what I tell you!
RTW
by RTW
Dude, where are you?
I like the paint job, think it look very good. Better than we imagined. I think the mechs look a little odd though. They would either look better it is was carried through onto the brakes and the ergos, or if they were still stock.
That said, I know it is very difficult to make a decent judgement just from the pictures here, and you need to see it in person.
jeroen
by jeroen
Hey Felix
That bike looks so good and to me this is the nicest CR1 a have see in my live.
But I am happy for you that everything turned out so well after all the work you have done.
grtz jeroen
jalapeno
by jalapeno
very beautiful, good effort!
Gravitas est meus Hostilis
Painted Roads Cycling: http://www.paintedroads.com
Words: http://mikesimagination.wordpress.com
col hicks
by col hicks
:D like i said on fwb , i love it
TriRig
by TriRig
That is just SICK. Wow.
FelixOr
by FelixOr
Thanks guys, i'm glad you like it. The paintjob polarizes pretty much, and some members of other forums dislike it. :)
@Kuiper: The naked frame was 857 grams, the naked fork was 274. The weight of the frame with original paint was 915grams, of the fork 280grams.
@Skillgannon: :goodpost: Couldnt have said it better! Thanks buddy
@Rich: I think you may see it in person pretty soon :)
Thanks again for all the nice comments.
Here's a picture with the other drive-train setup:
520 Dan
by 520 Dan
how do you like the saddle?
