2018 Specialized S-Works Tarmac Sagan Superstar *completed*
HaroldC
by HaroldC
Completed the SS and have a couple of rides so far. Swapped all the parts from the SL5 Sagan except the brakes, used EE direct mounts for the build. Mounting the EE direct mount brakes required a bit of learning curve, also trying to get the alignment of the cables was tricky with the rear seatstay and the "rear" brake.
Ride: More comfortable than my SL5 Sagan. The front and rear soak up more of the rough stuff, impressive given the fact that the BB feels stiffer. The power transfer is so direct, it really accelerates with every watt in the pedals. Really impressed with the frame!
Weight: 14.5 lbs or 6.577 kg - fully loaded and ready to ride with cages, pedals, Barfly Garmin mount, P2M Powermeter and Garmin speed sensor.
Photos: Just like the SL5 Sagan, the paint looks stunning and better in person than the photos. The decals are reflective and change with light conditions and angles, just like the paint.
Build:
Frame: 56cm S-Works Tarmac Sagan Superstar Edition
Drivetrain: Sram Red eTap
Cassette: Sram Red 11-26
Crankset: S-Works Cranks, Power2Max powermeter with Praxis 52-36 chainrings
Pedals: Speedplay Zero Stainless
Brakes: EE Direct Mount Brakes
Cables: Jagwire Elite Link
Handlebar: 3T Ergonova Team Stealth carbon 40cm
Stem: 3T Team Stealth 100mm
Tape: Specialized Roubaix tape
Garmin mount: Barfly
Saddle: S-Works Toupe
Wheels: Zipp 303 NSW
Tires: S-Works Turbo 26c
Cages: S-Works carbon
Topcap: Chameleon - Made Rad by Tony (Bauman)
And some weights of the frame with cable guides (but no BB, headset, or seat binder hardware), uncut fork and seat post with clamp hardware:
stockae92
by stockae92
wow! that's a pretty looking paint job!
AZR3
by AZR3
This is almost spot on how I'd build up that frame...so jealous!
Ghost234
by Ghost234
That frame looks so much better close up. I look forward to a complete build.
themidge
by themidge
Looks beautiful! :thumbup: sounds like a really nice build too.
I'm very impressed by the frame weight. With so much glossy paintwork you'd expect it to be heavier.
:hello:
Cannondale Supersix 2008 (weight: tbc)
B'twin Triban 540 (weight: :oops: )
Vitus "Benotto" 979 (weight: :? )
Mtek
by Mtek
Looks fantastic, paint is incredible. Personally, I would be calling in to work sick and start building it asap lol.
Delorre
by Delorre
What a color, wow ! Looking forward to the build. Is that still an OSBB in the same dimensions as before in the sl5 ? Looks like 2 alu inserts we're inserted in an sl5 BB shell, resulting in a smaller diameter, just like the alu OSBB frames
Geoff
by Geoff
Ok, that's nice. Really great paint!
robertg
by robertg
Harold! That looks amazing! I can't wait to see the final build in person.
mile2424
by mile2424
That definitely looks awesome! Can't wait to see her all built up! Love that paint job and don't forget the logo's are reflective :)
asiantrick
by asiantrick
du ma, that's fckin' nice yo
MRM
by MRM
Beauty! Can't wait!
bikemaniack
by bikemaniack
To make it lighter,you have to strip this paint off :)
Neddysmith
by Neddysmith
Thats a piece of art.
dereksmalls
by dereksmalls
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: That is some sick paint! Nice
