It is currently Wed Apr 26, 2017 10:57 pm
Post new topic  Reply to topic  [ 157 posts ]  Go to page 1 2 3 4 511 Next
PostPosted: Wed May 31, 2006 12:37 am
Well Mr. Walser says he may build me a frame at the end of june. So I have to decide on a few pieces. The frame, bars, and wheels are already set in stone. I'm going to get a square taper bb from andy and I *may* buy SRMs to put on it. What do people think for:
1) Fork (has to be 1"). What's the best aero fork out there? Andy suggests profile design.
2) Saddle. I've ridden track bikes with steeper geometry, but this is my first tt bike. What do you like for TT saddles?
3) I have campy on my other bikes, should I look at shimano for any reason? The rear wheel is more narrow than normal and won't be interchangeable with my other bikes anyway.
4) brakes?
5) tuned rd with ceramics for a few watts?
Any other suggestions? I'm going for reliable and fast more than light. I will probably use standard cables/housing.
I'm really excited! I will probably be the slowest person ever to ride a walser but I'm really looking forward to it.
 Post subject:
PostPosted: Wed May 31, 2006 12:46 am
here is my 2 Cents:
Fork- Either easton (if avail in 1") or Profile.
Saddle- SLR tri
RD-Toss whatever you have laying around on there and wait for '07 record. I think it will be worth it.
Good luck, I wish I were lucky enough to own one of those masterpieces.
 Post subject:
 Post subject:
PostPosted: Wed May 31, 2006 1:13 am
Are there going to be improvements in record 07 that will matter for tt? Sounded like most were in integrated levers and cranks. Neither of which I'll need.
 Post subject:
PostPosted: Wed May 31, 2006 1:20 am
No contest! You HAVE to get the Oval Concepts Jetstream fork!
http://ovalconcepts.com/productsDetails ... &idProd1=1
Available in 1" & very fast. I was going to recommend the Blackwell Time Bandit, but it is only 1-1/8".
That's going to be a nice bike - definately get the SRM. Being able to pace with power in a TT is very sweet.
 Post subject:
PostPosted: Wed May 31, 2006 1:23 am
Probably not, but we can't be sure until we see it now can we? It might just be worth the wait to see if it is badass and worth the bling factor. PLus, it is campy, and you can never go wrong with campy.
 Post subject:
PostPosted: Wed May 31, 2006 1:32 am
Oval concept's jetstream is 495 grams vs 370 for the easton and 580 for the profile design.
I wonder what the aero difference between the jetstream and the easton is. 125grams is a reasonably big difference. Is there an aero fork shootout somewhere?
 Post subject:
PostPosted: Wed May 31, 2006 2:02 am
i really have to say that i like the true temper aero forks. they are reasonably light (about 400g) and very fast. the feel is very stiff yet very sensitive. and they are available in 1".
for the shifting, i have always found dura ace bar ends to be more precise than the campag equivolent. either is great, and i definately recommend the ceramic pulleys - i have them on my latest bike and intend to put them on the next bunch i build also - they are very smooth and really seem to make a difference.
on a TT bike i think that zeroG brakes are a good choice. you really want to use them as little as possible, and they are more to control your speed than to stop you (particularly if you're on a walser), so the compact brake is likely to make the least impression on the passing air.
saddle is such a personal choice that i wouldn't even know where to start. i don't like saddles with big pads up front however. if you tilt your saddle slightly down at the nose from your road setup you should find that the same saddle works for you either place - remember you want to be set up so that you are supported by your sit bones, not your perenium on the nose of the saddle...
___________________________________________________
"Organization is for the simple-minded, the Genius controls the chaos." - Jens
 Post subject:
PostPosted: Wed May 31, 2006 4:42 am
While I havent heard of true temper (and lance generally know's what he's talking about, he'd be able to give you more info) on the weight comparisons you'd probably be just as well off getting the SLX/SL. While some people proport large gains on an aero fork, theres probably better investments to be made to improve your aerodynamics -if its at a simmilar pricepoint to the SL/SLX. Actually, considering you're buying a walser, you've pretty much made on of the best aero investments arround.
Congrats and hope you enjoy it when it arrives.
 Post subject:
PostPosted: Wed May 31, 2006 6:05 am
Does anyone have any experience with the oval concepts aero brake calipers? They are designed to mount behind the fork. if I use the jetstream fork it might match nicely.
 Post subject:
PostPosted: Wed May 31, 2006 6:09 am
Tillquist who is on this forum has them. Try and get hold of him.
- G. Digital K. Loco
 Post subject:
PostPosted: Wed May 31, 2006 6:10 am
BTW. I have a Profile Designs BDC front fork, and that is very aero, and sweet looking too :D
PostPosted: Wed May 31, 2006 7:14 am
4) brakes?
Really nice pick!
Fork: I would look EA EC 90 Aero but that 1"...or Reynold Ouzo Pro Aero?
http://www.reynoldscomposites.com/en/OuzoProAero.htm
Saddle: SLR T1 ar Selle San Marco has similar. But TT/tri seat anyway
Brakes: Front:Oval is nice but need bit re-building. It's dangerous in stock. That cable clamp is insane and mounting system should be cut lower. Fits better then, least in EA. Rear, Cane Creek 200 SL will be enought powerfull for TT/light/slim lined for aero IF you get that for cheap but D-A is sure pick. Remember good, new brake pads first, those Oval Tectro pads smoke hardly even firts test ride on Hed H3C...Lightweight pads are way to go. Oval brake is made by Tectro so bad desing faults are NOT suprise. But they work well after 1/2 hours with hacksaw and with external cable anchor.
I like D-A's in tt-bike. Bar end sifters are 1/2 price of Campy and they seem to be better. And 55th 10s. D-A ring looks good in my bike...Tune cassette is nice too. Just dump that 11+23 and put few spacers on back of cassette...12-21 8s is them 110g.
Record's are the way for road because D-A has those ugly/crappy Sti's but for TT, I like them.
BTW, I have D-A's/EA Aero fork/Oval brake/SLR T1/Tune on my TT-bike too...and I have few 200 SL too, but they are on spare un-used now because I use my own brake system on rear.
Samu @ www.signature.fi
 Post subject:
PostPosted: Wed May 31, 2006 7:53 am
True Temper = Alpha Q
http://www.truetemper.com
http://www.alphaqbike.com
They sponsor Team CSC and also makes Cervélo's house brand Wolf forks.
The TT fork Alpha Q TS-20 is made in both 1" and 1 1/8": http://www.alphaqbike.com/performance_tubing/ts20.asp
 Post subject:
PostPosted: Wed May 31, 2006 8:50 am
Resident Pro
I have both there fork and brake. It works great. Meant to be the most areo two products for there purpose.
 Post subject:
PostPosted: Wed May 31, 2006 9:46 am
The Wolf TT is nice too, as used by Team CSC, it's said to be built to have the best aerodynamic next the front wheel... marketing?
 Post subject:
There are no new unread posts for this topic. Parlee Z3 - Rebuild... Full build pics at bottom of page 1.
Lig
18
2244
Wed Jan 18, 2017 6:34 pm
Lig View the latest post
There are no new unread posts for this topic. Colnago Extreme Power PR82 - Build Photos Page 3
[ Go to page: 1 2 3 4 ]
Mr.Gib
56
3472
Sat Mar 11, 2017 8:38 pm
Mr.Gib View the latest post
There are no new unread posts for this topic. Colnago C40 retro modern build *pictures uploaded*
TomColnago
Wed Nov 02, 2016 11:02 pm
mrfish View the latest post
There are no new unread posts for this topic. trying to get a new bike - should i buy a whole package or build one up myself?
lovemyway
26
1894
Tue Aug 02, 2016 2:37 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Stiffest and Strongest Bike Build
ardennes777
Tue Jul 05, 2016 1:58 am
kkibbler View the latest post
Users browsing this forum: AZR3, iwantone, MSNbot Media, tibikeboy and 18 guests
