It is currently Mon Jan 22, 2018 1:58 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Sat Apr 29, 2017 7:53 pm
Hello WW,
After building and selling about 7 bikes in the last year I have made enough to put together my "dream" build. I have always loved the paint scheme on this Venge and since I ride mostly flat bike paths I think this will be a great bike for me. Groupo will be SRAM Etap which I am super excited to try out and will be finished off with Enve Classic 45 wheels
Enjoy!
The Frame: 2012 S-Works Venge 54cm
Not terrible for an Aero frame, 136 grams more than the S-Works Tarmac
Same Weight as the Tarmac Fork
Pleasantly surprised at the weight of the seatpost
Bigass seatpost collar
Headset
Fork cap thingy
100mm SL Stem
Enve Top Cap
Cage Bolts
Brake cable guides
Derailleur block off pieces
Wheels Manufactering angular contact bottom bracket
Derailleur hanger
First Day progress
Once I get the bike complete and fitted I'll cut down the fork so there won't be a big ass spacer above.
Thanks!
2012 Specialized Venge S-Works
eTap
Enve Classics
PostPosted: Sun Apr 30, 2017 4:40 am
following
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Sun Apr 30, 2017 11:35 am
+1
subscribed...
PostPosted: Sun Apr 30, 2017 1:13 pm
Following as well... Nice A-Stars jacket.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
http://www.skratchlabs.com
2015 Specialized S-Works Allez
2015 Specialized Venge Pro
PostPosted: Fri May 05, 2017 5:08 am
Been really busy at work but had a chance to make some progress on the Venge
For the Crankset I am using a Specialized FACT 11r 172.5mm with some Rotor Rings I had laying around. I'm gonna try a couple combinations of rings that I have around the garage before I spend some money on a new set
Non drive side
Drive Side
Lock Ring
110 BCD Carbon Spider
Compression piece
36T
52T
New S-Works bolts
Now we get to the fun part :) ------ ETAP! Very Very excited to try this out
Front Derailleur
Battery
Rear Derailleur
Front Brake
Carbon Brake Pads
Rear Brake
For my wheelset I am going with a used pair of Enve Classics. Not sure if I will like a wheel with some depth to it so I decided not to spend a bunch of money and get something that was already experienced :) I took of the white stickers and put some red ones on.
Decent for an Aero Wheel
Used Turbo tires - Gonna go with S Works after I wear these out
Tube - Gonna go with something lighter when I put the S Works on
Enve Titanium Skewer
Day 2 progress with the red sticker ENVE front wheel
Comments and questions welcome!
eTap
Enve Classics
PostPosted: Fri May 05, 2017 1:57 pm
coming along nicely, so far...
PostPosted: Fri May 05, 2017 2:17 pm
Great build so far! The colors of the wheel stickers and the frame come great together!
My bike
PostPosted: Fri May 05, 2017 4:12 pm
This is going to be a sweet ride.
PostPosted: Fri May 05, 2017 4:57 pm
I read red stickers and thought oh nooo, but they look brilliant.
Looking forward to seeing the rest of your build.
PostPosted: Fri May 05, 2017 6:13 pm
I've always like the looks of the early Venges. I can't recall that paint scheme. It looks great. I would even say that red bartape could look good with a white/red saddle, but black would be the obvious/safe choice
PostPosted: Fri May 05, 2017 7:42 pm
Thanks yeah that bike is quite a bit faster than the Venge :D
I'm glad you like them, I was on the fence about the red.
Thanks! Really looking forward to putting some miles on it
Yeah I was on the fence about the red as well but my main motivation was to do something at least alittle different. It's a pretty "safe" and standard build so I thought the red would give it some slight uniqueness.
A red saddle and red tape is definitely in my plans for the future. The specialized power saddle has gotten glowing reviews so I got the expert version in black to see how my but likes it and if it agrees with it I will upgrade to the Pro version which comes in red.
Thanks for the nice comments!
eTap
Enve Classics
PostPosted: Fri May 05, 2017 11:58 pm
You will love those wheels, no doubt. The enve classics are fantastic in every way. That frame deserves some mid or deep dish carbon wheels anyway. I think it could look a bit off with low profile alum. options. Enjoying the build!
PostPosted: Tue May 23, 2017 8:26 am
Hey guys and gals I'm back after a busy two weeks.
Put the rear wheel on with the white stickers. I think both look good but I'm glad I went with the red.
Rear wheel Weight
Old beat up 10 speed hub
Shiny new 11 speed hub. Gained 3g
Rear Tire
Tube
SRAM Red 11-25T cassette
That's all for now. I should be finished by the weekend.
eTap
Enve Classics
PostPosted: Tue May 23, 2017 11:45 am
You are not gonna use that 117gr innertube, aren't you? :shock: Should be a very nice ride when all done :thumbup:
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
PostPosted: Tue May 23, 2017 5:24 pm
haha I am for the first few hundred miles. I want to get a feel for the bike before I put the expensive S-Works Turbo Rubber and S-Works tubes on.
eTap
Enve Classics
There are no new unread posts for this topic. 2017 Specialized S-Works Venge Vias Disc eTap / Enves 56cm - $6550
Samklee15
Sat Jan 20, 2018 12:51 am
Samklee15 View the latest post
There are no new unread posts for this topic. FS-2012 Specialized S-Works Venge
Bianchi10
Sat Dec 09, 2017 6:39 pm
Bianchi10 View the latest post
There are no new unread posts for this topic. S-Works Venge ViAS Disc Sagan WC Edition
lovemyway
7
2228
Sun Dec 17, 2017 2:20 pm
tmr5555 View the latest post
There are no new unread posts for this topic. Campag 303 on SRAM Etap build
in Everything wheels
Jbarker1975
Thu Jul 13, 2017 9:16 am
Jbarker1975 View the latest post
There are no new unread posts for this topic. Attachment(s) Di2 R9170 or eTap HRD for the disc brake build?
lovemyway
30
4177
Fri Sep 01, 2017 8:40 am
jino View the latest post
Users browsing this forum: No registered users and 6 guests
