It is currently Sun Oct 22, 2017 6:12 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Feb 24, 2017 8:56 pm
Congrats on your new Scott! What a great price, too.
I'm impressed with your plan - I don't have the patience to take on all that sanding / paint removal.
Please keep posting pics of your progress. I'm eager to see what it becomes.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Fri Feb 24, 2017 9:13 pm
Thanks. I don't think I have the patience either. This project is definitely testing what little I have. I will get the nice camera out soon hopefully and try and get some proper pictures of my progress.
PostPosted: Fri Feb 24, 2017 10:49 pm
Hi,
i used paint remover to remove paint from a stevens slc. still some sanding necessary, but makes it much easier!
PostPosted: Sun Feb 26, 2017 9:58 pm
Reedplayer. Thanks for the suggestion of the paint stripper. In retrospect it may have been nice to use it but at least now I can relax that I haven't done any chemical damage to the carbon fibre or the resin.
I went riding on saturday in storm Doris so I was a bit too exhuasted after that to get pictures. However I got some today before I masked off the frame and painted it. I have pictures of before and some of the result after.
There are still scratches on the frame from the sanding and various little bits of paint left but I have wet sanded it to a good enough level to accept clear coat. So my sins should be covered.
As per usual I have ran out of daylight again and I still need to do some finishing touches to the paint. But here are some pictures of the finish.
The cable bosses will be painted gloss black which should hopefully create some nice little accents through the frame.
Here is the start of the masking for the logo I plan to put on the headtube. Not the best stencil I have ever made but it should do the trick.
Thanks for looking.
PostPosted: Wed Mar 01, 2017 7:39 pm
I set up my bike with some spare cables and stuff while I wait on the last few components today. However I am having issues with the front derailleur.
I had read about people having issues with the front derailleur tab cracking and coming off on these Scotts however I didn't expect it to be so flimsy. I can set up the front derailleur perfectly however as soon as I shift under the slightest load the tab flexes so much that the chain wont shift. I have tried both my SRAM Force derailleur and my Shimano 105 one which was the setup I had previously. I wonder if this is because I am using 11 speed chainrings? I know that everyone says chainrings are all cross compatible between 10 and 11 speed however these SRAM ones are plastered in warnings saying "only use with 11 speed"
Any help would be appreciated as I feel like I am missing a trick here.
Thanks
PostPosted: Thu Mar 02, 2017 12:05 am
Nice job on the paint strip. What shifters are you using?
PostPosted: Thu Mar 02, 2017 1:14 am
euph wrote:
However I am having issues with the front derailleur. I had read about people having issues with the front derailleur tab cracking and coming off on these Scotts however I didn't expect it to be so flimsy. I can set up the front derailleur perfectly however as soon as I shift under the slightest load the tab flexes so much that the chain wont shift. I have tried both my SRAM Force derailleur and my Shimano 105 one which was the setup I had previously. I wonder if this is because I am using 11 speed chainrings? I know that everyone says chainrings are all cross compatible between 10 and 11 speed however these SRAM ones are plastered in warnings saying "only use with 11 speed"
Yup, sadly that's a potential issue with that gen of Addict. Sorry to read you've been bitten by it.
I suspect Scott is aware. I've read numerous instances where Scott allegedly replaced frames with cracked carbon FD tabs. Furthermore, the FD tab on the current-gen Addict is significantly more robust and appears to have a metal insert behind it. My impression is that Scott is very progressive with their warranty support for original owners.
I struggled with the carbon FD tab on my '10 Addict (same gen as yours) that didn't ever appear cracked, but got floppier and more tempermental over the years. "My" trusty mechanic - who's a bike Jedi - mastered it, but other mechanics filling in would invariably be driven to tears trying to adjust my FD.
Not sure what's under the FD tab on the seat tube of this gen of Addict, but I frequently toyed with cutting off the FD tab and replacing it with a clamp-on unit (see Parlee and others). Instead of getting primeval on it, I demoted (promoted?) it to basement Zwift duty. My new bike will have a very robust FD tab with some sort of metal insert behind it.
https://store.parleecycles.com/products ... leur-clamp
PostPosted: Thu Mar 02, 2017 1:23 am
Kevosinn
I am using SRAM Red 10s shifters from my aluminium build that I have posted on here previously. Don't have the weight on me now.
Johnny Rad
I fear you are correct. I thought I was prepared for this issue and I went in very aware of it and made sure it was solid before I begun this project. Every visual sign was okay. I should have gone further and tested with a quick build up perhaps. Oh well. You live and you learn. I am going to experiment with epoxy and some pressure to see if I can give some "solidness" back to the mount.
Thanks for chiming in with your experience. I will update on my experimenting soon. Coincidentally while I had it built up it weighed ~6.9kg which is inline with my spreadsheet. Very happy.
PostPosted: Fri Mar 03, 2017 1:45 am
eTap has a brace of sorts for the FD tab ... check that out before you give up!
PostPosted: Thu Mar 09, 2017 10:37 am
Johnny Rad
Thanks for the tip. I have managed to make a little brace for my front derailleur. Combined with some epoxy around the developing cracks I have been able to build the bike up and get the front shifting to work nicely.
My fix is only temporary and in time to come I will either remove the tab and look into a lightweight "band on" replacement or maybe experiment with some carbon fibre as I will have some spare from a university project after summer.
I managed to take the bike out on the first ride today and it handles beautifully. I am pleased with the outcome. Thanks for all the help.
PostPosted: Thu Mar 09, 2017 2:58 pm
Would like to see how this turns out.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Mon Mar 13, 2017 2:22 pm
Took some quick pictures after a ride a few days ago. This is a temporary build as I only used spare cables and haven't stripped the paint off the fork yet. But it works and rides beautifully and that's all that matters.
In this picture the shifters look at a funny angle. I have set them this way because the strange eBay bars I am using don't want to cooperate with my shifters. More experimentation is needed. Or a real set of handlebars that won't kill me.
I also made a spreadsheet with the cost and weights in. I have weighed the bike with my hanging scales but they wont give me a reliable weight. Sometimes it is 6.9Kg sometimes it is 7.0Kg. So I will call it 7Kg for £1000
PostPosted: Mon Mar 13, 2017 2:43 pm
You need to get working on that fork. I like projects like this.
BIG DADDY B FLOW
PostPosted: Mon Mar 13, 2017 2:46 pm
I know. The fork is quite jarring! I was just bored of scraping and sanding. I will do it when I have the bike apart again to redo the cables.
PostPosted: Tue Mar 14, 2017 7:56 am
What's wrong with the handlebar? Are the cable holes at a wrong angle?
Chains to the right!
There are no new unread posts for this topic. Scott Addict RC 2010 or Basso Venta 2017 frameset
cveks
Wed Oct 18, 2017 3:06 pm
daniel8128 View the latest post
There are no new unread posts for this topic. Lightest Version of the Scott Addict Frame / Fork?
basenji29
Thu Aug 31, 2017 10:45 am
basenji29 View the latest post
There are no new unread posts for this topic. Scott Addict line-up changes for 2018 - no more HMX-SL carbon?
Johnny Rad
7
1065
Mon Sep 18, 2017 5:46 pm
MAsshole View the latest post
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
5083
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
There are no new unread posts for this topic. Scott addict 2017 headset
Jbarker1975
Sun Sep 10, 2017 6:06 am
Johnny Rad View the latest post
Users browsing this forum: doingitright, Herb5998, steff and 25 guests
