This is one of their standard colourways. I liked the colour scheme and went with it. Didn’t want stealth black.
I’m a Campag guy so went with TRP Hy-roads in the new flat-mount style, 140mm at the rear and 160mm at the front. Maybe there will be an upgrade to full Campag hydro as money and inclination allow.
I’ve noticed that a lot of current road disc bikes have messy cable routing. Digital shifting allows for much cleaner cabling although I still need to tidy it up a bit. The bars are Zipp Aero SL which I’m liking very much. There’s a good transition of bar into shifter body.
TRP centrelock rotors.
Cable ports allow for mech or elec shifter cables.
Chunky BB86 bottom bracket shell.
12mm thru-axles front and rear.
The wheels I built from a Bdop cycling kit: Novatec centrelock hubs, Cx-ray spokes, carbon 40mm deep 26mm wide rim. They are lovely rims, 410g, tubeless compatible. They’re wearing Schwalbe One tubeless (original not Pro) in 28mm width. They weigh a ton, 390g, but they roll really nicely.
The frame finishing is very nice, I have no complaints.
The bike is not superlight, around 8.3kg as pictured. I’ve hardly put any time in on yet so ride assessment is to follow.
