It is currently Sat Dec 16, 2017 8:53 am
Post new topic  Reply to topic  [ 71 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: Filament Bikes
PostPosted: Fri Mar 17, 2017 3:08 pm
Here's my latest creation. It's a custom carbon frame for disc brakes with flat mount calipers and thru-axles.
The frame weighs 1kg and the bike weighs 6.9kg without pedals.
The paint is based on an artwork by Jackson Pollock.
ImageFilamentDisc by Filament, on Flickr
http://www.filamentbikes.com
http://www.instagram.com/filament_by_craddock
 Post subject: Re: Filament Bikes
PostPosted: Fri Mar 17, 2017 3:09 pm
Awesome paint job ! Looking forward to some weights perhaps
PostPosted: Fri Mar 17, 2017 3:14 pm
that really is the pollocks
Scott CR1 - 12.56Ib
Neon - 15.49Ib
PostPosted: Fri Mar 17, 2017 3:28 pm
Very nice !!
But why the spacers and short stem for a custom made frame ?
PostPosted: Fri Mar 17, 2017 3:35 pm
Awesome. You paint it yourself?
FF Ti Road
EM Alu Cross
PostPosted: Fri Mar 17, 2017 3:41 pm
csteenbe wrote:
Very nice !!
It's gotta be for a smaller rider in the 150-160cm range. If the reach were any shorter you wouldn't get toe overlap, you'd get foot overlap.
Gosh-darn that's a good looking paint job though.
PostPosted: Fri Mar 17, 2017 3:49 pm
The owner is probably well under 5' (150 cm) tall. thus the resulting slope of a shorter top tube and taller head tube would probably exceed the limits on effective bonds with tube-to-tube construction techniques, not to mention that if the top tube were any shorter, the toe-overlap of the front fork would end up being pretty precarious at slow speeds and technical turns.
PostPosted: Fri Mar 17, 2017 8:13 pm
The short stem let's me preserve a good front centre figure to avoid toe overlap without resorting to a lower HTA and increased fork offset. The result is good steering on a small bike. I've learned these things from my own experience of riding small frames.
This particular rider is building up his form after some time away from cycling so the 15mm of spacers allows him scope for lowering the handlebar in future, either through a change in flexibility, a desire to be more aero, or a change of saddle or pedal stack. I prefer to keep at least a 5mm spacer under a stem for these reasons.
The seatpost is not set at its final height in these photos.
Nice to hear that you like the paint.
PostPosted: Fri Mar 17, 2017 11:02 pm
Lovely.
What are the wheels?
PostPosted: Fri Mar 17, 2017 11:47 pm
Cool bike- What fork did you use?
Is there a nice road fork out there that allows for a tire in the 33-35mm range?
PostPosted: Sat Mar 18, 2017 3:11 pm
My regular painter took care of this as usual. He has to tape up plastic sheeting to catch the paint that misses the frame to keep his work space clean.
PostPosted: Sat Mar 18, 2017 3:16 pm
The new ENVE road disc fork has clearance for a 32, then their GRD version can take 38mm.
This fork is a special weight weenie unit that I source from the manufacturer - 350g. But it can only take a 28mm tyre, maybe a 30.
PostPosted: Sat Mar 18, 2017 3:19 pm
gerryc89 wrote:
Lovely.
Those are Ksyrium Elite Disc at 1670g.
PostPosted: Fri Apr 14, 2017 8:52 am
The super-duty sprinter edition tube set. The joints have been wrapped with prepreg carbon which will be cured in the oven.
ImageIMG_5229 by Filament, on Flickr
PostPosted: Fri Apr 14, 2017 11:00 am
Oof, love the downtube / BB area.
There are no new unread posts for this topic. Stolen Bikes
fitty4
Wed May 03, 2017 6:24 am
Shrike View the latest post
There are no new unread posts for this topic. Attachment(s) LOOK bikes quality (?)
stormur
Mon Oct 30, 2017 6:25 pm
mds View the latest post
There are no new unread posts for this topic. Alchemy Bikes
Lookryder
Mon Sep 25, 2017 2:01 pm
Lookryder View the latest post
There are no new unread posts for this topic. Factor bikes
Boshk
9
2014
Sat Sep 23, 2017 3:08 pm
corky View the latest post
There are no new unread posts for this topic. What happened to Look bikes?
[ Go to page: 13 4 5 6 7 ]
tranzformer
94
11343
Fri Jun 30, 2017 8:44 pm
flying View the latest post
Users browsing this forum: DOUG, Google Adsense [Bot] and 20 guests
