It is currently Thu Jan 18, 2018 3:06 pm
Post new topic  Reply to topic  [ 90 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Wed Jan 11, 2017 10:05 pm
liam7020 wrote:
One of the most sexy color scheme's for the F8 I've seen so far. What size was it?
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
PostPosted: Wed Jan 11, 2017 10:25 pm
MRM wrote:
wingguy wrote:
spartan wrote:
the 'old' f8 aero was tested by tour mag to be 2 watts slower than the madone/venge(cervelo/felt were 1 watt slower). f10 is 12.6% more aero so it should have same aero as the cervelo/felt twins. direct mount brakes should allow for 28 mm tires. the extra fairing on the fork tip is similiar to the bike wiggins rode when he set the hour record.
The direct mount brakes it doesn't have? :wink:
I think he means the F10 has direct mount brakes, not the F8.
Right, the direct mount brakes that it doesn't have. :wink:
PostPosted: Wed Jan 11, 2017 10:55 pm
There are no direct mount brakes on neither the F8 or the F10.
It's all downhill from here, except for the uphills.
PostPosted: Wed Jan 11, 2017 11:09 pm
Apologies. I must have misunderstood this.
{USERNAME} wrote:
The Shimano Dura-Ace Di2 control junction box is now hidden inside a compartment in the down tube, so it doesn’t hang below the stem. Another change is the switch from dual pivot to direct mount brake calipers.
Specialized Venge Pro Disc 8,3 kg
PostPosted: Wed Jan 11, 2017 11:31 pm
Obviously, they got it wrong. Just look at a picture of the F10. Any picture :wink:
PostPosted: Thu Jan 12, 2017 12:46 am
Delorre wrote:
Cheers! It's a 55cm.
Belgian Flag S-Works Tarmac viewtopic.php?f=10&t=144553
PostPosted: Thu Jan 12, 2017 1:56 am
velocite's patent will never hold up.
look at this litespeed.
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
PostPosted: Thu Jan 12, 2017 7:42 am
In Slovenija difference between F8 and F10 is 300 €, F8 Xlight is 1.700 € more than F10.
PostPosted: Thu Jan 12, 2017 8:27 am
Shop Owner / Manufacturer
The Litespeed Archon was part of the prior art review during the patent application process. It was deemed that our design was sufficiently different to be awarded a full 20 year invention patent. More information here if you search for I562931: http://twpat3.tipo.gov.tw/tipotwoc/tipo ... 2023003b0d
Venn Cycling
Velocite Bikes
Cycle Taiwan
PostPosted: Thu Jan 12, 2017 9:02 am
So yours is different enough from there's to be patentable, but Pina's is similar enough to yours to be infringement? Why is that?
Honestly all 3 of them look equally similar in concept and different in execution to me :noidea:
PostPosted: Thu Jan 12, 2017 9:16 am
I do not want to go into details lest it be used against our claim sometime in the future if Pinarello/LVHM decides that court is their preferred mediation venue, but, in a nutshell it has to do with integration of the water bottle into the airflow, not just concavity. Concavity was the only way to achieve this.
Our solution that Pinarello is using is functional, it is not styling.
Second and the easiest to observe difference between Archon and Velocite Syn/Pinarello Dogma F10 is in the length of the concave section. It has to be long enough to work with the bottle in place. The concave section on the Archon is too short in a horizontal plane. Pinarello's follows our patent and our research.
A little bit more info and one of our CFD simulations can be seen here under point 1. It is aerodynamic, published in May 2015: http://blog.velocite-bikes.com/2015/05/ ... now-active
Venn Cycling
Velocite Bikes
Cycle Taiwan
PostPosted: Thu Jan 12, 2017 11:34 pm
moonoi wrote:
... and then the Di2 integration is designed specifically around the new DA9150, so you can't use the downtube port to hide the junction box if you have the older version or Ultegra, or for that matter EPS, genius.
Call this Complicity in International Crime! :mrgreen: :mrgreen:
Perhaps a way to "force" others to get on with the "program". I love Campy to death, but come on! They should have had a slimmer and better battery since V2. Also, their V3 interface is antiquated and bulky! They are overdue for a better junction box and so on.
..A..
PostPosted: Fri Jan 13, 2017 12:02 am
DI2 junction boxes are all cross compatible. If you can afford £4k for a frameset you can afford £110 for a new junction box to go with your old group :lol:
PostPosted: Mon Feb 06, 2017 12:22 am
No the F10 does not have direct mount brakes, which in my opinion is a disappointment to see a newly released frame of this kind and have these brakes.
I am not sure what Pinarello was thinking, but I just could not see many people rushing to get this frame after the lame improvements they made.
They Should have called it the F8.5. Now take a look at the Bianchi Oltre XR.4 and the new Cervelo R5 that they have on the works. Those are good examples of bikes being modernized.
..A..
PostPosted: Mon Feb 06, 2017 12:35 am
Doesn't matter. They're going to sell them as quickly as they can make them.
The new R5 proto doesn't have DM brakes either :wink:
Also consider, Cervelo launched the new R5 at about the same time Pinarello released the 65.1 Think2. Since then Pina released the F8, and now the new F10. Cervelo released a new colour scheme, and now the new R5.
There are no new unread posts for this topic. Difference in Pinarello Gan RS 2016-2017
Daniel1975
Fri Dec 22, 2017 12:31 pm
Daniel1975 View the latest post
There are no new unread posts for this topic. My Pinarello Dogma F8
deano87
7
1745
Wed Nov 08, 2017 8:10 pm
philhul83 View the latest post
There are no new unread posts for this topic. Pinarello Dogma 65.1 Think 2
nismosr
Thu Apr 20, 2017 2:06 pm
nismosr View the latest post
There are no new unread posts for this topic. Pinarello dogma upgrade ,
SNUGSHIP
10
1601
Mon Apr 24, 2017 4:52 pm
audiojan View the latest post
There are no new unread posts for this topic. Attachment(s) Pinarello Dogma F8 Size 47 - Help!!!
TwinSpokes21
26
4529
Thu Jul 20, 2017 9:07 am
PinaF8 View the latest post
Users browsing this forum: coriordan and 18 guests
