prendy im just fine
Prendy, I'm doing fine. Just back from Nice
Went out every day for a few hours climbing around.
The bike is 4 kilos ( clinchers) single chaining 53 x 28. I never used the 28 . Mostly in the 19,21,24
I will be putting on a thm clav I.just picked up , the sisl is fine.but i may as well drop another 100 or so grams
Just to say, because some posters can't climb on a 53 does not mean I can't
I find it very easy to spin and never caused me any issues. We all ride the way that is best for us. Both my bikes are now single chain ring.
I have added about a stone of muscle to my physique and so far it has not had any effect on my climbing. Hope you like the direction my bike has gone.
I permanent marker the tune housing.it needs the odd touch up but works ok.
I have just tune a rival wi fli in s way no one had tried. If it works ok I will do the same to a red . It drops a lot of weight. The mech on the guru weighs 70 grms. Not bad a?
. Cheers
Looks great. Tell us about the bike, and more pics please!
- prendrefeu
- Contact:
hey hey! Glad to see you're out and about!
Happy riding sir.
Happy riding sir.
Instagram @rich_dub_u
'19 Trek Emonda SLR H1 Rim Brake (6,250g) | '21 Sworks Tarmac SL7 (7,300g) | '21 BMC Teammachine SLR_01 | '15 Sworks Epic World Cup (10,242g)
prendrefeu wrote:hey hey! Glad to see you're out and about!
Happy riding sir.
Cheers prendy . A fellow ww said you mentioned me on a post so thought I would say hello to you.
Hope your projects are going well. I m sure you have my mail feel free to contact me .
Kevin has it if you don't, so if you want to discuss tuning ideas im happy to do that via mail .
. Cheers
- prendrefeu
- Contact:
Brilliant man, I'll drop a line sometime. After some more research may have figured a way to get those Tune housing into color... theoretically any color. It involves chemicals though, which I just ordered. Better living through chemistry I suppose.
I love the Tsubasa Cycles seatpost/saddle combo made by Ed A true work of art. Are you going the dentist way with the Clavicula SE crank?
BH Ultralight
Litespeed Ghisallo
Scott Addict Singlespeed
Cannondale Evo HiMod
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
prendrefeu wrote:After some more research may have figured a way to get those Tune housing into color... theoretically any color. It involves chemicals though, which I just ordered. Better living through chemistry I suppose.
Yes!! This is what it's all about - lengths not to add mass!
What are the specs on the Tune tubing: ID/OD, is this PTFE material? It can't be that exotic...
- prendrefeu
- Contact:
I think it is PTFE, or a PVC variant. I've ordered some MEK ("Clear Cleaner" works just as well) and petroleum dye (black) to test out coloring, I should know by next week when the dye finally arrives.
prendrefeu wrote:I think it is PTFE, or a PVC variant. I've ordered some MEK ("Clear Cleaner" works just as well) and petroleum dye (black) to test out coloring, I should know by next week when the dye finally arrives.
If it works would you be sweet with some sent your way to do and send back?
- prendrefeu
- Contact:
If it works I'll write up a little DIY/How To on the Tune housing thread, the components are easy-ish to acquire.
