Post new topic Reply to topic  [ 25 posts ]
Go to page 1, 2  Next
 Post subject: my Caad9 Cross bike
PostPosted: Sun Nov 12, 2006 2:21 am
Here is my new Cross bike. 07' Cannondale Caad9 Si Cyclocross.
- Easton EC90x fork
- Si Carbon crankset with 34/46 rings
- Spooky Carbon brakes
- Ksyrium ES w/Panaracer Crossblaster tires
- Sram Force group with Record CT Front Derailleur
- FSA Plasma bar/stem and K-force lite post
- Arione Saddle
7185g/15.83lbs
I took it out this morning and it rides great. Very fast and responsive. The force is cool, it just takes a little getting used to. Weight is pretty good, I could easily make it a lot lighter, but It has a good stiffness/weight ratio.
 Post subject:
PostPosted: Sun Nov 12, 2006 2:27 am
wow I like that bike
 Post subject:
PostPosted: Sun Nov 12, 2006 4:22 am
nice.. i have force on my cross bike too, but how do you find the braking? mine isnt that powerful, but its my first cross bike so maybe its just cantilever brakes in general...
My CAAD 9 BB30
 Post subject:
PostPosted: Mon Nov 13, 2006 3:09 am
Well it really depends on your brakes. I had to switch from ceramic pads to a softer compund to get the brakes working well, It didn't have anythign to do with the levers... toe-in is also a factor. Besides that the force is good.
 Post subject:
PostPosted: Mon Nov 13, 2006 9:45 am
very nice bike. the weight is really good. how are your experiences with the sram-components?
why do you not have a dog-fang?
 Post subject:
PostPosted: Mon Nov 13, 2006 12:18 pm
xcfisher, I've got two totally unrelated questions for ya:
Firstly, how much toe-in do you use? I'm totally new to cross bikes, and while my front brake (R550) is hiddeously powerful, my rear does practically nothing.
Secondly, is there any 'cross racing left in So Cal by January? I'm thinking of visiting the family once my thesis is done... :D
 Post subject:
PostPosted: Mon Nov 13, 2006 1:37 pm
Nice! :D Does it handle nice or what? 8)
Here's mine:
 Post subject:
PostPosted: Mon Nov 13, 2006 6:11 pm
I use a lot of toe in. It seems to help with the power on the canti brakes... as for racing here, check out socalcyclocross.org for a full schedule. I think there are a few after the new year...
Musing- I have a dog fang, I just haven't put it on yet.
Thijsje- Great set up, I will be putting my alu Si cranks on this week. I am switching to a single ring set-up, 42t 130 pattern. It should drop another 200g off between the cranks/FD/Ring/cable ect.
 Post subject:
PostPosted: Mon Nov 13, 2006 6:13 pm
Thanks for the heads up!
I've got the brakes a tad better, but I need to work on it. It should be better with my tubular wheelset (with less worn rims) mounted.
 Post subject:
PostPosted: Mon Nov 13, 2006 6:42 pm
I have a pair of FSA carbon chainguides lying around, ready to be mounted but I'll stick with the double-chainring setup.
 Post subject:
PostPosted: Tue Nov 14, 2006 10:11 pm
WOW.... looking at the same bike myself..
what size is yours?? and how high are you?
...thanks
In the movie "The Matrix", Chuck Norris is the Matrix. If you pay close attention in the green "falling code" scenes, you can make out the faint texture of his beard.
 Post subject:
PostPosted: Wed Nov 15, 2006 2:48 am
Mine is a 50cm. I am 5'9"
 Post subject:
PostPosted: Wed Nov 15, 2006 3:58 am
wait, it is a 50cm center to center and you are 5"9'? That is WAY too small, unless there is something weird with sizing.
 Post subject:
PostPosted: Wed Nov 15, 2006 9:49 am
I´m 6,0 and thinking of the 54cm.... have you been out riding it yet?
does your feet rub the front tire (a little bit) in tight corners??? cause my ridley (52cm did that) and i was wondering since you have a small size, and are almost the same hight as me? i really like to be able to pedal trough some turns!
thanks for the help :D
 Post subject:
PostPosted: Wed Nov 15, 2006 7:05 pm
The sizing on the 50 is not the same as a standard road bike. It is not a measured 50. I ride a 52 road bike (at least in a cannondale) because of top tube length and standover. My inseam is only 29".
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
Users browsing this forum: 573, DaleRider, Exabot [Bot], maverick_1, roadieboy, Tom-s, viney, Zitter and 28 guests
There are no new unread posts for this topic. Felt F1x Cross Bike 14.28 lbs
sedluk
15
1418
Wed Apr 10, 2013 3:10 am
sedluk View the latest post
There are no new unread posts for this topic. Mtb chainset on cross bike???
dane476
Thu Nov 08, 2012 9:41 pm
eric View the latest post
There are no new unread posts for this topic. Will this work? (drivetrain for a cross bike)
lanierb
9
667
Thu Oct 18, 2012 8:08 pm
monty dog View the latest post
There are no new unread posts for this topic. Attachment(s) Winter bike project: ALAN Alu Cross (finished P. 2)
SWijland
23
5119
Thu Dec 27, 2012 12:24 pm
SWijland View the latest post
There are no new unread posts for this topic. CAAD9
jdp211
Fri Sep 21, 2012 6:06 am
xFree View the latest post
It is currently Wed May 22, 2013 3:47 pm
