The Wilier Cento10Air Ramato
NiFTY
by NiFTY
Great build. Proportions are perfect. Did you get a custom set of carbonworls to run button head screws as they are normally countersunk and if not i can't imagine they will last long as the carbon in that area is very thin to deal with unexpected forces from nonstandard bolts
hidefguy
by hidefguy
Bely wrote:
Sat Jan 27, 2018 9:28 am
Wowza! :beerchug:
Bely
by Bely
NiFTY wrote:Great build. Proportions are perfect. Did you get a custom set of carbonworls to run button head screws as they are normally countersunk and if not i can't imagine they will last long as the carbon in that area is very thin to deal with unexpected forces from nonstandard bolts
I had left the bolts back home! And swapped them out upon returning her home - not only that added a second.
The Harem
Speedvagen | Argonaut 2.0 | Cherubim (S) | Mosaic RT-1 | Festka Scalatore | Pegoretti Responsorium Ciavete | Wilier Cento10Air Ramato | Trek Madone 9
Incoming
English | Field
Ex's:
Factor | Field | Baum | Stinner | F10
kidrob
by kidrob
dgasmd wrote:
Sat Jan 27, 2018 2:33 pm
Pardon my ignorance, but what is the little roller on the down tube plate for?
Same question :roll: :mrgreen:
majklnajt
by majklnajt
WOW :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
glepore
by glepore
roller is a cable adjuster for mechanical shifting
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
jimaizumi
by jimaizumi
The magic question is "how is it vs the rest of your collectibles?"
:oops: THE PAST: 2005 Cannondale R700, 2006 Specialized S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
:D THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato
:wink: THE FUTURE: :mrgreen: :mrgreen:
