Post new topic Reply to topic  [ 101 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7
 Post subject: Re: show me your cervelo
PostPosted: Fri Jun 22, 2012 10:52 pm
SSB wrote:
^ Nice ride! :thumbup:
Not a fan of the red Campy hoods, but maybe a little contrast is necessary on a stealthed frame like that. I'd debadge those wheels too!
Unsure about the hoods as well, probably going to change to black. Unsure if I can get the stickers on the wheels off, they seems to be under the clear painting, any suggestions ?
2012 Cervelo R5ca Campa Superrecord.
PostPosted: Wed Aug 22, 2012 6:40 am
Hello all, this is my cervelo!
do you have any upgrade suggestion ?
PostPosted: Wed Aug 22, 2012 6:04 pm
Change brake calipers to Ultegra, best braking calipers in the industry
 Post subject: show me your cervelo
PostPosted: Wed Aug 22, 2012 6:05 pm
^ this is true in my experience....
PostPosted: Wed Aug 22, 2012 6:35 pm
So some weight adding tips:
+1 re. brakes, I just got rid of my Gravitas brakes to go back to DA. But I suspect you would be fine with the latest DA pads. Secondly get rid of the Tufo tyres and get some Veloflex. Those will make the bike nicer to ride.
To reduce weight it's pretty simple; make a spreadsheet with current weights, then see how much it costs to save each g. Either set a £/g limit, or just buy things which save maximum g. But I would recommend not going crazy, for instance there is no point in buying light tyres if they give a bad ride (Tufo), don't fit (Schmolke bars and carbon seats) or spending £££s on light parts if you could save a lot more for less by switching to a lighter frame.
Assuming you want to keep the frame and forks I would look at things in roughly this order:
1. Cut off anything unnecessary; seat post, fork, shorten cables, remove stickers, throw away valve caps, shorten chain etc.
2. Focus on the small stuff; bolts, bottle cages, inner tubes, headset compressor and top cap, bar tape and ends, tyres, cables, veloplugs, chain, skewers... There is a lot of weight to be spared there for not too much cash
3. Look at cheaply upgrading the heavier items attached to the frame: saddle, post, bars, stem, pedals
4. Look at lighter groupset items: Cranks and brakes are main weight savers here
5. Change wheels and fork
6. Change frame
I would personally stop after 2. as you will have a nice, well-tuned bike. If you go further you might feel you have a mismatched bike with some areas begging to be upgraded until you spend lots of £££s on a whole new frame, groupset and wheels.
PostPosted: Sun Sep 16, 2012 9:11 pm
I posted a while back with my R3 which I broke. The frame was repaired and I finally rebuilt it. Here is the final build, with my wife's wheels which she has kindly let me borrow.
Hideous crank action there, but I had to put that reflective crap on for the Race Around Ireland and it's so difficult to get it off.
Picking her up from the shop.
Weight
Some vanity shots.
I'm going to leave this paint here as a reminder not to be so stupid.
Some fork damage which I'm really not so sure about.
PostPosted: Sun Sep 16, 2012 10:39 pm
Here it is updated and you can see on page three what it used to look like. Also in talks to get some custom bars done like the ones at in the last picture but more aero.
Bike is currently at 5980g/13.18 lbs.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Mon Sep 17, 2012 12:38 am
PostPosted: Mon Sep 17, 2012 12:59 pm
A bit dirty after a 104mi Granfondo
PostPosted: Thu Sep 20, 2012 11:36 am
Does somebody know an internetshop that still has a S1 frame size 56?
PostPosted: Fri Sep 21, 2012 10:51 pm
Already in its own thread, but I will add this here too:
:beerchug:
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
Users browsing this forum: Bing [Bot], Exabot [Bot], Google [Bot], Google Adsense [Bot], philipBer and 24 guests
There are no new unread posts for this topic. Attachment(s) Show me your sexy SRM PC7
devinci
10
1220
Mon Jan 21, 2013 11:05 pm
Tinea Pedis View the latest post
There are no new unread posts for this topic. Show us your Workshop
DartanianX
Tue Jun 19, 2012 6:32 pm
crohnsy View the latest post
There are no new unread posts for this topic. Attachment(s) Show me Your Tuning!
[ Go to page: 1 ... 17, 18, 19 ]
weeracerweenie
282
23876
Sun May 19, 2013 12:45 pm
weeracerweenie View the latest post
There are no new unread posts for this topic. Attachment(s) Show off you WW 29r builds!
[ Go to page: 1, 2, 3, 4, 5 ]
1spd
74
8422
Sun May 12, 2013 8:20 am
the_marsbar View the latest post
There are no new unread posts for this topic. Attachment(s) Show Us Your Toolboard ...
Valbrona
Sat Nov 10, 2012 3:31 pm
jeronimo View the latest post
It is currently Fri May 24, 2013 12:03 pm
