Rob English | Mudfoot 29er Rigid
by Denavelo
I'm headed up to Rob's area to finally pickup and build my Rob English Rigid 29er. Years ago I saw his baby blue belt drive bike and it won me over.
Years later a close friend was doing some work with him and got me into his queue for a build.
I live in LA where the cyclist use cross bikes on mountain bike trails (Rocks, steep, etc). I did a 100mi ride one year and it included a pretty daunting section of dirt and it ruined my desire for a CX bike.
So I ordered a rigid 29er to build with all of my weight weenie passion. I had Rob build it with boost spacing and enough clearance for 2.4 tires (Maybe even larger).
Here are some sneak pics and the build list. I'll post detailed pics when it's build up. Not sure if I should weigh it, but this is Weight Weenies!!!
Frame: Rob English custom 29er Rigid (Carbon headtube)
Fork: Rob English Custom Fork (15mm thru axle | Boost Spacing)
Headset: Tune Bobo
Stem: Extralite Hyperstem (Custom Painted)
Handlebars: Enve Sweep Carbon (Temporary until Mt Zoom arrives)
Grips: KCNC Foam Lock-on Grips
Shifters: SRAM XX1
Cassette: SRAM XX1
Chain: SRAM XX1
Crankset: SRAM XX1 GXP (Boost) sanded
Bottom Bracket: Chris King GXP
Chainring: Garbaruk 34T (Hand polished)
Pedals: XTR M9020 Trail SPD Pedal
Seatpost: MCFK 27.2
Seatpost Clamp: Rob English Custom
Saddle: MCFK 135mm 3k Weave
Front Brake: Shimano XTR Trail BR-M9020
Rear Brake: Shimano XTR Trail BR-M9020
Front Rotor: Ashima Flo-tor 180mm Floating 6 bolt
Rear Rotor: Ashima Flor-tor 160mm Floating 6 bolt
Front Hub: Carbon Ti X-Hub SP Boost (110mm) 28h
Rear Hub: Carbon Ti X-Hub SP Boost (148mm) 28h
Spokes: CX Rays Straight pull
Nipples: Sapim Alloy
Rims: MCFK Carbon 29er
Tires: Schwalbe Ralph Racing 29 x 2.35
Speedvagen Road Machine "2011 Surprise me | Cannondale SuperSix Evo | Rob English "Mudfoot" 29er | Firefly Ti #419
by davidw
Congrats dood! Finna be ill.
Sent from my SAMSUNG-SM-G930A using Tapatalk
by Bely
No.... that’s wicked!
The Harem
Speedvagen | Argonaut 2.0 | Cherubim (S) | Mosaic RT-1 | Festka Scalatore | Pegoretti Responsorium Ciavete | Wilier Cento10Air Ramato | Trek Madone 9
English | Field
Factor | Field | Baum | Stinner | F10
by Gullholm
Looking forward to see how this one turns out!
by jemima
That's going to look great.
