Colnago C 60 PLGL LTD Team one of 100 -
anquetil
by anquetil
1,1 pound under UCI limit
Willier
by Willier
Uroš, build list would be nice :wink:
anquetil
by anquetil
I think photo is good enough to see all parts, ok saddle is Berk, Stem Pro PLT, handlebar Deada superleggera and Frame is one of the lightest come out of factory(almost 200 g like ordinary in size50).
joe1234
by joe1234
Nice color! :thumbup:
Delorre
by Delorre
anquetil wrote:I think photo is good enough to see all parts, ok saddle is Berk, Stem Pro PLT, handlebar Deada superleggera and Frame is one of the lightest come out of factory(almost 200 g like ordinary in size50).
Stunning build!! What's the 'secret' about the frame? Why 200gr lighter than a regular c60? Due to frame construction, or rather the finish?
Bely
by Bely
Hot damn!!!
The Harem
Speedvagen | Argonaut 2.0 | Cherubim (S) | Mosaic RT-1 | Festka Scalatore | Pegoretti Responsorium Ciavete | Wilier Cento10Air Ramato | Trek Madone 9
Incoming
English | Field
Ex's:
Factor | Field | Baum | Stinner | F10
Imaking20
by Imaking20
Beautiful bike. I am a bit skeptical of the weight though. It was really challenging to get my bike under 14 lbs and that's without 300g+ brakes. I'm also curious about the frame weight. I don't believe my PLLB is a totally standard color, and it is lighter than my RSWH was, but not my nearly 200g. More info would definitely be appreciated!
Current:
T2
Retired:
anquetil
by anquetil
Frame is 8..g, fork(cutted) 340g. This frame is made for UAE team.
Its still space to go down under 6 kg easily(tires, seatpost, stem, bottle cage :), but i like 25 Arnbergs.
caballero
by caballero
I met the mexhanics at UAE who mentioned their frames were much lighter than regular c60s. This is one of the same framesets ?
anquetil
by anquetil
caballero wrote:I met the mexhanics at UAE who mentioned their frames were much lighter than regular c60s. This is one of the same framesets ?
Can not comment.
KCookie
by KCookie
Not really. A lot of us on here including myself have spreed sheets with every single component weighed and listed. Its great for others to compare and see the weights if they are interested in buying any item listed. Plus this is WWs after all.
Awesome bike any way. Enjoy.
liam7020
by liam7020
[/quote]Not really. A lot of us on here including myself have spreed sheets with every single component weighed and listed. Its great for others to compare and see the weights if they are interested in buying any item listed. Plus this is WWs after all.
Awesome bike any way.[/quote]
Agree with that. Also don't see the point of starting a thread on a "limited edition" frameset but then not being prepared to give any details on the frame.
Belgian Flag S-Works Tarmac viewtopic.php?f=10&t=144553
anquetil
by anquetil
Its LTD version of C60 build for UAE.
They test a few versions of frame( weight mostly and sometimes geometry(angles)).
This Toray carbon will be availible for market 2019 or 2020.
liam7020
by liam7020
That's extremely interesting - thanks for sharing that info.
SuperDomestique
by SuperDomestique
I have still got one 54s pro team C60 frame currently stripped. I'll weight it.
I had no idea they were supposed to be lighter.
Also have a regular C60 stripped in 54s to compare.
