2018 DISC Trek Emonda SLR 8
TNumber5
by TNumber5
boots2000 wrote:What size tire is that?
What is the largest that would fit?
It shipped with R3's in a 25. The demo I rode had 28s on it. Twas awesome! Deciding on which tires I am going to run. I had 28 4000s on the Madone 9. Probably will put them on. :beerchug:
TobinHatesYou
by TobinHatesYou
I have measured the rear chainstay width at the tires to be 38mm on my Emonda. This leaves a scant 3mm of clearance on either side of a tire that actually measures 32mm. 28mm GP4Ks measure around 32mm on wide rims, so it's not surprising how little fork clearance they had in the GCN video Delorre linked.
TNumber5
by TNumber5
New handlebar tape!
Sent from my SM-G955U using Tapatalk
oshkikimi
by oshkikimi
You can feel the sensibility!
Tell me to get speed play information!
Delorre
by Delorre
TNumber5 wrote:New handlebar tape!
It's funny (or not actually :? ), all those Emonda's ,especially in H2 geometry, look like you crashed them against a wall and the frame/ fork is bend.
themidge
by themidge
I've never noticed that before but now I can never un-see it! :? :D
:hello:
Cannondale Supersix 2008 (weight: tbc)
B'twin Triban 540 (weight: :oops: )
Vitus "Benotto" 979 (weight: :? )
Yetiunio
by Yetiunio
hahaha @Dellore you're right, my perception of Emonda will change from now :D
Scott2017
by Scott2017
Nice looking bike.
Weight weenie disc suggestions? Okay.
Why not go with ultralight tubulars? FSE makes some cheapish, ultra-light wheels that have been well reviewed by Cycle Tips. If budget is no limit, then Ax Lightness of course. Forget 28mm tires, too much weight, 25 at most.
Also, sell that Dura Ace groupset and get SRAM Red (not etap, too heavy!). Also go for the Emonda SLR10 seatcap and clamp (assuming you don't have it already).
Anyway, you asked, my 2 cents. Sweet ride nonetheless!
FIJIGabe
by FIJIGabe
Skip the SLR seatcap. It's over $100 for a 9g drop.
hlvd
by hlvd
FIJIGabe wrote:Skip the SLR seatcap. It's over $100 for a 9g drop.
I've got one, I believe the only difference is the clamp, rest of it looks exactly the same as the standard seat mast.
FIJIGabe
by FIJIGabe
Yeah, the vast majority of the savings is in the clamp.
phm8147
by phm8147
What wheelset are you using??
Aeolus 3d3 tlr disc ??
wheelbuilder
by wheelbuilder
phm8147 wrote:What wheelset are you using??
Those are the new Aeolus Pro's.......same shape but manufactured overseas, heavier.
FIJIGabe
by FIJIGabe
Also the same hubs as the "lower spec" Trek wheels (not DT Swiss), which doesn't mean much, because they're still awesome hubs. I'm not sure what the wheels actually weigh in at, but they're a good bargain. I only wish they made a 28h version for CX racing.
