It is currently Fri Dec 15, 2017 5:55 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
 Post subject: Re: Cervelo S2 DA Di2
PostPosted: Wed Jun 21, 2017 3:36 am
Damn that looks clean.... did you run the Di2 wires with the rear brake cable? Any tips for running the Di2 wires on a S2 frame? Looking to build a S2 with the new 9150 group. I assume the battery fits in the seat tube? Nice work
PostPosted: Wed Jun 21, 2017 10:50 am
That cockpit... Superb.
PostPosted: Sun Jun 25, 2017 11:00 pm
Correct - The cable has been run with the rear brake cable (with another cable connecting the levers, and another from a shifter to the bar end plug). The main issue is battery location - i have dropped it in the seat tube with a withdrawal strap attached to it so I can pull it out (slightly nervous about dropping stuff into a frame!!£.. I did buy the di2 adaptor for the s5 but was too much hassle to make It worth the effort. I will take a look at the new 2017 seatpost at some point to see if it is easier.
PostPosted: Mon Jul 17, 2017 10:36 pm
Did you have to drill a hole to feed the di2 cable in near the rear brake cable? I had the same thing done in my s5. Small hole a small price to pay for a much tidier setup. No idea why cervelo does route this way and provide the hold themselves.
PostPosted: Tue Jul 18, 2017 8:43 am
No managed to slip it behind the plastic cable stop
PostPosted: Wed Jul 26, 2017 4:31 pm
I love that build!
Are you running 25mm Conti GP 4000II on your wheelset? Does the S2 frame and fork have enough clearance to run them?
By chance do you know the inner widht of your rims?
Thanks a lot!
There are no new unread posts for this topic. Cervelo R5
Olivv
12
2496
Mon Apr 17, 2017 7:11 pm
Olivv View the latest post
[ Go to page: 14 5 6 7 8 ]
NYCPrynne
118
17886
Wed Jun 28, 2017 3:50 pm
wingguy View the latest post
There are no new unread posts for this topic. Cervelo R3
itguy
Thu Apr 27, 2017 8:50 am
itguy View the latest post
There are no new unread posts for this topic. Cervelo S1
mannequinforce
9
1520
Wed Apr 26, 2017 6:01 pm
tmr5555 View the latest post
There are no new unread posts for this topic. Cervelo S5 replacement
brycerider
23
2480
Thu Jun 22, 2017 8:55 am
brycerider View the latest post
Users browsing this forum: Zitter and 6 guests
