CAAD12 Project - 6.32kg
There is a plug that goes in between your frame and the cable running in. Not 100% sure where to get one. Since mine didn't come with that either.
There should be 2 washers that go in between your bearing and the bearing and arms
Just not certain if it's 2 or 3.
Hope this gives you a little help.
Much thanks but Ughh! So this will be delayed unless I can figure out a hack for the rear derailleur cable stop and I need to get to the bottom of the washer ordeal!
Did your frameset come with bb30 washers or just bearings?
Thanks again
Thanks again
Here's what you need for your BB. Wave washer not necessary.
What you're missing is the bb30 bearing seals.
The gap in the dropout is exposed on my rd cable also.
I do, sorry I thought you meant the small part above the qr nut being exposed.
raffit78 wrote:Wow looks great
Thanks.. unfortunately I have hit another snag.
HELP!!
I'm having crank issues. When I go to TQ to spec, there is way to much load on the bearings and the crank will hardly Spin with half the recommended TQ used.
I am using one bearing seal washer on each side. This Red22 crank has the screw type preload adjuster on the non drive side and I have checked that it is not pre loaded before install.
HELP!!!
I'm sure it's something simple and in curious if i need the bearing seal washer on the non drive side?
Thanks
I'm not familiar with sram, but I'd double check the accuracy of the comment that you don't need the wave washer.
Also Caad 12 has the 73mm bb you need the 5mm spacer on one side. The bb is asymmetrical.
